Sub Test()
  Dim File, Files, LR&, LR_KQ&, LR_TH&, LC%, R&, C%, K&, Arr, tArr()
  Dim TH As Worksheet, WS As Worksheet, WB As Workbook
  Const CR = 12, nWS = "TongHop"
  Set TH = ThisWorkbook.Worksheets(nWS)
  If Err Then: Set TH = Application.Workbooks.Add: TH.Name = nWS
  R = TH.Range("A" & Rows.Count).End(xlUp).Row
  If R > CR Then TH.Range("A" & CR + 1).Resize(Rows.Count - CR, 1).ClearContents
  Err.Clear
  ListAllFiles ThisWorkbook.Path, , Files, False, ".xls*"
  If Not IsArray(Files) Then Exit Sub
  For Each File In Files
    Set WS = Nothing
    Set WB = Application.Workbooks(File)
    If Err Then Set WB = Application.Workbooks.Open(File, , True)
    Err.Clear
    For Each WS In WB.Worksheets
      If Not WS.Name Like "*(*)*" And LCase(WS.Name) Like "ket qua kt*" Then Exit For
      Set WS = Nothing
    Next WS
    If Not WS Is Nothing Then
      LR_KQ = WS.Range("A" & Rows.Count).End(3).Row - CR
      If LC <= 0 Then LC = WS.Cells(CR - 1, Columns.Count).End(xlToLeft).Column
      If LR_KQ > 0 And LC > 0 Then
        If LR = 0 Then
          WS.Range("A" & CR - 3).Resize(4, LC).Copy TH.Range("A" & CR - 3).Resize(4, LC)
          TH.Range("A" & CR - 3).Resize(4, LC).value = TH.Range("A" & CR - 3).Resize(4, LC).value2
          Application.CutCopyMode = True
        ReDim Preserve tArr(1 To LC, 1 To LR + LR_KQ)
        Arr = WS.Range("A" & CR + 1).Resize(LR_KQ, LC).Value2
        For C = 1 To LC
          For R = LR + 1 To LR + LR_KQ
            tArr(C, R) = Arr(R - LR, C)
            If C = 1 Then: K = K + 1: tArr(C, R) = K
          Next R
        Next C
        LR = LR + LR_KQ
    WB.Close False
    Set WB = Nothing
  On Error GoTo 0
  If LR > 0 And LC > 0 Then
    ReDim Total(1 To LR, 1 To LC)
    For R = 1 To LR: For C = 1 To LC
        Total(R, C) = tArr(C, R)
    Next C, R
    TH.Range("A" & CR + 1).Resize(LR, LC).Value = Total
    TH.Activate
  Set WS = Nothing: Set TH = Nothing
Sub ListAllFiles(ByVal aFolder, _
        Optional ByRef FSO As Object, _
        Optional ByRef Files As Variant, _
        Optional ByVal IncludeSubfolders As Boolean, _
        Optional ByVal Types = "*.*", _
        Optional ByVal NameTypes = "", _
        Optional ByVal iShortPart As Boolean)
  If TypeName(aFolder) = "String" Then aFolder = Array(aFolder)
  Dim I&, K&, T$, T2$
  Dim aTypes(), Arr(), dArr()
  Dim SF, Item, Folder, sFolder
  I = -1
  If TypeName(NameTypes) = "String" Then
    If NameTypes <> vbNullString Then I=I+1:ReDim aTypes(I): aTypes(I) = LCase(NameTypes)
    ReDim aTypes(UBound(NameTypes))
    For I = LBound(Files) To UBound(Files): Arr(I) = LCase(NameTypes(I)): Next I
  If TypeName(Types) = "String" Then
    If Types <> vbNullString Then
      I = I + 1
      ReDim Preserve aTypes(I+1)
      aTypes(I+1) = "*" & LCase(Types)
    ReDim  Preserve aTypes(UBound(Types) + IIf(I = -1, 0, I))
    For K = LBound(Types) To UBound(Types): aTypes(K + IIf(I = -1, 0, I)) = "*" & LCase(Types(K)): Next K
  If FSO Is Nothing Then Set FSO = CreateObject("Scripting.FileSystemObject")
  I = -1: K = 0
  If IsArray(Files) Then
    ReDim Arr(UBound(Files))
    For I = LBound(Files) To UBound(Files): Arr(I) = Files(I): Next I
  For Each Folder In aFolder
    If FSO.FolderExists(Folder) Then
      Set sFolder = FSO.GetFolder(Folder)
      For Each Item In sFolder.Files
        T = vbNullString: T = LCase(Item.Name)
        T2 = vbNullString: T2 = LCase(Item.Type)
        For Each SF In aTypes
          If Left(T, 1) <> "~" And (T Like SF Or T2 Like SF) Then
            I = I + 1: ReDim Preserve Arr(I): Arr(I) = IIf(iShortPart, Item.ShortPath, Item.Path)
            Exit For
        Next SF
      Next Item
      If IncludeSubfolders Then
        For Each SF In sFolder.SubFolders
          ReDim Preserve dArr(K): dArr(K) = SF.Path: K = K + 1
        Next SF
  Next Folder
  Files = Arr
    ListAllFiles dArr, FSO, Files, True, Types, NameTypes, iShortPart
