Giúp xem code tạo Divirer, FadeID cho menu (1 người xem)
thanhnhanubnd
Xay dung
Mình có "chôm" 1 đoạn code, đã làm được nhưng chưa tạo được Divirer, FadeID cho menu :
Sub Auto_Open()
lenh Delete CommandBar
'khoi tao menu Du lieu'
Set oldMbar = CommandBars.ActiveMenuBar
Set myMenuBar = CommandBars.Add(Name:="Quan ly du lieu menu" _
    , Position:=msoBarTop, MenuBar:=False, Temporary:=True)
With myMenuBar
            .Visible = True:                .Protection = msoBarNoMove
Set myMenuBar = CommandBars.ActiveMenuBar
Set newMenu = myMenuBar.Controls.Add(Type:=msoControlPopup, Temporary:=True)
newMenu.Caption = "&Quan ly du lieu"
'tao Menu tilte Chon thu muc'
Set Ctrl1 = newMenu.Controls.Add(Type:=msoControlButton, ID:=3)
Ctrl1.FaceId = 66
Ctrl1.Caption = "Chon thu muc..."
Ctrl1.TooltipText = "Chon thu muc..."
Ctrl1.Style = msoButtonCaption
'chay ung dung bang menu cap nhat van ban'
Ctrl1.OnAction = "chon_thumuc"
'tao Menu tilte Cap nhat du lieu'
Set Ctrl2 = newMenu.Controls.Add(Type:=msoControlButton, ID:=3)
Ctrl2.FaceId = 66
Ctrl2.Caption = "Cap nhat van ban"
Ctrl2.TooltipText = "Cap nhat van ban"
Ctrl2.Style = msoButtonCaption
Ctrl2.OnAction = "capnhatvanban"
'tao Menu tilte Sap xep tang dan'
Set Ctrl3 = newMenu.Controls.Add(Type:=msoControlButton, ID:=3)
Ctrl3.FaceId = 66
Ctrl3.Caption = "&Sap xep tang dan"
Ctrl3.TooltipText = "Sap xep tang dan"
Ctrl3.Style = msoButtonCaption
Ctrl3.OnAction = "Sap_tangdan"
Set Ctrl4 = newMenu.Controls.Add(Type:=msoControlButton, ID:=1)
Divider = True
Ctrl4.Caption = "Sap xep giam dan"
Ctrl4.TooltipText = "Sap xep giam dan"
Ctrl4.Style = msoButtonCaption
'chay ung dung bang menu Tro ve trang chu'
Ctrl4.OnAction = "capnhatvanban"
Set Ctrl5 = newMenu.Controls.Add(Type:=msoControlButton, ID:=1)
Divider = True
Ctrl5.Caption = "&Luu van ban"
Ctrl5.TooltipText = "Luu van ban..."
Ctrl5.Style = msoButtonCaption
Set Ctrl6 = newMenu.Controls.Add(Type:=msoControlButton, ID:=1)
Divider = True
Ctrl6.Caption = "&In van ban"
Ctrl6.TooltipText = "In van ban"
Ctrl6.Style = msoButtonCaption
Ctrl6.OnAction = "Print"
Set Ctrl7 = newMenu.Controls.Add(Type:=msoControlButton, ID:=1)
Divider = True
Ctrl7.Caption = "&Tao van ban Word moi..."
Ctrl7.TooltipText = "Tao van ban moi"
Ctrl7.Style = msoButtonCaption
Ctrl7.OnAction = "Tao_word"
Set Ctrl8 = newMenu.Controls.Add(Type:=msoControlButton, ID:=1)
Divider = True
Ctrl8.Caption = "Loai van ban khac..."
Ctrl8.TooltipText = "Loai Van ban khac"
Ctrl8.Style = msoButtonCaption
Ctrl8.OnAction = "lienket"
Set Ctrl9 = newMenu.Controls.Add(Type:=msoControlButton, ID:=1)
Divider = True
Ctrl9.Caption = "Thoat khoi chuong trinh"
Ctrl9.TooltipText = "Exit"
Ctrl9.Style = msoButtonCaption
Ctrl9.OnAction = "nghi"
With myMenuBar
newMenu.Caption = "&Tim kiem van ban"
'tao Menu tilte Tim kiem van ban'
Ctrl1.FaceId = 23
Ctrl1.Caption = "Tim theo ngay tao"
Ctrl1.TooltipText = "Tim theo ngay tao"
'chay ung dung bang menu Tim theo ngay tao'
Ctrl1.OnAction = "tim_ngay"
Set Ctrl2 = newMenu.Controls.Add(Type:=msoControlButton, ID:=1)
Ctrl2.Divider = "TRUE"
Ctrl2.Caption = "Tim theo thang tao"
Ctrl2.TooltipText = "Tim theo thang tao"
'chay ung dung bang menu Tim theo thang tao'
Ctrl2.OnAction = "tim_thang"
Set Ctrl3 = newMenu.Controls.Add(Type:=msoControlButton, ID:=1)
Ctrl3.Divider = "TRUE"
Ctrl3.Caption = "Tim theo ngay thang nam"
Ctrl3.TooltipText = "Tim theo ngay thang nam"
Ctrl3.OnAction = "tim_ngay_thang_nam"
Set Ctrl4 = newMenu.Controls.Add(Type:=msoControlButton, ID:=3)
Ctrl4.FaceId = 66
Ctrl4.Caption = "Tim ten van ban"
Ctrl4.TooltipText = "Tim ten van ban"
Ctrl4.OnAction = "tim_noidung"
Divider = True
Ctrl5.Divider = True
Ctrl5.Caption = "Tim nguoi tham muu"
Ctrl5.TooltipText = "Tim nguoi tham muu"
Ctrl5.OnAction = "tim_thammuu"
Ctrl6.Divider = True
Ctrl6.Caption = "Tim nguoi lanh dao ky"
Ctrl6.TooltipText = "Tim nguoi lanh dao ky"
Ctrl6.OnAction = "tim_nguoiky"
Ctrl7.Divider = True
Ctrl7.Caption = "Tim so van ban"
Ctrl7.TooltipText = "Tim so van ban"
Ctrl7.OnAction = "tim_so"
Ctrl8.Divider = True
Ctrl8.Caption = "Hien thi tac ca van ban"
Ctrl8.TooltipText = "Hien thi tat ca van ban"
Ctrl8.OnAction = "khong_tim"
With myMenuBar
newMenu.Caption = "Thong tin chuong trinh"
'tao Menu tilte Tim kiem theo noi dung'
Ctrl1.FaceId = 66
Ctrl1.Caption = "Cach su dung chuong trinh"
Ctrl1.TooltipText = "&Cach su dung"
Ctrl1.OnAction = "su_dung"
Ctrl2.Divider = True
Ctrl2.Caption = "Thong tin..."
Ctrl2.TooltipText = "Thong tin..."
Ctrl2.OnAction = "thong_tin"
With myMenuBar
to thanhnhanubnb: bạn thử làm như sau xem có được ko nhé:
1/khai báo : Dim faceid as variant
2/chọn 1 sheet trong file của bạn sau đó tại ô A2 gõ vào công thức: =rand().Hàm rand sẽ trả về 1 giá trị bất kì.
Sau đó trở lại đoạn code của bạn rồi thử làm như sau:
Ctr1.faceid=cells(2,1)
'cells(2,1) là ô A2 trong sheet bạn
Còn muốn biết giá trị nào(vd: faceid=66) sẽ tương ứng với biểu tượng nào thì bạn search trên diễn đàn nhé.
thân
mình tạo thẳng trong VBA không có tạo trong sheet menu, có code nào ko, hay bạn xem và sửa dùm nhé.
thank
@ To thanhnhanubnd
Trong code của bạn có nhiều chỗ lặp lại, mình nghĩ bạn dùng With... End with sẽ hay hơn.
Bạn có thể tham khảo cách tạo Menu và gỡ bỏ Menu của John Walkenbach (Excel 2000 Power Programming With VBA)
TDN
File rất hay.Nếu muốn xóa mất thanh menu bar và toolbars chuẩn ( file,edit...) thì viết code thế nào?
Bạn Có thể dùng các codes sau
Application.CommandBars("Worksheet Menu Bar").Enabled = True / False
Application.CommandBars("Standard").Visible = True / False
Application.CommandBars("Formatting").Visible = True / False
TDN
Nếu mình True hết thì nó làm mất luộn cái Menubar mình mới tạo( mình chỉ muốn mất hết Edit, view, Data, Format, Tools< windows, Help).
Cái code phía dưới ( mình gừi hồi tối)dù hơi lung tung ben nhưng nó xóa sạch menubar
Vậy bạn hãy tham khảo thêm File sau của cùng tác giả John Walkenbach (Excel 2000 Power Programming With VBA)
TDN
Còn thanh địa chỉ ( ô và công thức), giúp mình xử nó luôn bạn nhé.
nếu xử được thì sẳn bạn làm luôn ( ẩn A, B,C.... và 1,2,3 luôn) nói chung làm màn hìn trống trơn luôn
Bạn dùng codes sau :
    ActiveWindow.DisplayHeadings = False
    Application.DisplayFormulaBar = False
TDN
