Chương trình chia sẻ CSDL qua Internet (6 người xem)
Mình có 1 đoạn code nhúng vào SQL để bảo mật rất tốt viếc = C++ . bạn thử xem
/* ODBCSQL: a sample program that implements an ODBC command line interpreter.
/* USAGE:   ODBCSQL DSN=<dsn name>   or
/*          ODBCSQL FILEDSN=<file dsn> or
/*          ODBCSQL DRIVER={driver name}
/* Copyright(c) Microsoft Corporation.   This is a WDAC sample program and
/* is not suitable for use in production environments.
/* Modules:
/*      Main                Main driver loop, executes queries.
/*      DisplayResults      Display the results of the query if any
/*      AllocateBindings    Bind column data
/*      DisplayTitles       Print column titles
/*      SetConsole          Set console display mode
/*      HandleError         Show ODBC error messages
#include <windows.h>
#include <sql.h>
#include <sqlext.h>
#include <stdio.h>
#include <conio.h>
#include <tchar.h>
#include <stdlib.h>
#include <sal.h>
/* Macro to call ODBC functions and        */
/* report an error on failure.             */
/* Takes handle, handle type, and stmt     */
#define TRYODBC(h, ht, x)   {   RETCODE rc = x;\
                                if (rc != SQL_SUCCESS) \
                                    HandleDiagnosticRecord (h, ht, rc); \
                                if (rc == SQL_ERROR) \
                                    fwprintf(stderr, L"Error in " L#x L"\n"); \
                                    goto Exit;  \
/* Structure to store information about   */
/* a column.
typedef struct STR_BINDING {
    SQLSMALLINT         cDisplaySize;           /* size to display  */
    WCHAR               *wszBuffer;             /* display buffer   */
    SQLLEN              indPtr;                 /* size or null     */
    BOOL                fChar;                  /* character col?   */
    struct STR_BINDING  *sNext;                 /* linked list      */
} BINDING;
/* Forward references                     */
void HandleDiagnosticRecord (SQLHANDLE      hHandle,
                 SQLSMALLINT    hType,
                 RETCODE        RetCode);
void DisplayResults(HSTMT       hStmt,
                    SQLSMALLINT cCols);
void AllocateBindings(HSTMT         hStmt,
                      SQLSMALLINT   cCols,
                      BINDING**     ppBinding,
                      SQLSMALLINT*  pDisplay);
void DisplayTitles(HSTMT    hStmt,
                   DWORD    cDisplaySize,
                   BINDING* pBinding);
void SetConsole(DWORD   cDisplaySize,
                BOOL    fInvert);
/* Some constants                        */
#define DISPLAY_MAX 50          // Arbitrary limit on column width to display
#define DISPLAY_FORMAT_EXTRA 3  // Per column extra display bytes (| <data> )
#define DISPLAY_FORMAT      L"%c %*.*s "
#define DISPLAY_FORMAT_C    L"%c %-*.*s "
#define NULL_SIZE           6   // <NULL>
#define SQL_QUERY_SIZE      1000 // Max. Num characters for SQL Query passed in.
#define PIPE                L'|'
SHORT   gHeight = 80;       // Users screen height
int __cdecl wmain(int argc, _In_reads_(argc) WCHAR **argv)
    SQLHENV     hEnv = NULL;
    SQLHDBC     hDbc = NULL;
    SQLHSTMT    hStmt = NULL;
    WCHAR*      pwszConnStr;
    WCHAR       wszInput[SQL_QUERY_SIZE];
    // Allocate an environment
    if (SQLAllocHandle(SQL_HANDLE_ENV, SQL_NULL_HANDLE, &hEnv) == SQL_ERROR)
        fwprintf(stderr, L"Unable to allocate an environment handle\n");
        exit(-1);
    // Register this as an application that expects 3.x behavior,
    // you must register something if you use AllocHandle
    TRYODBC(hEnv,
            SQL_HANDLE_ENV,
            SQLSetEnvAttr(hEnv,
                SQL_ATTR_ODBC_VERSION,
                (SQLPOINTER)SQL_OV_ODBC3,
                0));
    // Allocate a connection
    TRYODBC(hEnv,
            SQL_HANDLE_ENV,
            SQLAllocHandle(SQL_HANDLE_DBC, hEnv, &hDbc));
    if (argc > 1)
        pwszConnStr = *++argv;
    else
        pwszConnStr = L"";
    // Connect to the driver.  Use the connection string if supplied
    // on the input, otherwise let the driver manager prompt for input.
    TRYODBC(hDbc,
        SQL_HANDLE_DBC,
        SQLDriverConnect(hDbc,
                         GetDesktopWindow(),
                         pwszConnStr,
                         SQL_NTS,
                         NULL,
                         0,
                         NULL,
                         SQL_DRIVER_COMPLETE));
    fwprintf(stderr, L"Connected!\n");
    TRYODBC(hDbc,
            SQL_HANDLE_DBC,
            SQLAllocHandle(SQL_HANDLE_STMT, hDbc, &hStmt));
    wprintf(L"Enter SQL commands, type (control)Z to exit\nSQL COMMAND>");
    // Loop to get input and execute queries
    while(_fgetts(wszInput, SQL_QUERY_SIZE-1, stdin))
        RETCODE     RetCode;
        SQLSMALLINT sNumResults;
        // Execute the query
        if (!(*wszInput))
            wprintf(L"SQL COMMAND>");
            continue;
        RetCode = SQLExecDirect(hStmt,wszInput, SQL_NTS);
        switch(RetCode)
        case SQL_SUCCESS_WITH_INFO:
                HandleDiagnosticRecord(hStmt, SQL_HANDLE_STMT, RetCode);
                // fall through
        case SQL_SUCCESS:
                // If this is a row-returning query, display
                // results
                TRYODBC(hStmt,
                        SQL_HANDLE_STMT,
                        SQLNumResultCols(hStmt,&sNumResults));
                if (sNumResults > 0)
                    DisplayResults(hStmt,sNumResults);
                else
                    SQLLEN cRowCount;
                    TRYODBC(hStmt,
                        SQL_HANDLE_STMT,
                        SQLRowCount(hStmt,&cRowCount));
                    if (cRowCount >= 0)
                        wprintf(L"%Id %s affected\n",
                                 cRowCount,
                                 cRowCount == 1 ? L"row" : L"rows");
                break;
        case SQL_ERROR:
                break;
        default:
            fwprintf(stderr, L"Unexpected return code %hd!\n", RetCode);
        TRYODBC(hStmt,
                SQL_HANDLE_STMT,
                SQLFreeStmt(hStmt, SQL_CLOSE));
Exit:
    // Free ODBC handles and exit
    if (hStmt)
        SQLFreeHandle(SQL_HANDLE_STMT, hStmt);
    if (hDbc)
        SQLDisconnect(hDbc);
        SQLFreeHandle(SQL_HANDLE_DBC, hDbc);
    if (hEnv)
        SQLFreeHandle(SQL_HANDLE_ENV, hEnv);
    wprintf(L"\nDisconnected.");
    return 0;
/* DisplayResults: display results of a select query
/* Parameters:
/*      hStmt      ODBC statement handle
/*      cCols      Count of columns
                    SQLSMALLINT cCols)
    BINDING         *pFirstBinding, *pThisBinding;
    RETCODE         RetCode = SQL_SUCCESS;
    int             iCount = 0;
    // Allocate memory for each column
    AllocateBindings(hStmt, cCols, &pFirstBinding, &cDisplaySize);
    // Set the display mode and write the titles
    DisplayTitles(hStmt, cDisplaySize+1, pFirstBinding);
    // Fetch and display the data
    bool fNoData = false;
    do {
        // Fetch a row
        if (iCount++ >= gHeight - 2)
            int     nInputChar;
            bool    fEnterReceived = false;
            while(!fEnterReceived)
                wprintf(L"              ");
                SetConsole(cDisplaySize+2, TRUE);
                wprintf(L"   Press ENTER to continue, Q to quit (height:%hd)", gHeight);
                SetConsole(cDisplaySize+2, FALSE);
                nInputChar = _getch();
                wprintf(L"\n");
                if ((nInputChar == 'Q') || (nInputChar == 'q'))
                    goto Exit;
                else if ('\r' == nInputChar)
                    fEnterReceived = true;
                // else loop back to display prompt again
            iCount = 1;
        TRYODBC(hStmt, SQL_HANDLE_STMT, RetCode = SQLFetch(hStmt));
        if (RetCode == SQL_NO_DATA_FOUND)
            fNoData = true;
        else
            // Display the data.   Ignore truncations
            for (pThisBinding = pFirstBinding;
                pThisBinding;
                pThisBinding = pThisBinding->sNext)
                if (pThisBinding->indPtr != SQL_NULL_DATA)
                    wprintf(pThisBinding->fChar ? DISPLAY_FORMAT_C:DISPLAY_FORMAT,
                        PIPE,
                        pThisBinding->cDisplaySize,
                        pThisBinding->wszBuffer);
                else
                    wprintf(DISPLAY_FORMAT_C,
                        PIPE,
                        L"<NULL>");
            wprintf(L" %c\n",PIPE);
    } while (!fNoData);
    wprintf(L"%*.*s", cDisplaySize+2, cDisplaySize+2, L" ");
    wprintf(L"\n");
Exit:
    // Clean up the allocated buffers
    while (pFirstBinding)
        pThisBinding = pFirstBinding->sNext;
        free(pFirstBinding->wszBuffer);
        free(pFirstBinding);
        pFirstBinding = pThisBinding;
/* AllocateBindings:  Get column information and allocate bindings
/* for each column.
/* Parameters:
/*      hStmt      Statement handle
/*      cCols       Number of columns in the result set
/*      *lppBinding Binding pointer (returned)
/*      lpDisplay   Display size of one line
                      SQLSMALLINT   cCols,
                      BINDING       **ppBinding,
                      SQLSMALLINT   *pDisplay)
    SQLSMALLINT     iCol;
    BINDING         *pThisBinding, *pLastBinding = NULL;
    SQLLEN          cchDisplay, ssType;
    SQLSMALLINT     cchColumnNameLength;
    *pDisplay = 0;
    for (iCol = 1; iCol <= cCols; iCol++)
        pThisBinding = (BINDING *)(malloc(sizeof(BINDING)));
        if (!(pThisBinding))
            fwprintf(stderr, L"Out of memory!\n");
            exit(-100);
        if (iCol == 1)
            *ppBinding = pThisBinding;
        else
            pLastBinding->sNext = pThisBinding;
        pLastBinding = pThisBinding;
        // Figure out the display length of the column (we will
        // bind to char since we are only displaying data, in general
        // you should bind to the appropriate C type if you are going
        // to manipulate data since it is much faster...)
        TRYODBC(hStmt,
                SQL_HANDLE_STMT,
                SQLColAttribute(hStmt,
                    iCol,
                    SQL_DESC_DISPLAY_SIZE,
                    NULL,
                    0,
                    NULL,
                    &cchDisplay));
        // Figure out if this is a character or numeric column; this is
        // used to determine if we want to display the data left- or right-
        // aligned.
        // SQL_DESC_CONCISE_TYPE maps to the 1.x SQL_COLUMN_TYPE.
        // This is what you must use if you want to work
        // against a 2.x driver.
        TRYODBC(hStmt,
                SQL_HANDLE_STMT,
                    iCol,
                    SQL_DESC_CONCISE_TYPE,
                    NULL,
                    0,
                    NULL,
                    &ssType));
        pThisBinding->fChar = (ssType == SQL_CHAR ||
                                ssType == SQL_VARCHAR ||
                                ssType == SQL_LONGVARCHAR);
        pThisBinding->sNext = NULL;
        // Arbitrary limit on display size
        if (cchDisplay > DISPLAY_MAX)
            cchDisplay = DISPLAY_MAX;
        // Allocate a buffer big enough to hold the text representation
        // of the data.  Add one character for the null terminator
        pThisBinding->wszBuffer = (WCHAR *)malloc((cchDisplay+1) * sizeof(WCHAR));
        if (!(pThisBinding->wszBuffer))
            exit(-100);
        // Map this buffer to the driver's buffer.   At Fetch time,
        // the driver will fill in this data.  Note that the size is
        // count of bytes (for Unicode).  All ODBC functions that take
        // SQLPOINTER use count of bytes; all functions that take only
        // strings use count of characters.
        TRYODBC(hStmt,
                SQL_HANDLE_STMT,
                SQLBindCol(hStmt,
                    iCol,
                    SQL_C_TCHAR,
                    (SQLPOINTER) pThisBinding->wszBuffer,
                    (cchDisplay + 1) * sizeof(WCHAR),
                    &pThisBinding->indPtr));
        // Now set the display size that we will use to display
        // the data.   Figure out the length of the column name
        TRYODBC(hStmt,
                SQL_HANDLE_STMT,
                    iCol,
                    SQL_DESC_NAME,
                    NULL,
                    0,
                    &cchColumnNameLength,
                    NULL));
        pThisBinding->cDisplaySize = max((SQLSMALLINT)cchDisplay, cchColumnNameLength);
        if (pThisBinding->cDisplaySize < NULL_SIZE)
            pThisBinding->cDisplaySize = NULL_SIZE;
        *pDisplay += pThisBinding->cDisplaySize + DISPLAY_FORMAT_EXTRA;
    return;
Exit:
    exit(-1);
    return;
/* DisplayTitles: print the titles of all the columns and set the
/*                shell window's width
/* Parameters:
/*      cDisplaySize   Total display size
/*      pBinding        list of binding information
                   DWORD     cDisplaySize,
                   BINDING   *pBinding)
    WCHAR           wszTitle[DISPLAY_MAX];
    SQLSMALLINT     iCol = 1;
    for (; pBinding; pBinding = pBinding->sNext)
        TRYODBC(hStmt,
                SQL_HANDLE_STMT,
                    iCol++,
                    SQL_DESC_NAME,
                    wszTitle,
                    sizeof(wszTitle), // Note count of bytes!
                    NULL,
                    NULL));
                 PIPE,
                 pBinding->cDisplaySize,
                 wszTitle);
Exit:
    wprintf(L" %c", PIPE);
    wprintf(L"\n");
/* SetConsole: sets console display size and video mode
/*  Parameters
/*      siDisplaySize   Console display size
/*      fInvert         Invert video?
void SetConsole(DWORD dwDisplaySize,
                BOOL  fInvert)
    HANDLE                          hConsole;
    CONSOLE_SCREEN_BUFFER_INFO      csbInfo;
    // Reset the console screen buffer size if necessary
    hConsole = GetStdHandle(STD_OUTPUT_HANDLE);
    if (hConsole != INVALID_HANDLE_VALUE)
        if (GetConsoleScreenBufferInfo(hConsole, &csbInfo))
            if (csbInfo.dwSize.X <  (SHORT) dwDisplaySize)
                csbInfo.dwSize.X =  (SHORT) dwDisplaySize;
                SetConsoleScreenBufferSize(hConsole, csbInfo.dwSize);
            gHeight = csbInfo.dwSize.Y;
        if (fInvert)
            SetConsoleTextAttribute(hConsole, (WORD)(csbInfo.wAttributes | BACKGROUND_BLUE));
        else
            SetConsoleTextAttribute(hConsole, (WORD)(csbInfo.wAttributes & ~(BACKGROUND_BLUE)));
/* HandleDiagnosticRecord : display error/warning information
/* Parameters:
/*      hHandle     ODBC handle
/*      hType       Type of handle (HANDLE_STMT, HANDLE_ENV, HANDLE_DBC)
/*      RetCode     Return code of failing command
                             SQLSMALLINT    hType,
                             RETCODE        RetCode)
    SQLSMALLINT iRec = 0;
    SQLINTEGER  iError;
    WCHAR       wszMessage[1000];
    WCHAR       wszState[SQL_SQLSTATE_SIZE+1];
    if (RetCode == SQL_INVALID_HANDLE)
        fwprintf(stderr, L"Invalid handle!\n");
        return;
    while (SQLGetDiagRec(hType,
                         hHandle,
                         ++iRec,
                         wszState,
                         &iError,
                         wszMessage,
                         (SQLSMALLINT)(sizeof(wszMessage) / sizeof(WCHAR)),
                         (SQLSMALLINT *)NULL) == SQL_SUCCESS)
        // Hide data truncated..
        if (wcsncmp(wszState, L"01004", 5))
            fwprintf(stderr, L"[%5.5s] %s (%d)\n", wszState, wszMessage, iError);
Ý mình bạn có thể nói sơ về cách thức tấn công á
65 tuổi mà giỏi vậy đó hả, post bài liên tục, cái này phả gọi là ông già gân quá hihihih
Sao thấy cái cách bạn nói chuyện thấy quen quen sao ý
Tôi thấy cũng ngờ ngợ, nhưng thôi biết cái gì hỗ trợ lẫn nhau là được rồi.
Ông/Bà xưa thường nói "Đánh kẻ chạy đi chứ ai đánh người chạy lại".
Quan điểm của tôi thì rất rõ ràng: Nếu thành viên nào tôi không thích hoặc họ đôi co thái quá tôi cho vào "Danh sách đen" để khỏi đọc bài của họ.
Tôi luôn nhớ câu nói của Ông/Bà xưa là "Một câu nhịn chín câu lành", nhẫn nhịn là điều tốt nhất ta sẽ không gây mất lòng cho ai cũng như không tạo sự ghen ghét cho ai và sẽ đem lại sự hài hòa cho mọi người.
Mình năm nay gần 70 tuổi rồi. Luôn ăn nói lịch sự. Mình mong muốn đem hết kiến thức mình giúp cho cộng đồng. Tôi yêu GPE. GPE là ngôi nhà của tôi
Cỡ đó thì cũng tương đương tuổi tôi thôi.
Bài 32 tôi dùng từ nào mà bạn cho là không lịch sự, tôi dùng từ ngờ ngợ có nghĩa là nghi ngờ, chứ có chỉ đích danh một người nào đó đâu.
Cập nhật bài mới để các bạn theo dõi Dowload và Comment
Xem video thì nó là cái Sever + Client + *.accdb đó chứ ??!!
Danh sách đăng ký dự thi Hội thi Giáo viên giỏi ứng dụng CNTT trong công tác giảng dạy tỉnh Đồng Nai lần thứ 4 năm 2013
4 Nguyễn Thị Thanh Thủy 1981 Nữ Trường Mầm non Ánh Dương thị xã Long Khánh, tỉnh Đồng Nai Mầm non
Cô giáo mầm non mà giỏi nhỉ,ối anh theo không kịp đó, kkk :D
Eccc sao anh không đưa đoạt giải lên luôn đi ghê thật.
Lâu rồi mới thấy anh xuất hiện hihihi
Là nữ, cô giáo mầm non nữa, trái ngành nghề mà được như vậy là rất giỏi đó bé.
dù không hiểu nội dung topic này nhưng mà nể cô giáo mầm non quá trời quá đất, thiệt là không thể ngờ luôn đó cô ơi.
Ở GPE có mấy thành phần chuyên soi mói hoạnh hoẹ đủ thứ (mức độ phải cỡ vạch lá soi ra virus luôn) thế mà cái này của chị Thủy không thấy ý kiến ý cò gì chứng tỏ công phu chị Thủy đáng kinh ngạc thật. :1a:
Cạn lời với bạn.
Mà sao cách nói chuyện thấy quen giống ai nhỉ :rolleyes:
Cạn lời với bạn.
Có câu "Thấy sang bắt quàng làm họ", tôi chuyên móc c...t, thông cống (100% thật) thì đừng có nhận quen nha kẻo thúi lây.
Nhân tiện GPE có đồng môn ngành bới móc cống (hổng phải bới móc linh tinh nha) thì giơ tay giao lưu biết đau học hỏi kinh nghiệm :whistling:
Xin lỗi "Thấy sang bắt quàng làm họ" bạn đang ngái ngũ hả.
Bạn muốn bới móc hay móc cống cứ nói thẳng trực tiếp ý của bạn đó là quyền của bạn chứ đừng nói kiểu đó
192.168.x.x cái IP là cái IP mạng nội bộ, không phải IP Publib, muốn dùng IP Publib phải mở port nha. Chưa có mở port mà đòi chia sẽ qua internet
