Private Sub ComboBox1_Change()
With Range([A12], [A10000].End(xlUp))
.Offset(, 0).Value = "=IF(DATA!RC=SOCT!R1C5,DATA!RC[1],"""")"
.Offset(, 1).Value = "=IF(DATA!RC[-2]=SOCT!R1C5,DATA!RC[1],"""")"
.Offset(, 2).Value = "=IF(DATA!RC[-3]=SOCT!R1C5,DATA!RC[1],"""")"
.Offset(, 3).Value = "=IF(DATA!RC[-4]=SOCT!R1C5,DATA!RC[1],"""")"
.Offset(, 4).Value = "=IF(DATA!RC[-5]=SOCT!R1C5,DATA!RC[1],"""")"
.Offset(, 5).Value = "=IF(DATA!RC[-6]=SOCT!R1C5,DATA!RC[1],"""")"
.Offset(, 6).Value = "=IF(DATA!RC[-7]=SOCT!R1C5,DATA!RC[1],"""")"
.Offset(, 7).Value = "=IF(DATA!RC[-8]=SOCT!R1C5,DATA!RC[1],"""")"
.Offset(, 8).Value = "=IF(DATA!RC[-9]=SOCT!R1C5,DATA!RC[1],"""")"
.Offset(, 9).Value = "=IF(DATA!RC[-10]=SOCT!R1C5,DATA!RC[1],"""")"
.Offset(, 10).Value = "=IF(DATA!RC[-11]=SOCT!R1C5,DATA!RC[1],"""")"
.Offset(, 11).Value = "=IF(DATA!RC[-12]=SOCT!R1C5,DATA!RC[1],"""")"
With .Offset(, 0).Resize(, 12): .Value = .Value: End With
Dim eRw As Long, jJ As Byte: Dim WF, Cls As Range
eRw = [B1000].End(xlUp).Row
For Each Cls In [C12].Resize(eRw)
If WF.CountIf(Cls.Resize(, 4), "<>0") = 0 Then
Cls.EntireRow.Hidden = True
Next Cls
File ví dụ đưa lên nên bỏ bớt những phần link, chỉ đưa sát yêu cầu, file khá lớn nên làm biếng.A/C viết dùm em code lọc dữ liệu cho nút Combo này nhé! Câu hỏi cụ thể trong file đính kèm.
Sub TimMa()
Dim endR As Long, i As Long, s As Long, k As Long
Dim Arr(), ArrKQ(1 To 1000, 1 To 12)
Dim SLnhap, SLxuat, STnhap, STxuat
Dim MaHH As String
With Sheets("Data")
endR = .Cells(65000, 1).End(xlUp).Row
Arr = .Range("A12:M" & endR).Value
With Sheets("SoCT")
MaHH = .[E1]
s = 0
For i = 1 To UBound(Arr)
If Arr(i, 1) = MaHH Then
s = s + 1
For k = 1 To 10
ArrKQ(s, k) = Arr(i, k + 1)
Next k
SLnhap = SLnhap + ArrKQ(s, 7)
SLxuat = SLxuat + ArrKQ(s, 9)
STnhap = STnhap + ArrKQ(s, 8)
STxuat = STxuat + ArrKQ(s, 10)
ArrKQ(s, 11) = Sheets("SoCT").Range("K11") + SLnhap - SLxuat
ArrKQ(s, 12) = Sheets("SoCT").Range("L11") + STnhap - STxuat
If s = 0 Then Exit Sub
With Sheets("SoCT")
endR = .Cells(65000, 1).End(xlUp).Row + 2
With .Range("A" & endR)
.Resize(s, 12) = ArrKQ
Erase Arr(), ArrKQ
Bạn dùng code sau, thay vì dùng AdFi với E1 tôi dùng Array.
Bạn có thể dùng Worksheet_Change để chạy code.PHP:Sub TimMa() Dim endR As Long, i As Long, s As Long, k As Long Dim Arr(), ArrKQ(1 To 1000, 1 To 12) Dim SLnhap, SLxuat, STnhap, STxuat Dim MaHH As String With Sheets("Data") endR = .Cells(65000, 1).End(xlUp).Row Arr = .Range("A12:M" & endR).Value End With With Sheets("SoCT") MaHH = .[E1] End With s = 0 For i = 1 To UBound(Arr) If Arr(i, 1) = MaHH Then s = s + 1 For k = 1 To 10 ArrKQ(s, k) = Arr(i, k + 1) Next k SLnhap = SLnhap + ArrKQ(s, 7) SLxuat = SLxuat + ArrKQ(s, 9) STnhap = STnhap + ArrKQ(s, 8) STxuat = STxuat + ArrKQ(s, 10) ArrKQ(s, 11) = Sheets("SoCT").Range("K11") + SLnhap - SLxuat ArrKQ(s, 12) = Sheets("SoCT").Range("L11") + STnhap - STxuat End If Next i If s = 0 Then Exit Sub With Sheets("SoCT") endR = .Cells(65000, 1).End(xlUp).Row + 2 With .Range("A" & endR) .Resize(s, 12) = ArrKQ End With End With Erase Arr(), ArrKQ End Sub
Lộn xộn thế nào, xin cho cụ thể "lộn xộn".Anh ơi, em làm theo cách của anh rồi nhưng vẫn không được. Nó cập nhật lôn xộn lắm. Anh kiểm tra lại dùm em nhé!
Dim Cll1, Cll2 As Range, d1
Set Cll1 = Sheet2.[a12]
Set Cll2 = Sheet3.[a12]
d1 = Sheet3.[a65536].End(xlUp).Row
Sheet3.Range("a12:L" & IIf(d1 > 11, d1, 11)).ClearContents
Do While Trim(Cll1) <> ""
If Cll1 = Me.ComboBox1 Then
Cll2.Resize(, 10).Value = Cll1.Offset(, 1).Resize(, 10).Value
Cll2.Offset(, 10) = Cll2.Offset(-1, 10) + Cll2.Offset(, 6) - Cll2.Offset(, 8)
Cll2.Offset(, 11) = Cll2.Offset(-1, 11) + Cll2.Offset(, 7) - Cll2.Offset(, 9)
Set Cll2 = Cll2.Offset(1)
Set Cll1 = Cll1.Offset(1)
Loop
