Đố vui về ADO, DAO. (1 người xem)
Chế lại code của bản kia nhưng chưa tìm ra cách sắp sếp sao cho giống file mẫu
Sub GPE()    Dim Query As String
    Set rs = CreateObject("ADODB.Recordset")
     With cn
        .ConnectionString = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=" & _
        ThisWorkbook.FullName _
    & ";Extended Properties=""Excel 12.0 Xml;HDR=NO;IMEX=1"";"
        .Open
  Query = "SELECT A.f1, A.f2,SWITCH(A.f1 = A.f2, B.f2, A.f1 <> A.f2, null)" & Chr(10)
  Query = Query & "FROM (select distinct f1, f2 from [D2:E13]) As A " & Chr(10) & "RIGHT JOIN [A2:B6] As B ON B.f1 = A.f1 "
   rs.Open Query, cn
    Range("K2").CopyFromRecordset rs
    rs.Close: cn.Close: Set rs = Nothing: Set cn = Nothing
     With cn
        .Open
   rs.Open Query, cn
Thế này thì lại càng sai so với mẫu (lúc đầu mình dùng iff rùi, thấy ko ổn nên để kiểu đó)
Kết quả mình có dc từ code
[TABLE="class: grid, width: 303"]
[TR]
[TD]FWT166.1[/TD]
[TD]Khung mặt[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]FWT166.1[/TD]
[TD]FWT166.1[/TD]
[TD]Red[/TD]
[/TR]
[TR]
[TD]FWT166.1[/TD]
[TD]Chân[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]Khung mặt[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]FWT034[/TD]
[TD]white[/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]Chân[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]Khung mặt[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]FWT034[/TD]
[TD]Grey[/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]Chân[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]WCF015[/TD]
[TD]white[/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]Mặt ngồi[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]Chân dài[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]WCF015[/TD]
[TD]Grey[/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]Mặt ngồi[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]Chân dài[/TD]
[TD][/TD]
[/TR]
[/TABLE]
[TR]
[TD]FWT166.1[/TD]
[TD]Khung mặt[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]FWT166.1[/TD]
[TD]FWT166.1[/TD]
[TD]Red[/TD]
[/TR]
[TR]
[TD]FWT166.1[/TD]
[TD]Chân[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]Khung mặt[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]FWT034[/TD]
[TD]white[/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]Chân[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]Khung mặt[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]FWT034[/TD]
[TD]Grey[/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]Chân[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]WCF015[/TD]
[TD]white[/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]Mặt ngồi[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]Chân dài[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]WCF015[/TD]
[TD]Grey[/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]Mặt ngồi[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]Chân dài[/TD]
[TD][/TD]
[/TR]
[/TABLE]
Mình biết là nó sẽ ntn, nhưng bạn so sánh với bản mẫu là khác nhau nhiều, nó theo quy luật sắp xếp, còn kết quả này chỉ là có đủ dòng và hiện màu với những dòng có f1 = f2 thui, chứ ko theo quy luật của Color detail
thì mình thêm mấy cái Order by zô nữa cho giống . hi hi /-*+//-*+/
[TR]
[TD]FWT166.1[/TD]
[TD]Khung mặt[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]FWT166.1[/TD]
[TD]FWT166.1[/TD]
[TD]Red[/TD]
[/TR]
[TR]
[TD]FWT166.1[/TD]
[TD]Chân[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]Khung mặt[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]FWT034[/TD]
[TD]white[/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]Chân[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]Khung mặt[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]FWT034[/TD]
[TD]Grey[/TD]
[/TR]
[TR]
[TD]FWT034[/TD]
[TD]Chân[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]WCF015[/TD]
[TD]white[/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]Mặt ngồi[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]Chân dài[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]WCF015[/TD]
[TD]Grey[/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]Mặt ngồi[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]WCF015[/TD]
[TD]Chân dài[/TD]
[TD][/TD]
[/TR]
[/TABLE]
RÁng chút nữa đi bạn, gần được rồi đó.
cái bảng đâu có nhiều cột lắm đâu , cứ nghịch dại vài cột thử xem sao ? xếp vài ba cột 1 lúc xem sao ? ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
Em vẫn chưa nghĩ ra cách order, nhưng em dùng mẹo 1 chút để ra kết quả giống đề bài vậy.
Mong 2 pro @Hai Ly Mien Tay và @doveandrose chỉ giáo thêm.
Sub GPE()
    Dim Query As String
     With cn
        .Open
  Query = "select f1,f2, iif(f1=f2,f3,null) from (SELECT A.f1, A.f2, iif(a.f1 = a.f2,B.f2, b.f2 + '1') as f3 " & Chr(10)
  Query = Query & "FROM (select distinct f1, f2 from [D2:E13]) As A " & Chr(10) & "LEFT JOIN [A2:B6] As B ON B.f1 = A.f1) order by f1,f3"
   rs.Open Query, cn
Sub GPE()
    Dim Query As String
     With cn
        .Open
   rs.Open Query, cn
Kết quả đúng rồi, tuy nhiên nên tìm cách nào đó dùng 1 sub query thôi.
Hóa ra order cũng dùng đc công thức. Em sửa lại ntn ạ.
Sub GPE()
    Dim Query As String
     With cn
        .Open
  Query = "SELECT A.f1, A.f2, iif(a.f1=a.f2,B.f2,null) " & Chr(10)
  Query = Query & "FROM (select distinct f1, f2 from [D2:E13]) As A " & Chr(10) & "LEFT JOIN [A2:B6] As B ON B.f1 = A.f1 ORDER BY a.f1, IIF(A.f1 = a.f2,b.f2,b.f2 + '1')"
   rs.Open Query, cn
Sub GPE()
    Dim Query As String
     With cn
        .Open
   rs.Open Query, cn
Chính xác là như vậy, cảm ơn bạn đã tham gia, mong rằng đề tài này tiếp tục có nhiều thành viên quan tâm giống như bạn.
Tiện đây em cũng xin góp vui 1 bài toán về Tính tiền điện.
Các bạn coi file để rõ bài toán.
Tiện đây em cũng xin góp vui 1 bài toán: Tính tiền điện bằng ADO.
Mình thấy cách đặt vấn đề có gì đó không ổn?
ADO là công cụ quản trị dữ liệu kết nối và khai thác CSDL từ các nguồn có hỗ trợ chứ đâu có tham gia tính toán.
Cái mà bạn nói là kết quả của SQL đấy chứ. Vậy nên, 1 chủ đề thảo luận nó cũng cần có mức độ chính xác nhất định kẻo "thiên hạ" đánh giá nhà ta.
Em cảm ơn anh đã góp ý, em đã sửa bài rùi ạ.
Cái này cho vào hàm iif, kết hợp phép toán +,-,* là ra.
Đại loại ví dụ như sau:
IIf([SoDien]<=100,[SoDien]*2000,IIf([SoDien]<=200,100*2000+([SoDien]-100)*1600,IIf([SoDien]<=300,100*2000+100*1600+([SoDien]-200)*1200,IIf([SoDien]<=500,100*2000+100*1600+100*1200+([SoDien]-300)*1000,100*2000+100*1600+100*1200+200*1000+([SoDien]-500)*700))))
BẠn test thử nhé, xin lỗi vì chưa kiểm tra.
