Giúp code lọc dữ liệu siêu tốc khoảng 10.000 dòng (6 người xem)
minhtuan55
Chào cả nhà GPE!
Em đang cần làm 1 đoạn code để lọc dữ liệu khoảng 10.000 dòng trở xuống ( code khi đánh vài ký tự liên quan trong Textbox thì Listbox sẽ hiện ra kết quả ( Trong Form)). Hiện em đang dùng code cũng ở trên diễn đàn
Nhưng nó xứ lý chỉ được 500 dòng là OK mà 10.000 dòng thì như rùa bò luôn. Mong các cao thủ giúp em. XIn chân thành cảm ơn !
Sub locnhapkhonewa()
Dim dl(), i As Long
dl = Sheets("khachhang").Range("K4:K5003").Value 'lay nguon hang hoa
THANHTOAN.ListBox1.Clear
For i = 1 To UBound(dl)
   If dl(i, 1) <> "" Then
      If TV(UCase(dl(i, 1))) Like "*" & TV(UCase(THANHTOAN.TextBox1.Value)) & "*" Then ' dieu kien loc Bo dau tieng viet Chu hoa chu thuong
         THANHTOAN.ListBox1.AddItem dl(i, 1)
Function TV(ByVal Text As String) As String ' bo dau tieng viet
  Dim CharCode, ResText As String, i As Long, tmp As String
  tmp = Text
  CharCode = Array(ChrW(7855), ChrW(7857), ChrW(7859), ChrW(7861), ChrW(7863), ChrW(7845), ChrW(7847), _
                   ChrW(7849), ChrW(7851), ChrW(7853), ChrW(225), ChrW(224), ChrW(7843), ChrW(227), ChrW(7841), _
                   ChrW(259), ChrW(226), ChrW(273), ChrW(7871), ChrW(7873), ChrW(7875), ChrW(7877), ChrW(7879), _
                   ChrW(233), ChrW(232), ChrW(7867), ChrW(7869), ChrW(7865), ChrW(234), ChrW(237), ChrW(236), _
                   ChrW(7881), ChrW(297), ChrW(7883), ChrW(7889), ChrW(7891), ChrW(7893), ChrW(7895), ChrW(7897), _
                   ChrW(7899), ChrW(7901), ChrW(7903), ChrW(7905), ChrW(7907), ChrW(243), ChrW(242), ChrW(7887), _
                   ChrW(245), ChrW(7885), ChrW(244), ChrW(417), ChrW(7913), ChrW(7915), ChrW(7917), ChrW(7919), _
                   ChrW(7921), ChrW(250), ChrW(249), ChrW(7911), ChrW(361), ChrW(7909), ChrW(432), ChrW(253), _
                   ChrW(7923), ChrW(7927), ChrW(7929), ChrW(7925))
  ResText = "aaaaaaaaaaaaaaaaadeeeeeeeeeeeiiiiiooooooooooooooooouuuuuuuuuuuyyyyy"
  For i = 0 To UBound(CharCode)
    tmp = Replace(tmp, CharCode(i), Mid(ResText, i + 1, 1))
    tmp = Replace(tmp, UCase(CharCode(i)), UCase(Mid(ResText, i + 1, 1)))
  TV = tmp
Private Sub TextBox1_Change()
locnhapkhonewa
Tạo mảng dữ liệu không dấu khi form được gọi và khi lọc so sánh với dữ liệu này.
Ngoài ra ghi kết quả vào mảng sau đó gán vào listbox 1 lần (.List) có thể sẽ nhanh hơn AddItem từng kết quả.
Dạ em cảm ơn anh. Em chỉ biết Code sơ sơ thôi ak, Em toàn lấy code diễn dàn em thay địa chỉ đầu vào đầu ra thôi. Chứ em không biết viết. Mong anh giúp em. Chứ em không biết Mãng hay AddItem gì hết
Chào cả nhà GPE!
Dim dl(), i As Long
  tmp = Text
  TV = tmp
locnhapkhonewa
thử code
Dim dic As Object, Test As Boolean
Private Sub locnhapkhonewa()
Dim dl(), arr(), i As Long, dk As String, tmp As String
dk = Up_TV_KhongDau(UCase(TextBox1.Value))
ReDim arr(1 To 1)
ListBox1.Clear
      tmp = Up_TV_KhongDau(UCase(dl(i, 1)))
      If tmp Like "*" & dk & "*" Then ' dieu kien loc Bo dau tieng viet Chu hoa chu thuong
          ReDim Preserve arr(1 To k)
          arr(k) = tmp
ListBox1.List = arr
Private Function Up_TV_KhongDau(ByVal Text As String) As String ' bo dau tieng viet
  If Len(Text) = 0 Then Up_TV_KhongDau = "": Exit Function
  If Test = False Then
      dic.Add CharCode(i), Mid(ResText, i + 1, 1)
      dic.Add UCase(CharCode(i)), UCase(Mid(ResText, i + 1, 1))
    Test = True
  For i = 1 To Len(Text)
    Key = Mid(Text, i, 1)
    If dic.Exit(Key) Then Mid(Text, i, 1) = dic.Item(Key)
  Up_TV_KhongDau = Text
  locnhapkhonewa
Để tăng tốc code, tôi đề nghị tạo 1 biến chứa dữ liệu đã loại bỏ dấu tiếng Việt. Biến này là biến toàn cục và được load ngay khi mở file (Auto_Open) đồng thời cũng có thể được khởi tạo lại khi có thay đổi trên sheet (sự kiện Change)
Vậy chúng ta phải chấp nhận file bị chậm khi vừa mới khởi động (đương nhiên sau đó sẽ nhanh)
Toàn bộ code đề xuất:
1> Trong Module:
Public rngSrc As Range, aDes, bChk As Boolean
Sub Auto_Open()
  Dim aSrc
  Dim lR As Long
  Set rngSrc = Sheet1.Range("B4:B20000")
  aSrc = rngSrc.Value
  aDes = aSrc
  ReDim Preserve aDes(1 To UBound(aDes, 1), 1 To 2)
  For lR = 1 To UBound(aSrc, 1)
    aDes(lR, 2) = RemoveMarks(aDes(lR, 1))
Function RemoveMarks(ByVal Text As String) As String
  Dim CharCode, i As Long
  Dim ResText As String, sTmp As String
  sTmp = Text
  CharCode = Array(7855, 7857, 7859, 7861, 7863, 7845, 7847, 7849, 7851, 7853, 225, _
                   224, 7843, 227, 7841, 259, 226, 273, 7871, 7873, 7875, 7877, 7879, _
                   233, 232, 7867, 7869, 7865, 234, 237, 236, 7881, 297, 7883, 7889, _
                   7891, 7893, 7895, 7897, 7899, 7901, 7903, 7905, 7907, 243, 242, _
                   7887, 245, 7885, 244, 417, 7913, 7915, 7917, 7919, 7921, 250, _
                   249, 7911, 361, 7909, 432, 253, 7923, 7927, 7929, 7925)
    sTmp = Replace(sTmp, ChrW(CharCode(i)), Mid(ResText, i + 1, 1))
    sTmp = Replace(sTmp, UCase(ChrW(CharCode(i))), UCase(Mid(ResText, i + 1, 1)))
  RemoveMarks = sTmp
Function Filter2DArray(ByVal SourceArray, ByVal ColIndex As Long, ByVal FindStr As String, ByVal HasTitle As Boolean)
  Dim aTmpArr, i As Long, j As Long, arr, dic, TmpStr, Tmp, Chk As Boolean, TmpVal As Double
  aTmpArr = SourceArray
  ColIndex = ColIndex + LBound(aTmpArr, 2) - 1
  Chk = (InStr("><=", Left(FindStr, 1)) > 0)
  For i = LBound(aTmpArr, 1) - HasTitle To UBound(aTmpArr, 1)
    If Chk And FindStr <> "" Then
      TmpVal = CDbl(aTmpArr(i, ColIndex))
      If Evaluate(TmpVal & FindStr) Then dic.Add i, ""
      If Left(FindStr, 1) = "!" Then
        If Not (UCase(aTmpArr(i, ColIndex)) Like UCase(Mid(FindStr, 2, Len(FindStr)))) Then dic.Add i, ""
        If UCase(aTmpArr(i, ColIndex)) Like UCase(FindStr) Then dic.Add i, ""
  If dic.Count > 0 Then
    Tmp = dic.Keys
    ReDim arr(LBound(aTmpArr, 1) To UBound(Tmp) + LBound(aTmpArr, 1) - HasTitle, LBound(aTmpArr, 2) To UBound(aTmpArr, 2))
    For i = LBound(aTmpArr, 1) - HasTitle To UBound(Tmp) + LBound(aTmpArr, 1) - HasTitle
      For j = LBound(aTmpArr, 2) To UBound(aTmpArr, 2)
        arr(i, j) = aTmpArr(Tmp(i - LBound(aTmpArr, 1) + HasTitle), j)
    If HasTitle Then
        arr(LBound(aTmpArr, 1), j) = aTmpArr(LBound(aTmpArr, 1), j)
  Filter2DArray = arr
Sub fesrtg()
UserForm1.Show
2> Trong UserForm:
  Dim arr
  arr = Filter2DArray(aDes, 2, "*" & RemoveMarks(TextBox1.Text) & "*", False)
  If IsArray(arr) Then Me.ListBox1.List = arr
  If (rngSrc Is Nothing) Or bChk Then
    Auto_Open
    bChk = False
3> Trong sự kiện Change của sheet:
  If Not Intersect(Range("B4:B20000"), Target) Is Nothing Then bChk = True
Mời tham khảo file đính kèm
1> Trong Module:
Sub Auto_Open()
  Dim aSrc
  Dim lR As Long
  aSrc = rngSrc.Value
  aDes = aSrc
  sTmp = Text
  RemoveMarks = sTmp
    Tmp = dic.Keys
    If HasTitle Then
  Filter2DArray = arr
Sub fesrtg()
UserForm1.Show
2> Trong UserForm:
  Dim arr
    Auto_Open
    bChk = False
COde quá OK xin chân thành cảm ơn anh
Xem thử.
Lưu ý:
- Gõ ký tự bất kỳ thì nó sẽ tìm chữ đầu tiên bên trái.
- Muốn tìm bất kỳ thì gõ ký tự * (dấu Sao) rồi gõ từ muốn tìm kế tiếp.
Cảm ơn anh nhiều. Code rất OK tuy chậm 1 tí như vậy là ok rồi
Nếu cần nhanh hơn nữa, thì nên sử dụng ngôn ngữ lập trình khác (tạo file thực thi) thay vì VBA trong EXCEL
Mình xin được hỏi chủ bài đăng:
Thực chất trong file của bạn là cần "lọc" cái gì sau đây:
Lọc họ tên?
Lọc tên hàng hóa;
Lọc tên đầu sách?
Hay lọc cái gì khác nữa.
Hỏi như thế vì có khi bạn tạo bộ mã cho trường cần lọc thì sẽ là chuyện khác.
Chúc mọi người cuối tuần vui vẻ!
Tùy cái mới nhanh nhé. Vụ làm mảng trong VBA khá nhanh, đặc biệt cái listBox của VBA load data vào LIST cực nhanh. Bạn không thể làm nhanh hơn với ngôn ngữ khác so với kiểu làm VBA với cahs làm mảng. Nếu tôi sai thì bạn chứng minh xem.
Tôi thấy code đó là nhanh rồi đấy. Nếu có cái khác thì chỉ hơn không đáng kể đâu.
Về nguyên tắc, nhất là khi dữ liệu cực lớn, những cái gì cần làm 1 lần thì không đặt trong vòng lặp.
Tức thay cho
For i = 1 To UBound(x, 1)
                If LCase(x(i, 1)) Like LCase(TextBox1) & "*" Then
thì nên có
mask = LCase(TextBox1) & "*"
    If LCase(x(i, 1)) Like mask Then
"Lờ" nguyên tắc chỉ nên chấp nhận khi vòng lặp nhỏ.
Với dữ liệu nhiều (nhiều dòng thỏa) thì không nên dùng AddItem mà ghi vào mảng rồi nhập vào List (hoặc Column tùy theo mảng kia thế nào)
Đây chỉ là ý kiến chủ quan.
Tức thay cho
thì nên có
ĐÚng rồi anh. Mọi thứ phải giải quyết triệt để trước khi đưa vào vòng lặp. Code còn phải tỉa tót hơn nữa thì mới thực sự ngon, kể cả khi thêm nhiều điêu kiện.... Ý em nhanh ở đây là tổng thể - Chủ thớt không mong đợi quá tốt hơn được .
Chào Bác Ndu, theo file của Bác gửi cho em hỏi khi lọc ra List trên form mình cho con chỏ đến dòng đã chọn làm sao để gán vào 1 cell của 1 sheet hiện hành ạ.
Ngoctoan.
1> Trong Module:
Sub Auto_Open()
  Dim aSrc
  Dim lR As Long
  aSrc = rngSrc.Value
  aDes = aSrc
  sTmp = Text
  RemoveMarks = sTmp
    Tmp = dic.Keys
    If HasTitle Then
  Filter2DArray = arr
Sub fesrtg()
UserForm1.Show
2> Trong UserForm:
  Dim arr
    Auto_Open
    bChk = False
Công nhận với a là cái .list của listbox này nhanh thật , e thử dùng ado chuyển sang mảng rồi nạp vào .list và nâng dữ liệu lên hơn 60k dòng, tốc độ trên máy e là chấp nhận được CoreI5 2540M - 3GB ram dù vẫn màn hình hơi khựng lại chút xíu không đáng kể.
Đã test lại vẫn chậm hơn so với thầy NDU
Muốn nhanh thì dùng Dic kết hợp với mảng
Mình nhập từ 'Chá' thì hiện ra danh sách liệt kê;
Nhưng nhập nối tiếp thêm chữ 'o' thì danh sách trống trơn, là sao ta?
Rõ ràng trước đó trong danh sách hiển thị rất nhiều dòng có từ 'cháo' mà!
