làm sao cắt file 1 file PDF thành nhiều file với số trang mỗi file là n? (1 người xem)
Tường_Vi
Thành viên tiêu biểu
Luôn tìm kiếm một vị trí tốt hơn
Em có một file PDF-100.
File PDF này có 100 trang
Làm sao em có thể cắt file PDF-100 thành 50 file và mỗi file PDF có 02 trang
Xin cám ơn
em đang mò suốt từ sáng nhưng chưa thấy cái đúng ý mình (hầu như là split into single page) chứ không có split into doulbe page
Cám ơn google
Em đã tìm được
[h=1]How to Split a PDF into Multiple Files?[/h] Have you ever experienced that you need to send different pages of a large PDF file to a list of recipients?
Want to upload a certain PDF page to web but it exceeds the limited size?
Need to share a part of your PDF files with your friend via email?
If you have ever met the same or similar problems, you need to learn how to split PDF pages into separate files. PDF can describe documents containing any assemblages of text, images and graphics independently from platforms or applications, however, if we want to simplify the steps to view or get the desired pages, we should know how to split a PDF into multiple files at first. Following we provide the tutorial guide on how to split PDF into multiple pages with the powerful PDF splitter, which can break PDF files in all possible ways. Before following it to solve your problem, please free download the splitter at first.
Free Download to Split a PDF into Multiple Files Now!
[h=2]Guide: How to Split a PDF into Multiple Files[/h] Step 1. Run the PDF Splitter
Download, install and run Aiseesoft PDF Splitter on your computer. Then you will see the following interface.
Step 2. Input PDF Document
Click the "Browse" button to add the PDF file you want to split.
Step 3. Choose Split Way
This PDF Cutter provides you with five split methods: Split PDF by every n page(s); Split by bookmark; Split by page range to a PDF file; Split by specific page ranges to multiple PDF files and Split averagely to n PDF file(s).
Step 4. Split PDF into Separate Pages
After you set all the parameters for the cutting, you can click the "Split" button to start splitting PDF into multiple files.
Well done! You will split a PDF into multiple files in a short time with several clicks and easy-to-use interface. The splitter does help you a lot! Just get one of yourself!
Tags: split PDF into single files, how to split pdf files into multiple pages, how to split pdf pages into separate files
Related: Convert PDF to Editable Word, How to Separate PDF Pages
Rất cảm ơn bạn đã cất công tìm ra phần mềm hay này nhé. Nhưng bạn ơi cho mình hỏi key của phần mềm này ở đâu vậy bạ. Mong ban giúp đỡ nhé. Mình rất cần phần mềm này.
Nếu nhận được 1 file pdf do người ta scan gửi cho mình, có 4 cái thông tin chẳng hạn. Nhưng mình lại muốn tách 4 cái thông tin này ra để gửi cho 4 người khác nhau.
Lúc đấy, điên lên đây.
Mình làm rất đơn giản, xin chia sẻ như sau:
Mở file pdf ra, vào phần Snapshot (hình cái chụp ảnh)-> chọn.
Đưa con trỏ xuống chọn phần mình mu+ Trả Lời Ðề Tàiốn tách ra, sau đó chuột phải Copy selected graphic.
Sau đó vào Start-All program-Accessory-Paint. Sau đó Past xong rồi save lại.
Thế là ta đã có 1 file ảnh mình cần.
Cảm ơn các bạn đã đọc tin.
