Giúp đỡ căn chỉnh dòng tự động khi soạn văn bản bằng Excel (3 người xem)
em xin file bác sửa cod trên file excel của em ạ
cho e xin file excel này của bác tham khảo với ạ
Sub ExportExcel2Word_AllF()
Dim DataC As Long, Tg
Dim dem As Long, EndR As Long, EndC As Long
Dim objRange, objTable
Dim wDoc, aWord
Dim FCol As Long, LCol As Long, i As Long
Const CFont = "Times New Roman"
Const CSize = "14"
Const CColor_Normal = wdColorDarkGreen
Const CColor_Table = wdColorDarkBlue
Tg = Timer()
Set aWord = CreateObject("Word.Application")
'TAO FILE WORD
Set wDoc = aWord.Documents.Add
aWord.Visible = True
'SHEET NGUON: Dem cot, dem dong
For FCol = 1 To 100
If Cells(65536, FCol).End(xlUp).Row > 10 Then Exit For
Next FCol
EndR = Cells(65536, FCol).End(xlUp).Row + 2
Cells(1, FCol).Select
For dem = 1 To EndR
Cells(dem, FCol).Select
If LCol < Selection.Columns.Count Then LCol = Selection.Columns.Count
Next dem
LCol = LCol + FCol - 1
'CHEP TU DAU DEN CUOI VB
For i = 1 To EndR
'Neu khong chia nhieu cot
If WorksheetFunction.CountA(Range(Cells(i, FCol), Cells(i, LCol))) = 1 Or WorksheetFunction.CountA(Range(Cells(i, FCol), Cells(i, LCol))) = 0 Then
'Cell hien hanh khong co du lieu -> chep nguyen dong hien hanh
If Cells(i, FCol) = "" Then
Range(Cells(i, FCol), Cells(i, LCol)).Copy
Set objRange = wDoc.Paragraphs(wDoc.Paragraphs.Count).Range
objRange.Paste
With objRange
.Font.Name = CFont
.Font.Size = CSize
.Font.Color = CColor_Table
wDoc.Range.InsertAfter Cells(i, FCol) & vbCrLf 'Chep du lieu neu co
'Dinh dang doan van ban
With wDoc.Paragraphs(wDoc.Paragraphs.Count - 1).Range
.Font.Name = CFont
.Font.Size = CSize
.Font.Color = CColor_Normal
'Dinh dang cac dong co font chu Dam
If Cells(i, FCol).Font.Bold = True Then
.Font.Bold = True
'Can chinh
If Cells(i, FCol).HorizontalAlignment = xlCenter Then
.ParagraphFormat.Alignment = wdAlignParagraphCenter
.ParagraphFormat.Alignment = wdAlignParagraphJustify
'Gian cach giua 2 doan van ban
.ParagraphFormat.SpaceBefore = 3
.ParagraphFormat.SpaceBeforeAuto = False
.ParagraphFormat.SpaceAfter = 3
.ParagraphFormat.SpaceAfterAuto = False
'Neu tai cac dong co nhieu cot
If WorksheetFunction.CountA(Range(Cells(i, FCol), Cells(i, LCol))) > 1 Then
If Cells(i, FCol).Borders(xlEdgeTop).LineStyle = xlContinuous Then
For dem = i To EndR
If Cells(dem, FCol).Borders(xlEdgeRight).LineStyle = xlNone Then Exit For
Next dem
Range(Cells(i, FCol), Cells(dem - 1, LCol)).Copy
'Cells(dem - 1, FCol).Select
i = dem - 1
'Chep Table tu Excel sang Word
'On Error Resume Next
objRange.Paste
With objRange
.Font.Name = CFont
.Font.Size = CSize
'On Error GoTo 0
'Dinh dang le trang in
With wDoc.PageSetup
.Orientation = wdOrientPortrait
.TopMargin = CentimetersToPoints(2.2)
.BottomMargin = CentimetersToPoints(2)
.LeftMargin = CentimetersToPoints(3.3)
.RightMargin = CentimetersToPoints(1.5)
Dim oTbl As Object, oTblX As Object
Set oTblX = wDoc.Tables(1)
oTblX.AutoFitBehavior (wdAutoFitContent)
MsgBox "Tong thoi gian la " & Round(Timer() - Tg, 2) & " giay"
'Call LuuFileWord
aWord.Activate 'Xem ket qua
Set wDoc = Nothing
Set aWord = Nothing
Tôi chỉnh sửa nhiều chỗ trong Autofit chiều cao dòng và xuất ra Word. Trong đó, xuất ra Word có 3 Sub. Các bạn tải file BC của bạn tuan16 về chạy thử với các lưu ý:
1. Autofit: cần chuẩn bị cột phụ như trong file và khai báo cột phụ ở gần đầu sub, chỗ: ChrCol = "R" 'Khai báo cot phu de AutoFit. Cột R đó tôi để đó cho trực quan, nhưng khi dùng trong thực tế phải ẩn đi.
2. ExportExcel2Word: Khai báo cell chứa giá trị header và footer chỗ Hder = Range("S1"): Fter = Range("S2") gần cuối sub. Ở các sub không format văn bản thì khi xuất sẽ phụ thuộc vào định dạng Style Normal của Word. Bạn cần setting áp dụng cho tất cả các document của Word trước khi chạy sub.
Cảm ơn bác nhiều. Đoạn code chạy ổn trên file bác gửi lên... Nhưng em không hiểu sao khi em lấy đoạn code ra và áp dụng trên một file excell mới thì luôn báo lỗi. Chắc em còn sai ở bước nào rồi
Excel bị lỗi thiếu thư viện
Bac songmai xem dùm lỗi: Đối với các hình ảnh trong excel khi xuất qua word thì vẫn còn tình trạng lúc có lúc không có hình
BSongmaimai xem dùm lỗi: Đối với các hình ảnh trong excel khi xuất qua word thì vẫn còn tình trạng lúc có lúc không có hình
Khác phục lỗi thư viện này sao bác. Hướng dẫn em với ạ
Bạn không thể nhờ người khác giúp với cách như vậy. Tôi nhớ rằng đã nhắc bạn rồi nên giờ tôi không nhắc nữa.
Tôi chưa làm việc với hình nên không thể trả lời bạn được
cài lại office hoặc gửi file lên đây
bác xem giúp mình với ạ
dạ thưa bác. đoạn code autofit của bác thì em chạy bình thường. nhưng những đoạn code để xuất ra word lại không được nên em mới phải nên hỏi các bác ạ
bỏ 3 dòng này
Const CColor_Normal = wdColorblack
Const CColor_Table = wdColorblack
bỏ 3 dòng này
đã bỏ
dòng này
ở cả 3 sub mà không được bác ạ. Nhờ bác xem với ạ
@thoai
Bạn cần xuất table sang Word kiểu gì?
1- Xuất 1 bảng có địa chỉ cụ thể trong file Excel vào 1 nơi cụ thể chuẩn bị sẵn trong file Word.
2- Xuất tất cả các bảng có trong file Excel vào cùng 1 nơi cụ thể chuẩn bị sẵn trong file Word.
... (ý của bạn)
Nếu có file mẫu thì dễ code
