Tách 1 sheet thành nhiều sheet theo điều kiện (10 người xem)
  • Thread starter Thread starter antit
antit
Chào Anh/Chị,
Em có 1 file dữ liệu gồm 1 sheet Tổng hợp , Giờ muốn tách sheet tổng hợp này thành nhiều sheet chia theo Brand ạ
Em cảm ơn ạ
Chào Anh/Chị,
Em cảm ơn ạ
Dùng tạm code này.
Sub Tach1SheetThanhNhieuSheet()
Dim tTime As Double
Dim Ws As Worksheet
Dim i As Integer
Dim NWs As Worksheet
Dim Odau As Range
'tTime = Timer
 'XOA
 For Each Ws In ActiveWorkbook.Sheets
    If Ws.Name <> "Sheet1" Then Ws.Delete
Set Ws = ThisWorkbook.Sheets("Sheet1")
    Ws.Columns(3).Copy
    Ws.Columns(17).PasteSpecial xlPasteValues
    Ws.Cells(2, 17).CurrentRegion.RemoveDuplicates Columns:=1, Header:=xlYes
    ' Loc cac Đk va tao sheet moi và copy
    i = 2
    While (Ws.Cells(i, 17) <> "")
    Worksheets.Add after:=ThisWorkbook.Sheets(ThisWorkbook.Sheets.Count)
    Set NWs = ActiveSheet
    NWs.Name = Ws.Cells(i, 17)
    Ws.Select
    Set Odau = Ws.Range("A1")
    Odau.CurrentRegion.AutoFilter Field:=3, Criteria1:=Ws.Cells(i, 17)
    Odau.CurrentRegion.SpecialCells(xlCellTypeVisible).Copy
    NWs.Range("A1").PasteSpecial
    NWs.Cells.EntireColumn.AutoFit
    Ws.Select
    Odau.AutoFilter
    i = i + 1
    Wend
    Ws.Columns(17).ClearContents
'Debug.Print Timer - tTime
    MsgBox " Đa hoàn thành"
Góp vui thế này:
HTML:
Sub Tach_Sheets()
    Dim Lr&, i&, j&, k&, Arr(), Res(1 To 100000, 1 To 9)
    Dim Dic As Object, Key$, Ws As Worksheet, Rng As Range
    For Each Ws In Worksheets
            Ws.Delete
    Next Ws
    With Sheets("Sheet1")
        Set Rng = .Range("A1:I1")
        Lr = .Range("A" & Rows.Count).End(xlUp).Row
        Arr = .Range("A2:I" & Lr).Value
        For i = 1 To UBound(Arr)
            If Arr(i, 3) <> "" Then
                Key = Arr(i, 3)
                If Not Dic.exists(Key) Then
                    Dic.Add (Key), ""
                    Worksheets.Add after:=Sheets(Sheets.Count)
                    ActiveSheet.Name = Key
                        If Arr(i, 3) = Ws.Name Then
                            For j = 1 To 9
                                Res(k, j) = Arr(i, j)
                If k Then
                    Rng.Copy Ws.Range("A1")
                    Ws.Range("A2").Resize(k, 9).Value = Res
                    Ws.Range("A1").CurrentRegion.Borders.LineStyle = 1
                    Ws.Columns("A:I").AutoFit
                    k = 0
            Next Ws
    Set Dic = Nothing
    MsgBox "Done"
Góp vui thế này:
HTML:
Sub Tach_Sheets()
            Ws.Delete
    Next Ws
                Key = Arr(i, 3)
                    Dic.Add (Key), ""
                            For j = 1 To 9
                If k Then
                    k = 0
            Next Ws
    Set Dic = Nothing
    MsgBox "Done"
Dạ, em có nhờ code của anh mà làm được file của em, nhưng trong file của em cần điền thêm chữ "Bên giao" và "Bên nhận" sau mỗi sheet được tách ra (Tính từ dòng cuối có dữ liệu + 2 dòng trống, thì điền Bên giao và Bên nhận ở cột C và F, vì mỗi PO có số lượng sp khác nhau nên không set cố định vào 1 ô được ạ)
Em gửi file đính kèm, nhờ anh hỗ trợ cho em xin code với ạ.
Em cám ơn nhiều
Góp vui thế này:
HTML:
Sub Tach_Sheets()
            Ws.Delete
    Next Ws
                Key = Arr(i, 3)
                    Dic.Add (Key), ""
                            For j = 1 To 9
                If k Then
                    k = 0
            Next Ws
    Set Dic = Nothing
    MsgBox "Done"
Code chạy nhanh quá ạ
Em cám ơn nhiều
Gì mà làm việc sớm thế, mình còn đang ăn bánh chưng.
Mách cho bạn nhá, sau khi chạy xong đoạn tách sheets thì thêm phần tìm dòng cuối có dữ liệu, gán chữ “Bên giao” và “ Bên nhận” vào vị trí cột C, F “ở dòng cuối +2” là được rồi.
Bạn biết chỉnh code thì thêm lệnh nhỏ này chắc tự làm được đấy!
ôi cám ơn anh, em làm được rồi, ngồi mò từng code. Em cám ơn nhiều lắm ạ. Nếu anh có dạy vba, anh cho e xin contact nhé ạ.
Chúc mừng bạn đã tự làm được, bạn muốn học về VBA thì mỗi ngày online vào GPE khoảng 2-3 tiếng nhé, trên này là môi trường tốt để ta học tập đấy, tôi cũng đang đi học thôi, trình độ của tôi hãy còn non và xanh lắm!
Nhờ các bác viết giùm em code như file với ạ
Em muốn tách sheet Report (dữ liệu bắt đầu từ AB7 đến cột HF) thành các sheet chia theo Location (cột GT của sheet Report) và vị trí copy dữ liệu qua sheet mới bắt đầu từ cột A7 (kết quả như các sheet BDO, DNO, HCM).
Cám ơn các bác nhiều ạ.
Pivot table bạn nhé sẵn có trong excel mà
Dùng tạm code này:
Dim tTime As Double
Dim Ws As Worksheet
Dim i As Integer
Dim Odau As Range
 'XOA
    If Ws.Name <> "REPORT" Then Ws.Delete
Set Ws = ThisWorkbook.Sheets("REPORT")
    Ws.Range("GT8:GT1000").Copy
    Ws.Cells(1, 217).PasteSpecial xlPasteValues
    Ws.Cells(1, 217).CurrentRegion.RemoveDuplicates Columns:=1, Header:=xlNo
    i = 1
    While (Ws.Cells(i, 217) <> "")
    NWs.Name = Ws.Cells(i, 217)
    Ws.Select
    Set Odau = Ws.Range("AB7")
    Odau.CurrentRegion.AutoFilter Field:=175, Criteria1:=Ws.Cells(i, 217)
    Odau.CurrentRegion.SpecialCells(xlCellTypeVisible).Copy NWs.Range("A1") '.PasteSpecial
    Ws.Select
    Odau.AutoFilter
    i = i + 1
    Wend
    Ws.Columns(217).ClearContents
Hoặc dùng code của anh @THÓC SAMA ở bài #3 và sửa lại thế này:
Sub Tach_Sheets()
    Dim Lr&, i&, j&, k&, Arr(), Res(1 To 100000, 1 To 187)
            Ws.Delete
    Next Ws
    With Sheets("REPORT")
        Set Rng = .Range("AB7:HF7")
        Lr = .Range("AB" & Rows.Count).End(xlUp).Row
        Arr = .Range("AB8:HF" & Lr).Value
            If Arr(i, 175) <> "" Then
                Key = Arr(i, 175)
                    Dic.Add (Key), ""
                        If Arr(i, 175) = Ws.Name Then
                            For j = 1 To UBound(Arr, 2)
                If k Then
                    Ws.Range("A2").Resize(k, UBound(Arr, 2)).Value = Res
                    Ws.Columns("A:GE").AutoFit
                    k = 0
            Next Ws
    Set Dic = Nothing
    MsgBox "Done"
Cám ơn bác em làm được rồi, tuy nhiên khi em tách file thì nó bị mất các những sheet có sẵn mà chỉ ra sheet tổng hợp và sheet cần tách.
Bác có thể chỉnh thêm code giúp em, vẫn giữ nguyên các sheet có sẵn trong file được không ạ
Khi tách dữ liệu ra thành cách sheet Thì điều kiện là
mà cột GT ấy chỉ có là BDO, DNO, HCM và lấy luôn các Location ấy làm tên sheet- và tên sheet chỉ là duy nhất, như vậy các sheet cũ sẽ bị xóa đi thay vào đó là các sheet mới tạo. Nếu giữ lại các sheet có sẵn trong workbook thì khi được dữ liệu tách sẽ được ghi vào đâu? Theo code ở bài #11 thì khi chạy code tất cả các sheet có tên khác "REPORT" đều bị xóa. Nếu bạn muốn giữ lại sheet nào thì:
Thay dòng code
Thành
If Ws.Name <> "REPORT" or  Ws.Name <> "tên sheet cần giữ" or Ws.Name <> "tên sheet cần giữ" or ....Then
nếu tên sheet cần giữ mà trùng tên Với Location ở cột GT thì khi Chạy thử, sẽ vấp lỗi Tên sheet không phải là duy nhất.
bạn có thể giúp mình tách sheet TH này thành nhiều sheet nhỏ theo các tiêu chí ở cột M; mà phần cuối có dòng ngày tháng;ký nhận không ạ? mình không biết gì về viết code cả
Có thể chia sẻ cái làm được rồi đó không? để cho nhiều người có thêm kiến thức học hỏi.
Option Compare Text
Sub Brand_(Dic As Object, Arr_N(), Arr_Brand())
Dim i As Long, k As Long
Set Dic = CreateObject("Scripting.dictionary")
k = 0
For i = 1 To UBound(Arr_N, 1)
  If Not Dic.exists(Arr_N(i, 9)) Then
    Dic.Add Arr_N(i, 9), k
    ReDim Preserve Arr_Brand(1 To k)
     Arr_Brand(k) = Arr_N(i, 9)
Sub Trichloc(Arr_N(), Arr_D(), k As Long, Brand As String)
k = 0
   If Arr_N(i, 9) = Brand Then
    For j = 1 To 9
        Arr_D(k, j) = Arr_N(i, j)
Sub Main()
Dim i As Long, k As Long, Dcuoi As Long, Brand As String
Dim Dic As Object, Sh As Worksheet
Dim Arr_N(), Arr_D(), Arr_Brand()
Dcuoi = Sheet1.Range("A100000").End(xlUp).Row
Arr_N = Sheet1.Range("A2:I" & Dcuoi)
ReDim Arr_D(1 To UBound(Arr_N, 1), 1 To 10)
For Each Sh In Worksheets
    If Sh.Name <> "Sheet1" And Sh.Name <> "Sheet2" Then
        Sh.Delete
Call Brand_(Dic, Arr_N, Arr_Brand)
For i = 1 To UBound(Arr_Brand, 1)
  Brand = Arr_Brand(i)
  Call Trichloc(Arr_N, Arr_D, k, Brand)
   Sheet2.Range("A2:J10000").Clear
   Sheet2.Range("A2").Resize(k, 9).NumberFormat = "@"
   Sheet2.Range("A2").Resize(k, 9) = Arr_D
   Sheet2.Copy after:=Sheet2
   ActiveSheet.Name = Brand
bạn muốn học hỏi thì có thể xem code này nếu học được chỗ nào thì học, tôi có đính kèm theo yêu cầu file đầu tiên, lâu lâu viết bài cho đỡ nhớ diễn đàn
Code đã có sẵn đó rồi bạn thử tuỳ chỉnh theo mục đích cá nhân xem sao.
Vướng đâu ta lại hỏi tiếp!
Góp vui thế này:
HTML:
Sub Tach_Sheets()
            Ws.Delete
    Next Ws
                Key = Arr(i, 3)
                    Dic.Add (Key), ""
                            For j = 1 To 9
                If k Then
                    k = 0
            Next Ws
    Set Dic = Nothing
    MsgBox "Done"
cái này nếu vừa muốn tách vừa muốn các sheet con tự động thay đổi khi dữ liệu tổng thay đổi thì làm sao ạ
