Khi em chạy code msit81_3 có lúc báo lỗi script out of range có lúc không? Quan trọng hơn nữa là khi chạy xong vẫn thấy thiếu phần của tiền EUR ah!
Mong mọi người chỉ giúp!
Đây là đoạn code VBA, mà em mày mò mãi chưa ra ah
Sub msit81_3()
''Dung Dictionary tong hop theo DP_TypeCode
Sheets("msit81_DP").Select
Dim Dic As Object
Dim iRow As Long, I As Long
Dim Arr() As Variant, VungDuLieu As Variant
With Sheets("BaoCaoTheoMSIT81")
.Range("A7:AR45").ClearContents
'''''''''''Tu dong 7 den dong 45
With Sheets("msit81_DP")
VungDuLieu = Range("A1", Range("A1").End(xlToRight).End(xlDown).Address).Value '65536 '1048576
ReDim Arr(1 To UBound(VungDuLieu, 1), 1 To 29)
For iRow = 1 To UBound(VungDuLieu, 1)
j = j + 1
If Not IsEmpty(VungDuLieu(iRow, 5)) And Not Dic.Exists(VungDuLieu(iRow, 5)) Then
I = I + 1
Dic.Add VungDuLieu(iRow, 5), I
Arr(I, 1) = VungDuLieu(iRow, 5) 'Arr(I,1): DPCode
If VungDuLieu(iRow, 10) = "USD" Then
'''''''voi loai tien USD
If VungDuLieu(iRow, 1) = "00" Then
Arr(I, 2) = VungDuLieu(iRow, 11)
ElseIf VungDuLieu(iRow, 1) = "03" Then
Arr(I, 5) = VungDuLieu(iRow, 11)
ElseIf VungDuLieu(iRow, 1) = "04" Then
Arr(I, 8) = VungDuLieu(iRow, 11)
ElseIf VungDuLieu(iRow, 1) = "07" Then
Arr(I, 11) = VungDuLieu(iRow, 11)
ElseIf VungDuLieu(iRow, 1) = "09" Then
Arr(I, 14) = VungDuLieu(iRow, 11)
ElseIf VungDuLieu(iRow, 1) = "10" Then
Arr(I, 17) = VungDuLieu(iRow, 11)
ElseIf VungDuLieu(iRow, 1) = " " Then
Arr(I, 20) = VungDuLieu(iRow, 11)
ElseIf VungDuLieu(iRow, 1) = "05" Then
Arr(I, 23) = VungDuLieu(iRow, 11)
ElseIf VungDuLieu(iRow, 1) = "01" Then
Arr(I, 26) = VungDuLieu(iRow, 11)
ElseIf VungDuLieu(iRow, 1) = "02" Then
Arr(I, 29) = VungDuLieu(iRow, 11)
ElseIf VungDuLieu(iRow, 1) = "06" Then
Arr(I, 32) = VungDuLieu(iRow, 11)
ElseIf VungDuLieu(iRow, 1) = "08" Then
Arr(I, 35) = VungDuLieu(iRow, 11)
ElseIf VungDuLieu(iRow, 10) = "VND" Then
Arr(I, 3) = VungDuLieu(iRow, 11)
Arr(I, 6) = VungDuLieu(iRow, 11)
Arr(I, 9) = VungDuLieu(iRow, 11)
Arr(I, 12) = VungDuLieu(iRow, 11)
Arr(I, 15) = VungDuLieu(iRow, 11)
Arr(I, 18) = VungDuLieu(iRow, 11)
Arr(I, 21) = VungDuLieu(iRow, 11)
Arr(I, 24) = VungDuLieu(iRow, 11)
Arr(I, 27) = VungDuLieu(iRow, 11)
Arr(I, 30) = VungDuLieu(iRow, 11)
Arr(I, 33) = VungDuLieu(iRow, 11)
Arr(I, 36) = VungDuLieu(iRow, 11)
ElseIf VungDuLieu(iRow, 10) = "EUR" Then
Arr(I, 4) = VungDuLieu(iRow, 11)
Arr(I, 7) = VungDuLieu(iRow, 11)
Arr(I, 10) = VungDuLieu(iRow, 11)
Arr(I, 13) = VungDuLieu(iRow, 11)
Arr(I, 16) = VungDuLieu(iRow, 11)
Arr(I, 19) = VungDuLieu(iRow, 11)
Arr(I, 22) = VungDuLieu(iRow, 11)
Arr(I, 25) = VungDuLieu(iRow, 11)
Arr(I, 28) = VungDuLieu(iRow, 11)
Arr(I, 31) = VungDuLieu(iRow, 11)
Arr(I, 34) = VungDuLieu(iRow, 11)
Arr(I, 37) = VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 2) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 2) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 5) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 5) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 8) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 8) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 11) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 11) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 14) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 14) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 17) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 17) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 20) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 20) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 23) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 23) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 26) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 26) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 29) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 29) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 32) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 32) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 35) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 35) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 3) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 3) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 6) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 6) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 9) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 9) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 12) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 12) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 15) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 15) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 18) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 18) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 21) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 21) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 24) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 24) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 27) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 27) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 30) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 30) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 33) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 33) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 36) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 36) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 4) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 4) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 7) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 7) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 10) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 10) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 13) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 13) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 16) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 16) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 19) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 19) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 22) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 22) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 25) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 25) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 28) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 28) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 31) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 31) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 34) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 34) + VungDuLieu(iRow, 11)
Arr(Dic.Item(VungDuLieu(iRow, 5)), 37) = Arr(Dic.Item(VungDuLieu(iRow, 5)), 37) + VungDuLieu(iRow, 11)
Next iRow
Sheets("BaoCaoTheoMSIT81").Select
.Range("B9").Resize(I, 37).Value = Arr 'dong nay de xuat gtri mang Arr ra
.Range("C7").Value = "HoiSo-TienGui"
.Range("C7:E7").Merge
.Range("F7").Value = "PGD03-TienGui"
.Range("F7:H7").Merge
.Range("I7").Value = "PGD04-TienGui"
.Range("I7:K7").Merge
.Range("L7").Value = "PGD07-TienGui"
.Range("L7:N7").Merge
.Range("O7").Value = "PGD09-TienGui"
.Range("O7:Q7").Merge
.Range("R7").Value = "PGD10-TienGui"
.Range("R7:T7").Merge
.Range("U7").Value = "IB-TienGui"
.Range("U7:W7").Merge
.Range("X7").Value = "PGD05-TienGui"
.Range("X7:Z7").Merge
.Range("AA7").Value = "PGD01-TienGui"
.Range("AA7:AC7").Merge
.Range("AD7").Value = "PGD02-TienGui"
.Range("AD7:AF7").Merge
.Range("AG7").Value = "PGD06-TienGui"
.Range("AG7:AI7").Merge
.Range("AJ7").Value = "PGD08-TienGui"
.Range("AJ7:AL7").Merge
.Range("C9").Value = "USD"
.Range("D9").Value = "VND"
.Range("E9").Value = "EUR"
.Range("C9:E9").Copy
.Range("F9:AL9").Select
.Paste
.Range("A9").Value = "STT"
.Range("B9").Value = "DPcode"
Set Dic = Nothing
Sheets("BaoCaoTheoMSIT81").Range("A7:AL" & Cells(Rows.count, 2).End(xlUp).Row).Select
With Selection
.Borders(xlDiagonalDown).LineStyle = xlNone
.Borders(xlDiagonalUp).LineStyle = xlNone
.Borders(xlEdgeLeft).Weight = xlMedium
.Borders(xlEdgeTop).Weight = xlMedium
.Borders(xlEdgeBottom).Weight = xlMedium
.Borders(xlEdgeRight).Weight = xlMedium
.Borders(xlInsideVertical).Weight = xlThin
.Borders(xlInsideHorizontal).Weight = xlThin
Sheets("BaoCaoTheoMSIT81").Range("B8:B" & Cells(Rows.count, 2).End(xlUp).Row).Select
With Selection
.ColumnWidth = 4.71
.HorizontalAlignment = xlCenter
.VerticalAlignment = xlCenter
.WrapText = True
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.ShrinkToFit = False
.ReadingOrder = xlContext
'Sap xep thu tu cot DPcode
DongCuoiCuaCot = Cells(Rows.count, 2).End(xlUp).Row
ActiveWorkbook.Worksheets("BaoCaoTheoMSIT81").Sort.SortFields.Clear
ActiveWorkbook.Worksheets("BaoCaoTheoMSIT81").Sort.SortFields.Add key:=Range( _
"B9:B" & DongCuoiCuaCot), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
xlSortNormal
With ActiveWorkbook.Worksheets("BaoCaoTheoMSIT81").Sort
.SetRange Range("B9:AL" & DongCuoiCuaCot)
.Header = xlYes
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
Range("C10", Range("AL" & DongCuoiCuaCot)).Select
Selection.NumberFormat = "#,##0.00"
Columns("A:AL").AutoFit
Sheets("BaoCaoTheoMSIT81").Range("A8").Select
