Thanhlam2425
Mọi ngời cho em hỏi lỗi này là bị Như thế nào ạ.
Sub capnhaphanghoa()
Dim cn As Object
Dim rst As Object, sql As String
Dim Pro As String, lr As Long, arr3(), ten As String, i As Long, dk As String, k As Integer
Dim Ext As String
Dim Name As String
Dim s1 As String, s2 As String
s1 = "NGHI" & ChrW(7878) & "P V" & ChrW(7908)
s2 = "xu" & ChrW(7845) & "t " & ChrW(273) & "i" & ChrW(7873) & "u chuy" & ChrW(7875) & "n"
With Sheets("DT-DC")
lr = .Range("a" & Rows.Count).End(xlUp).Row
If lr > 7 Then .Range("A8:R" & lr).ClearContents
arr3 = Array("210", "230", "250", "280", "289", "290", "293", "275")
Set cn = CreateObject("ADODB.connection")
Set rst = CreateObject("ADODB.recordset")
For k = 0 To UBound(arr3)
lr = .Range("a" & Rows.Count).End(xlUp).Row + 1
Name = "C:\BUILDSTOREPROJEC\ACCOUNT\BAR LIST\" & arr3(k) & ".xlsx"
Pro = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source="
Ext = ";Extended Properties=""Excel 12.0;HDR=No;"";"
cn.Open (Pro & Name & Ext)
sql = "SELECT *from [DATA$A7:R100000] WHERE F5='a'" '" & "'" & s2 & "'"
rst.Open sql, cn, 3, 1
Sheets("DT-DC").Range("A" & lr).CopyFromRecordset rst
rst.Close
cn.Close
Next k
