Giúp code lọc dữ liệu siêu tốc khoảng 10.000 dòng (5 người xem)
minhtuan55
Chào cả nhà GPE!
Em đang cần làm 1 đoạn code để lọc dữ liệu khoảng 10.000 dòng trở xuống ( code khi đánh vài ký tự liên quan trong Textbox thì Listbox sẽ hiện ra kết quả ( Trong Form)). Hiện em đang dùng code cũng ở trên diễn đàn
Nhưng nó xứ lý chỉ được 500 dòng là OK mà 10.000 dòng thì như rùa bò luôn. Mong các cao thủ giúp em. XIn chân thành cảm ơn !
Sub locnhapkhonewa()
Dim dl(), i As Long
dl = Sheets("khachhang").Range("K4:K5003").Value 'lay nguon hang hoa
THANHTOAN.ListBox1.Clear
For i = 1 To UBound(dl)
   If dl(i, 1) <> "" Then
      If TV(UCase(dl(i, 1))) Like "*" & TV(UCase(THANHTOAN.TextBox1.Value)) & "*" Then ' dieu kien loc Bo dau tieng viet Chu hoa chu thuong
         THANHTOAN.ListBox1.AddItem dl(i, 1)
Function TV(ByVal Text As String) As String ' bo dau tieng viet
  Dim CharCode, ResText As String, i As Long, tmp As String
  tmp = Text
  CharCode = Array(ChrW(7855), ChrW(7857), ChrW(7859), ChrW(7861), ChrW(7863), ChrW(7845), ChrW(7847), _
                   ChrW(7849), ChrW(7851), ChrW(7853), ChrW(225), ChrW(224), ChrW(7843), ChrW(227), ChrW(7841), _
                   ChrW(259), ChrW(226), ChrW(273), ChrW(7871), ChrW(7873), ChrW(7875), ChrW(7877), ChrW(7879), _
                   ChrW(233), ChrW(232), ChrW(7867), ChrW(7869), ChrW(7865), ChrW(234), ChrW(237), ChrW(236), _
                   ChrW(7881), ChrW(297), ChrW(7883), ChrW(7889), ChrW(7891), ChrW(7893), ChrW(7895), ChrW(7897), _
                   ChrW(7899), ChrW(7901), ChrW(7903), ChrW(7905), ChrW(7907), ChrW(243), ChrW(242), ChrW(7887), _
                   ChrW(245), ChrW(7885), ChrW(244), ChrW(417), ChrW(7913), ChrW(7915), ChrW(7917), ChrW(7919), _
                   ChrW(7921), ChrW(250), ChrW(249), ChrW(7911), ChrW(361), ChrW(7909), ChrW(432), ChrW(253), _
                   ChrW(7923), ChrW(7927), ChrW(7929), ChrW(7925))
  ResText = "aaaaaaaaaaaaaaaaadeeeeeeeeeeeiiiiiooooooooooooooooouuuuuuuuuuuyyyyy"
  For i = 0 To UBound(CharCode)
    tmp = Replace(tmp, CharCode(i), Mid(ResText, i + 1, 1))
    tmp = Replace(tmp, UCase(CharCode(i)), UCase(Mid(ResText, i + 1, 1)))
  TV = tmp
Private Sub TextBox1_Change()
locnhapkhonewa
Cảm ơn bác nhiều.Bác cho hỏi Muốn hiển thị thêm 1 cột nữa trong listbox phải chỉnh sao bác.Em có thêm ColumnCount nhưng nó lại hiện các cột mà bác đã loại bỏ dấu
textbox1.list=darr là lệnh đưa dữ liệu vào, khai báo darr 7 cột và list 7 cột
