Em có cái code chạy update kết quả nhờ các bác sửa cho phù hợp với Win 64bit và gán file excel chạy thử.
Code đây ạ:
Private Declare Function DeleteUrlCacheEntry Lib "wininet.dll" Alias "DeleteUrlCacheEntryA" (ByVal lpszUrlName As String) As Long
Private Declare Function URLDownloadToFile Lib "urlmon" Alias "URLDownloadToFileA" (ByVal pCaller As Long, _
ByVal szURL As String, ByVal szFileName As String, ByVal dwReserved As Long, ByVal lpfnCB As Long) As Long
Dim rW As Long
Dim TP As clsMain
Sub Aut
pen()
Set TP = New clsMain
TP.Create Application
'Exit Sub
SpeedOnK
Call FixExcel
If PathExists("C:\Tamhoang") = False Then MkDir ("C:\Tamhoang")
Application.DisplayFormulaBar = False
Application.ExecuteExcel4Macro "Show.ToolBar(""Ribbon"",false)"
Dim Index As Long, n As Long, Col As Long, row As Long, Text As String
Dim Rng As Range, fso As Object, FilesToImport
Dim TextSource As Object, NumOfLines, Cols, Res()
Set Rng = Sheets("Lotto").Range("A2")
Ngay = Lotto.[a10000].End(3) + 1
If Hour(Now) > 18 Then
Dy = Date
Dy = Date - 1
For Days = Ngay To Dy
EndR = Lotto.[a10000].End(3).row
Sheet9.Range("B10").Resize(, 21).Value = Lotto.Range("BE10000").End(3).Resize(, 21).Value
URL = "http://www.minhngoc.net.vn/ket-qua-xo-so/mien-bac/"
URL = URL & Day(Days) & "-" & Month(Days) & "-" & Year(Days) & ".html"
DownloadFile_hn = URLDownloadToFile(0, URL, "C:\Tamhoang\vn.txt", 0, 0)
FilesToImport = "C:\Tamhoang\vn.txt"
Set TextSource = fs
penTextFile("C:\Tamhoang\vn.txt", 1, , -2)
NumOfLines = Split(TextSource.ReadAll, vbCrLf)
If UBound(NumOfLines) > 0 Then
Lotto.Cells(EndR + 1, "A") = Days
If Weekday(Days) = 1 Then
Lotto.Cells(EndR + 1, "B") = "CN"
Lotto.Cells(EndR + 1, "B") = "T" & Weekday(Days)
'ReDim Res(1 To UBound(NumOfLines), 1 To 1)
For row = 1 To UBound(NumOfLines)
Text = NumOfLines(row)
If Text <> "" Then
If InStr(Text, """giaidb""") > 0 Then
Lotto.Cells(EndR + 1, "C").Value = "'" & Mid(NumOfLines(row + 1), 10, 5)
Sheet9.[L11].Value = "'" & Mid(NumOfLines(row + 1), 10, 5)
ElseIf InStr(Text, """giai1""") > 0 Then
Lotto.Cells(EndR + 1, "D") = "'" & Mid(NumOfLines(row + 1), 10, 5)
ElseIf InStr(Text, """giai2""") > 0 Then
Lotto.Cells(EndR + 1, "E") = "'" & Mid(NumOfLines(row + 1), 10, 5)
Lotto.Cells(EndR + 1, "F") = "'" & Mid(NumOfLines(row + 1), 26, 5)
ElseIf InStr(Text, """giai3""") > 0 Then
Lotto.Cells(EndR + 1, "G") = "'" & Mid(NumOfLines(row + 1), 10, 5)
Lotto.Cells(EndR + 1, "H") = "'" & Mid(NumOfLines(row + 1), 26, 5)
Lotto.Cells(EndR + 1, "I") = "'" & Mid(NumOfLines(row + 1), 42, 5)
Lotto.Cells(EndR + 1, "J") = "'" & Mid(NumOfLines(row + 1), 58, 5)
Lotto.Cells(EndR + 1, "K") = "'" & Mid(NumOfLines(row + 1), 74, 5)
Lotto.Cells(EndR + 1, "L") = "'" & Mid(NumOfLines(row + 1), 90, 5)
ElseIf InStr(Text, """giai4""") > 0 Then
Lotto.Cells(EndR + 1, "M") = "'" & Mid(NumOfLines(row + 1), 10, 4)
Lotto.Cells(EndR + 1, "N") = "'" & Mid(NumOfLines(row + 1), 25, 4)
Lotto.Cells(EndR + 1, "O") = "'" & Mid(NumOfLines(row + 1), 40, 4)
Lotto.Cells(EndR + 1, "P") = "'" & Mid(NumOfLines(row + 1), 55, 4)
ElseIf InStr(Text, """giai5""") > 0 Then
Lotto.Cells(EndR + 1, "Q") = "'" & Mid(NumOfLines(row + 1), 10, 4)
Lotto.Cells(EndR + 1, "R") = "'" & Mid(NumOfLines(row + 1), 25, 4)
Lotto.Cells(EndR + 1, "S") = "'" & Mid(NumOfLines(row + 1), 40, 4)
Lotto.Cells(EndR + 1, "T") = "'" & Mid(NumOfLines(row + 1), 55, 4)
Lotto.Cells(EndR + 1, "U") = "'" & Mid(NumOfLines(row + 1), 70, 4)
Lotto.Cells(EndR + 1, "V") = "'" & Mid(NumOfLines(row + 1), 85, 4)
ElseIf InStr(Text, """giai6""") > 0 Then
Lotto.Cells(EndR + 1, "W") = "'" & Mid(NumOfLines(row + 1), 10, 3)
Lotto.Cells(EndR + 1, "X") = "'" & Mid(NumOfLines(row + 1), 24, 3)
Lotto.Cells(EndR + 1, "Y") = "'" & Mid(NumOfLines(row + 1), 38, 3)
ElseIf InStr(Text, """giai7""") > 0 Then
Lotto.Cells(EndR + 1, "Z") = "'" & Mid(NumOfLines(row + 1), 10, 2)
Lotto.Cells(EndR + 1, "AA") = "'" & Mid(NumOfLines(row + 1), 23, 2)
Lotto.Cells(EndR + 1, "AB") = "'" & Mid(NumOfLines(row + 1), 36, 2)
Lotto.Cells(EndR + 1, "AC") = "'" & Mid(NumOfLines(row + 1), 49, 2)
Exit For
TextSource.Close
Lotto.Range("BE" & EndR + 1).Resize(, 9).Value = Sheet9.Range("B11").Resize(, 9).Value
DB.Range("A2").End(4).Offset(1).Resize(, 21).Value = Sheet9.Range("B11").Resize(, 21).Value
For Each Clls In Lotto.Range("C" & EndR + 1 & ":AC" & EndR + 1)
If Clls <> "" Then Clls.Offset(, 27) = "'" & Right(Clls, 2)
Endrw = DB.[A2].End(4).row
DB.Range("K" & Endrw) = "'" & Sheet9.[L11]
DB.Range("M" & Endrw) = "'" & Right(DB.Range("K" & Endrw), 2)
DB.Range("R" & Endrw) = "'" & Bo(DB.Range("M" & Endrw))
If Lotto.Cells(EndR, "C") = "" Then
For rW = EndR To 2 Step -1
If Lotto.Cells(rW, "C") <> "" Then Exit For
If Lotto.Cells(EndR + 1, "C") = Lotto.Cells(rW, "C") And Lotto.Cells(EndR + 1, "D") = Lotto.Cells(rW, "D") Then
Lotto.Range("C" & EndR + 1).Resize(, 54).ClearContents
Lotto.Cells(EndR + 1, "M").Resize(, 10).ClearContents
Lotto.Cells(EndR + 1, "K") = "TET"
ElseIf Lotto.Cells(EndR + 1, "C") = Lotto.Cells(EndR, "C") And Lotto.Cells(EndR + 1, "D") = Lotto.Cells(EndR, "D") Then
Set objFSO = CreateObject("Scripting.FileSystemObject")
If FileExists("C:\Tamhoang\vn.txt") = True Then objFSO.DeleteFile ("C:\Tamhoang\vn.txt"), DeleteReadOnly
'If PathExists("C:\Tamhoang") = True Then objFSO.deletefolder ("C:\Tamhoang"), DeleteReadOnly
With Application
.ScreenUpdating = False
.CommandBars("Formatting").Visible = False
.CommandBars("Standard").Visible = False
.StatusBar = False
.DisplayStatusBar = True
With ActiveWindow
'.DisplayHeadings = False
.DisplayOutline = False
'.DisplayHorizontalScrollBar = True
'.DisplayVerticalScrollBar = True
.DisplayWorkbookTabs = False
.Zoom = 100
Sheet3.Visible = 2
Sheet4.Visible = 2
Application.ExecuteExcel4Macro "Show.ToolBar(""Ribbon"",False)"
Sheet1.Select
SpeedOff
Sub Auto_Close()
Set TP = Nothing
With Application
.ScreenUpdating = True
.DisplayFormulaBar = True
.CommandBars("Formatting").Visible = True
.CommandBars("Standard").Visible = True
.StatusBar = True
With ActiveWindow
.DisplayHeadings = True
.DisplayOutline = True
.DisplayWorkbookTabs = True
.Zoom = 100
Application.ExecuteExcel4Macro "Show.ToolBar(""Ribbon"",True)"
Application.DisplayFormulaBar = True
Sheet1.Cells.Clear
Sheet1.[A:AA].ColumnWidth = 9
Function PathExists(pname) As Boolean
Dim x As String
x = GetAttr(pname) And 0
If Err = 0 Then PathExists = True _
Else PathExists = False
Function FileExists(ByVal fname As String) As Boolean
Set fs = CreateObject("Scripting.FileSystemObject")
FileExists = fs.FileExists(fname)
Sub FixExcel()
With Application.ErrorCheckingOptions
.EvaluateToError = False
.TextDate = False
.NumberAsText = False
.InconsistentFormula = False
.OmittedCells = False
.UnlockedFormulaCells = False
'.ListLottoValidation = False
.InconsistentTableFormula = False
Xin chân thành cảm ơn các bác!
Code đây ạ:
Dim rW As Long
Dim TP As clsMain
Sub Aut
'Exit Sub
SpeedOnK
Call FixExcel
Dy = Date
Dy = Date - 1
Set TextSource = fs
If Text <> "" Then
Exit For
TextSource.Close
With Application
.StatusBar = False
With ActiveWindow
.Zoom = 100
Sheet3.Visible = 2
Sheet4.Visible = 2
Sheet1.Select
SpeedOff
Sub Auto_Close()
Set TP = Nothing
With Application
.StatusBar = True
With ActiveWindow
.Zoom = 100
Sheet1.Cells.Clear
Dim x As String
Sub FixExcel()
.TextDate = False
