[HỎI] Lỗi truy vấn trên Excel ADO khi dùng query UNION với Database là Access Table (3 người xem)
khanhhero
Xin chào mọi người,
Hiện tại em đang sử dụng access để làm database, em dùng ADO để truy vấn dữ liệu từ access về. Em đang gặp lỗi Error Method Open Recordset khi sử dụng câu truy vấn có chứa UNION.
Liệu ADO có cho phép sử dụng câu query đó không ạ? Nhờ mọi người xem thử giúp em với ạ.
Em cám ơn mọi người!
Sub R_FOLIO_SUMMARY()
Sheet4.Range("A7:L1000000").ClearContents
Dim cnn As ADODB.Connection
Set cnn = New ADODB.Connection
Dim rs As New ADODB.Recordset
Dim strcnn As String
Dim sqlstr As String
Dim lr As Long
FrP = Sheet10.Range("E12").Value
ToP = Sheet10.Range("E13").Value
strcnn = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=" & ThisWorkbook.Path & "\REV_DATABASE.accdb;" & "Jet OLEDB:Database Password = "
cnn.Open strcnn
     sqlstr = "SELECT Sum(A.RevAmt), Sum(A.SvcAmt), Sum(A.ScTAmt), Sum(A.TaxAmt), Sum(A.TipAmt), Sum(A.PaidAmt), A.Conf_No, A.Room_No, A.Arrival_Date, A.Departure_Date" & _
              " FROM " & _
                " (SELECT Trans_Amount as RevAmt, 0 as SvcAmt, 0 as ScTAmt, 0 as TaxAmt, 0 as TipAmt, 0 as PaidAmt, Conf_No, Room_No, Arrival_Date, Departure_Date" & _
                           " FROM FOLIO_DETAIL WHERE LEFT(Acc_Code, 4) = '5113'" & _
                 " UNION ALL SELECT 0 as RevAmt, Trans_Amount as SvcAmt, 0 as ScTAmt, 0 as TaxAmt, 0 as TipAmt, 0 as PaidAmt, Conf_No, Room_No, Arrival_Date, Departure_Date" & _
                           " FROM FOLIO_DETAIL WHERE LEFT(Acc_Code, 4) = '5114'" & _
                 " UNION ALL SELECT 0 as RevAmt, 0 as SvcAmt, Trans_Amount as ScTAmt, 0 as TaxAmt, 0 as TipAmt, 0 as PaidAmt, Conf_No, Room_No, Arrival_Date, Departure_Date" & _
                           " FROM FOLIO_DETAIL WHERE LEFT(Acc_Code, 4) = '3332'" & _
                 " UNION ALL SELECT 0 as RevAmt, 0 as SvcAmt, 0 as ScTAmt, Trans_Amount as ScTAmt, 0 as TipAmt, 0 as PaidAmt, Conf_No, Room_No, Arrival_Date, Departure_Date" & _
                           " FROM FOLIO_DETAIL WHERE LEFT(Acc_Code, 4) = '3331'" & _
                 " UNION ALL SELECT 0 as RevAmt, 0 as SvcAmt, 0 as ScTAmt, 0 as ScTAmt, Trans_Amount as TipAmt, 0 as PaidAmt, Conf_No, Room_No, Arrival_Date, Departure_Date" & _
                           " FROM FOLIO_DETAIL WHERE LEFT(Acc_Code, 3) = '338'" & _
                 " UNION ALL SELECT 0 as RevAmt, 0 as SvcAmt, 0 as ScTAmt, 0 as ScTAmt, 0 as TipAmt, Trans_Amount as PaidAmt, Conf_No, Room_No, Arrival_Date, Departure_Date" & _
                           " FROM FOLIO_DETAIL WHERE CAST(LEFT(Folio_Trans, 1) as INT) >= 8) as A" & _
             " GROUP BY A.Conf_No, A.Room_No, A.Arrival_Date, A.Departure_Date"
   rs.Open sqlstr, strcnn
    Sheet4.Range("A7").CopyFromRecordset rs
   rs.Close
cnn.Close
Set rs = Nothing
Set cnn = Nothing
Xin chào mọi người,
Dim lr As Long
cnn.Open strcnn
              " FROM " & _
   rs.Close
cnn.Close
Set rs = Nothing
Set cnn = Nothing
Trong Excel ADO có thể dùng câu lệnh Union Query nhé bạn.
chuỗi kết nối hình như có vấn đề, bạn check lại đúng không?
Em gửi mọi người xem giúp em ạ.
Mình check rồi mà không tìm ra được lỗi chỗ nào nữa bạn ah.
Đúng thật có lẽ do lỗi câu truy vấn, mình test thử 2 cột thì chạy.
Bên trên : cnn.Open strcnn
Phía dưới : rs.Open sqlstr, strcnn
Xem lại cái này
Chuối strSQL bị sai đó.
Số lượng cột không tương đồng giữa các Union, trùng lắp tên SctAmt ....
3 cái Union cuối.
À mà hàm CAST () trong Access không có nhé. Đổi qua CINT(), CLng() gì đó.
