wkiz
Xin chào anh/chị,
Em mới học excel vba có 1 đoạn Macro như bên dưới. Vấn đề của em là, nếu em đặt tên sheet là "test" thì đoạn code chạy bình thường, nhưng nếu sửa tên sheet đó khác đi thì sẽ ko chạy đc.
Em xin cảm ơn.
Sub taobangchuan()
' taobangchuan Macro
Columns("A:A").Select
Selection.ClearContents
Range("A1").Select
ActiveCell.FormulaR1C1 = "STT"
Columns("E:G").Select
Selection.Delete Shift:=xlToLeft
Columns("F:F").Select
Columns("G:R").Select
Columns("H:BB").Select
Columns("B:B").Select
ActiveWorkbook.Worksheets("test").Sort.SortFields.Clear
ActiveWorkbook.Worksheets("test").Sort.SortFields.Add Key:=Range("B1"), _
SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
With ActiveWorkbook.Worksheets("test").Sort
.SetRange Range("A2:G50")
.Header = xlNo
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
Range("B1").Select
ActiveCell.FormulaR1C1 = "GDV"
Range("C1").Select
ActiveCell.FormulaR1C1 = "Mã Khách Hàng"
Range("D1").Select
ActiveCell.FormulaR1C1 = "Sô H?p Ð?ng"
Range("E1").Select
ActiveCell.FormulaR1C1 = "Ngày Vay"
Range("F1").Select
ActiveCell.FormulaR1C1 = "Du N?"
Range("G1").Select
ActiveCell.FormulaR1C1 = "Tên Khách Hàng"
Cells.Select
With Selection.Font
.Name = "Arial"
.Size = 15
.Strikethrough = False
.Superscript = False
.Subscript = False
.OutlineFont = False
.Shadow = False
.Underline = xlUnderlineStyleNone
.ColorIndex = xlAutomatic
.TintAndShade = 0
.ThemeFont = xlThemeFontNone
Cells.EntireColumn.AutoFit
Selection.Style = "Comma"
Selection.NumberFormat = "_(* #,##0.0_);_(* (#,##0.0);_(* ""-""??_);_(@_)"
Selection.NumberFormat = "_(* #,##0_);_(* (#,##0);_(* ""-""??_);_(@_)"
Range("A2").Select
ActiveCell.FormulaR1C1 = "1"
Range("A3").Select
ActiveCell.FormulaR1C1 = "2"
Range("A2:A3").Select
Selection.AutoFill Destination:=Range("A2:A50"), Type:=xlFillDefault
Range("A2:A50").Select
Columns("E:E").Select
Selection.NumberFormat = "dd/mm/yyyy"
Selection.Cut
Columns("H:H").Select
Selection.Insert Shift:=xlToRight
Range("A1").Select
Em xin cảm ơn.
