Dùng tạm code này.Chào Anh/Chị,
Em có 1 file dữ liệu gồm 1 sheet Tổng hợp , Giờ muốn tách sheet tổng hợp này thành nhiều sheet chia theo Brand ạ
Em cảm ơn ạ
Sub Tach1SheetThanhNhieuSheet()
Dim tTime As Double
Dim Ws As Worksheet
Dim i As Integer
Dim NWs As Worksheet
Dim Odau As Range
'tTime = Timer
'XOA
For Each Ws In ActiveWorkbook.Sheets
If Ws.Name <> "Sheet1" Then Ws.Delete
Set Ws = ThisWorkbook.Sheets("Sheet1")
Ws.Columns(3).Copy
Ws.Columns(17).PasteSpecial xlPasteValues
Ws.Cells(2, 17).CurrentRegion.RemoveDuplicates Columns:=1, Header:=xlYes
' Loc cac Đk va tao sheet moi và copy
i = 2
While (Ws.Cells(i, 17) <> "")
Worksheets.Add after:=ThisWorkbook.Sheets(ThisWorkbook.Sheets.Count)
Set NWs = ActiveSheet
NWs.Name = Ws.Cells(i, 17)
Ws.Select
Set Odau = Ws.Range("A1")
Odau.CurrentRegion.AutoFilter Field:=3, Criteria1:=Ws.Cells(i, 17)
Odau.CurrentRegion.SpecialCells(xlCellTypeVisible).Copy
NWs.Range("A1").PasteSpecial
NWs.Cells.EntireColumn.AutoFit
Ws.Select
Odau.AutoFilter
i = i + 1
Wend
Ws.Columns(17).ClearContents
'Debug.Print Timer - tTime
MsgBox " Đa hoàn thành"
Sub Tach_Sheets()
Dim Lr&, i&, j&, k&, Arr(), Res(1 To 100000, 1 To 9)
Dim Dic As Object, Key$, Ws As Worksheet, Rng As Range
For Each Ws In Worksheets
Ws.Delete
Next Ws
With Sheets("Sheet1")
Set Rng = .Range("A1:I1")
Lr = .Range("A" & Rows.Count).End(xlUp).Row
Arr = .Range("A2:I" & Lr).Value
For i = 1 To UBound(Arr)
If Arr(i, 3) <> "" Then
Key = Arr(i, 3)
If Not Dic.exists(Key) Then
Dic.Add (Key), ""
Worksheets.Add after:=Sheets(Sheets.Count)
ActiveSheet.Name = Key
If Arr(i, 3) = Ws.Name Then
For j = 1 To 9
Res(k, j) = Arr(i, j)
If k Then
Rng.Copy Ws.Range("A1")
Ws.Range("A2").Resize(k, 9).Value = Res
Ws.Range("A1").CurrentRegion.Borders.LineStyle = 1
Ws.Columns("A:I").AutoFit
k = 0
Next Ws
Set Dic = Nothing
MsgBox "Done"
Góp vui thế này:
HTML:Sub Tach_Sheets() Dim Lr&, i&, j&, k&, Arr(), Res(1 To 100000, 1 To 9) Dim Dic As Object, Key$, Ws As Worksheet, Rng As Range Set Dic = CreateObject("Scripting.Dictionary") Application.DisplayAlerts = False Application.ScreenUpdating = False For Each Ws In Worksheets If Ws.Name <> "Sheet1" Then Ws.Delete End If Next Ws With Sheets("Sheet1") Set Rng = .Range("A1:I1") Lr = .Range("A" & Rows.Count).End(xlUp).Row Arr = .Range("A2:I" & Lr).Value For i = 1 To UBound(Arr) If Arr(i, 3) <> "" Then Key = Arr(i, 3) If Not Dic.exists(Key) Then Dic.Add (Key), "" Worksheets.Add after:=Sheets(Sheets.Count) ActiveSheet.Name = Key End If End If Next i For Each Ws In Worksheets If Ws.Name <> "Sheet1" Then For i = 1 To UBound(Arr) If Arr(i, 3) = Ws.Name Then k = k + 1 For j = 1 To 9 Res(k, j) = Arr(i, j) Next j End If Next i End If If k Then Rng.Copy Ws.Range("A1") Ws.Range("A2").Resize(k, 9).Value = Res Ws.Range("A1").CurrentRegion.Borders.LineStyle = 1 Ws.Columns("A:I").AutoFit k = 0 End If Next Ws End With Set Dic = Nothing Application.ScreenUpdating = True Application.DisplayAlerts = True MsgBox "Done" End Sub
Code chạy nhanh quá ạGóp vui thế này:
Gì mà làm việc sớm thế, mình còn đang ăn bánh chưng.Dạ, em có nhờ code của anh mà làm được file của em, nhưng trong file của em cần điền thêm chữ "Bên giao" và "Bên nhận" sau mỗi sheet được tách ra (Tính từ dòng cuối có dữ liệu + 2 dòng trống, thì điền Bên giao và Bên nhận ở cột C và F, vì mỗi PO có số lượng sp khác nhau nên không set cố định vào 1 ô được ạ)
Em gửi file đính kèm, nhờ anh hỗ trợ cho em xin code với ạ.
Em cám ơn nhiều
ôi cám ơn anh, em làm được rồi, ngồi mò từng code. Em cám ơn nhiều lắm ạ. Nếu anh có dạy vba, anh cho e xin contact nhé ạ.Gì mà làm việc sớm thế, mình còn đang ăn bánh chưng.
Mách cho bạn nhá, sau khi chạy xong đoạn tách sheets thì thêm phần tìm dòng cuối có dữ liệu, gán chữ “Bên giao” và “ Bên nhận” vào vị trí cột C, F “ở dòng cuối +2” là được rồi.
Bạn biết chỉnh code thì thêm lệnh nhỏ này chắc tự làm được đấy!
Chúc mừng bạn đã tự làm được, bạn muốn học về VBA thì mỗi ngày online vào GPE khoảng 2-3 tiếng nhé, trên này là môi trường tốt để ta học tập đấy, tôi cũng đang đi học thôi, trình độ của tôi hãy còn non và xanh lắm!ôi cám ơn anh, em làm được rồi, ngồi mò từng code. Em cám ơn nhiều lắm ạ. Nếu anh có dạy vba, anh cho e xin contact nhé ạ.
Dùng tạm code này:Nhờ các bác viết giùm em code như file với ạ
Em muốn tách sheet Report (dữ liệu bắt đầu từ AB7 đến cột HF) thành các sheet chia theo Location (cột GT của sheet Report) và vị trí copy dữ liệu qua sheet mới bắt đầu từ cột A7 (kết quả như các sheet BDO, DNO, HCM).
Cám ơn các bác nhiều ạ.
Dim tTime As Double
Dim Ws As Worksheet
Dim i As Integer
Dim Odau As Range
'XOA
If Ws.Name <> "REPORT" Then Ws.Delete
Set Ws = ThisWorkbook.Sheets("REPORT")
Ws.Range("GT8:GT1000").Copy
Ws.Cells(1, 217).PasteSpecial xlPasteValues
Ws.Cells(1, 217).CurrentRegion.RemoveDuplicates Columns:=1, Header:=xlNo
i = 1
While (Ws.Cells(i, 217) <> "")
NWs.Name = Ws.Cells(i, 217)
Ws.Select
Set Odau = Ws.Range("AB7")
Odau.CurrentRegion.AutoFilter Field:=175, Criteria1:=Ws.Cells(i, 217)
Odau.CurrentRegion.SpecialCells(xlCellTypeVisible).Copy NWs.Range("A1") '.PasteSpecial
Ws.Select
Odau.AutoFilter
i = i + 1
Wend
Ws.Columns(217).ClearContents
Sub Tach_Sheets()
Dim Lr&, i&, j&, k&, Arr(), Res(1 To 100000, 1 To 187)
Ws.Delete
Next Ws
With Sheets("REPORT")
Set Rng = .Range("AB7:HF7")
Lr = .Range("AB" & Rows.Count).End(xlUp).Row
Arr = .Range("AB8:HF" & Lr).Value
If Arr(i, 175) <> "" Then
Key = Arr(i, 175)
Dic.Add (Key), ""
If Arr(i, 175) = Ws.Name Then
For j = 1 To UBound(Arr, 2)
If k Then
Ws.Range("A2").Resize(k, UBound(Arr, 2)).Value = Res
Ws.Columns("A:GE").AutoFit
k = 0
Next Ws
Set Dic = Nothing
MsgBox "Done"
Khi tách dữ liệu ra thành cách sheet Thì điều kiện làCám ơn bác em làm được rồi, tuy nhiên khi em tách file thì nó bị mất các những sheet có sẵn mà chỉ ra sheet tổng hợp và sheet cần tách.
Bác có thể chỉnh thêm code giúp em, vẫn giữ nguyên các sheet có sẵn trong file được không ạ
mà cột GT ấy chỉ có là BDO, DNO, HCM và lấy luôn các Location ấy làm tên sheet- và tên sheet chỉ là duy nhất, như vậy các sheet cũ sẽ bị xóa đi thay vào đó là các sheet mới tạo. Nếu giữ lại các sheet có sẵn trong workbook thì khi được dữ liệu tách sẽ được ghi vào đâu? Theo code ở bài #11 thì khi chạy code tất cả các sheet có tên khác "REPORT" đều bị xóa. Nếu bạn muốn giữ lại sheet nào thì:chia theo Location (cột GT của sheet Report)
If Ws.Name <> "REPORT" or Ws.Name <> "tên sheet cần giữ" or Ws.Name <> "tên sheet cần giữ" or ....Then
Có thể chia sẻ cái làm được rồi đó không? để cho nhiều người có thêm kiến thức học hỏi.Cám ơn bác nhiều, em đã làm đượ rồi ạ
Hội trưởng "hội ém hàng" đây rồi!Có thể chia sẻ cái làm được rồi đó không? để cho nhiều người có thêm kiến thức học hỏi.
bạn có thể giúp mình tách sheet TH này thành nhiều sheet nhỏ theo các tiêu chí ở cột M; mà phần cuối có dòng ngày tháng;ký nhận không ạ? mình không biết gì về viết code cảGì mà làm việc sớm thế, mình còn đang ăn bánh chưng.
Option Compare Text
Sub Brand_(Dic As Object, Arr_N(), Arr_Brand())
Dim i As Long, k As Long
Set Dic = CreateObject("Scripting.dictionary")
k = 0
For i = 1 To UBound(Arr_N, 1)
If Not Dic.exists(Arr_N(i, 9)) Then
Dic.Add Arr_N(i, 9), k
ReDim Preserve Arr_Brand(1 To k)
Arr_Brand(k) = Arr_N(i, 9)
Sub Trichloc(Arr_N(), Arr_D(), k As Long, Brand As String)
k = 0
If Arr_N(i, 9) = Brand Then
For j = 1 To 9
Arr_D(k, j) = Arr_N(i, j)
Sub Main()
Dim i As Long, k As Long, Dcuoi As Long, Brand As String
Dim Dic As Object, Sh As Worksheet
Dim Arr_N(), Arr_D(), Arr_Brand()
Dcuoi = Sheet1.Range("A100000").End(xlUp).Row
Arr_N = Sheet1.Range("A2:I" & Dcuoi)
ReDim Arr_D(1 To UBound(Arr_N, 1), 1 To 10)
For Each Sh In Worksheets
If Sh.Name <> "Sheet1" And Sh.Name <> "Sheet2" Then
Sh.Delete
Call Brand_(Dic, Arr_N, Arr_Brand)
For i = 1 To UBound(Arr_Brand, 1)
Brand = Arr_Brand(i)
Call Trichloc(Arr_N, Arr_D, k, Brand)
Sheet2.Range("A2:J10000").Clear
Sheet2.Range("A2").Resize(k, 9).NumberFormat = "@"
Sheet2.Range("A2").Resize(k, 9) = Arr_D
Sheet2.Copy after:=Sheet2
ActiveSheet.Name = Brand
Code đã có sẵn đó rồi bạn thử tuỳ chỉnh theo mục đích cá nhân xem sao.bạn có thể giúp mình tách sheet TH này thành nhiều sheet nhỏ theo các tiêu chí ở cột M; mà phần cuối có dòng ngày tháng;ký nhận không ạ? mình không biết gì về viết code cả
cái này nếu vừa muốn tách vừa muốn các sheet con tự động thay đổi khi dữ liệu tổng thay đổi thì làm sao ạGóp vui thế này:
