duongrcfee
Xin chào mọi người!
Mình có một vấn đề mong được cả nhà chỉ giáo!
Mình muốn dùng VBA để lấy dữ liêu từ file *.txt, mình đã tham khảo bài viết của một bạn trong diễn dần với code như sau:
Sub Main()
Dim sFolder, txtFile As String, sWksName As String
Dim aFiles, Arr, wkbNew As Workbook
Dim lCount As Long, i As Long, n As Long, lWksCount As Long
With CreateObject("Shell.Application")
sFolder = .BrowseForFolder(0, "", 1).Self.Path
If TypeName(sFolder) = "String" Then
If Right(sFolder, 1) <> "\" Then sFolder = sFolder & "\"
aFiles = GetListFile(sFolder, "*.txt", False)
If IsArray(aFiles) Then
lCount = UBound(aFiles) + 1
ReDim Arr(1 To lCount)
Set wkbNew = Workbooks.Add
With wkbNew
lWksCount = lCount - .Sheets.Count
If lWksCount > 0 Then
.Worksheets.Add After:=.Sheets(.Sheets.Count), Count:=lWksCount
With CreateObject("Scripting.FileSystemObject")
For i = 0 To UBound(aFiles)
txtFile = sFolder & aFiles(i)
sWksName = Left(aFiles(i), InStrRev(aFiles(i), ".") - 1)
n = n + 1
Arr = GetValFromTxt(txtFile)
With wkbNew.Sheets(n)
.Range("A1").Resize(UBound(Arr)).Value = Arr
.Name = Left(sWksName, 31)
Function GetValFromTxt(ByVal txtFile As String)
Dim tmpArr, Arr()
Dim n As Long, i As Long
If .FileExists(txtFile) Then
With .OpenTextFile(txtFile, 1, , -2)
tmpArr = Split(.ReadAll, vbCrLf)
If IsArray(tmpArr) Then
ReDim Arr(1 To UBound(tmpArr) + 1, 1 To 1)
For i = 0 To UBound(tmpArr)
n = n + 1
Arr(n, 1) = CStr(tmpArr(i))
If n Then GetValFromTxt = Arr
.Close
Function GetListFile(ByVal Folder As String, ByVal Search As String, ByVal InSub As Boolean)
Dim sComm As String, tmp As String, tmpFile, Arr
If Right(Folder, 1) <> "\" Then Folder = Folder & "\"
Folder = """" & Folder & """"
tmpFile = .GetTempName
sComm = "DIR " & Folder & Search & " /ON /B /A-D " & IIf(InSub, "/S", " ") & " >" & tmpFile
CreateObject("Wscript.Shell").Run "cmd /u /c " & sComm, 0, True
With .OpenTextFile(tmpFile, 1, , -2)
tmp = Trim(.ReadAll)
If Right(tmp, 2) = vbCrLf Then tmp = Left(tmp, Len(tmp) - 2)
If Len(tmp) Then GetListFile = Split(tmp, vbCrLf)
.Close
Kill tmpFile
Nhưng mình muốn chỉnh sửa một chút mong mọi nguời giúp đỡ:
- Mình muốn lấy dữ liệu từ file *.txt vào sheet2 (hoặc sửa tên là data) chứ không mở 1 flie mới
- Các file *.txt khi đưa vào sẽ nằm trong 1 sheet
- Dữ liệu đưa vào thành dạng bảng
- Và thêm code để tự động save
Rất mong nhận được sự giúp đỡ của mọi người
Chân thành cảm ơn!
PS: Mình gửi cả file đính kèm nhé)
Sub Main()
With wkbNew
n = n + 1
Dim tmpArr, Arr()
n = n + 1
.Close
.Close
Kill tmpFile
Chân thành cảm ơn!
