#If VBA7 Then
  Private Declare PtrSafe Function SetTimer Lib "user32" (ByVal HWnd As LongPtr, ByVal nIDEvent As LongPtr, ByVal uElapse As LongPtr, ByVal lpTimerFunc As LongPtr) As Long
  Private Declare PtrSafe Function KillTimer Lib "user32" (ByVal HWnd As LongPtr, ByVal nIDEvent As LongPtr) As Long
#Else
  Private Declare Function SetTimer Lib "user32" (ByVal HWnd As Long, ByVal nIDEvent As Long, ByVal uElapse As Long, ByVal lpTimerFunc As Long) As Long
  Private Declare Function KillTimer Lib "user32" (ByVal HWnd As Long, ByVal nIDEvent As Long) As Long
#End If
#If Win64 Then
  Private gTimerID As LongPtr
#Else
#End If
Private Args(), WorkIndex As Integer
Function S_Scraper(ByVal target As Range) As Variant
  Dim k As Integer, i%, R, t$
  Set R = Application.Caller
  S_Scraper = scraper(target(1, 1).Value)(0)
  t = R.Formula
  k = UBound(Args)
  If k > 0 Then
    For i = 1 To k
      If Args(i)(3) = t And Args(i)(1) = 0 Then
        Exit Function
  ReDim Preserve Args(1 To k + 1)
  Args(k + 1) = VBA.Array(R, 0, target, t)
  If gTimerID = 0 Then gTimerID = SetTimer(0&, 0&, 1, AddressOf S_Scraper_callback)
Private Sub S_Scraper_callback()
  Call KillTimer(0&, gTimerID): gTimerID = 0
  S_Scraper_callback2
  On Error GoTo 0
Private Sub S_Scraper_callback2()
  Dim UA%, s$, a
  UA = UBound(Args)
  If UA > 0 Then
    WorkIndex = WorkIndex + 1
    a = Args(WorkIndex)
    If a(1) = 0 And a(0).Formula = a(3) Then
      Dim R&, R1, C%, LR&, LR2&, Arr, total$(), total2$(), cols%, ub2%, t, re As Object
      LR = a(2)(a(2).Rows.Count + 2, 1).End(3).Row - a(2).Row + 1
      If LR > 0 Then
        Set R1 = a(0).Parent.UsedRange
        LR2 = R1.Row + R1.Rows.Count - 1 - a(0)(1, 1).Row
        If LR2 < LR Then LR2 = LR
        Arr = a(2)(1, 1).Resize(LR, 1).Value
        t = scraper(Arr(1, 1), re)
        ub2 = UBound(t)
        If ub2 > 0 Then
          ReDim total2(1 To ub2)
          For C = 1 To ub2
            total2(C) = t(C)
          a(0)(1, 2).Resize(1, ub2).Value = total2
        For R = 2 To LR
          t = scraper(Arr(R, 1), re)
          ub2 = UBound(t) + 1
          If ub2 > cols Then
            cols = ub2
            ReDim Preserve total(1 To LR2, 1 To cols)
          For C = 1 To ub2
            total(R - 1, C) = t(C - 1)
        a(0)(2, 1).Resize(LR2, cols).Value = total
      a(1) = 1
    If WorkIndex >= UA Then
      Erase Args: WorkIndex = 0: Set re = Nothing
      gTimerID = SetTimer(0&, 0&, 1, AddressOf S_Scraper_callback): Exit Sub
  On Error GoTo 0
Private Function scraper(ByVal text$, Optional ByRef re As Object)
  scraper = Array("")
  If re Is Nothing Then
    Set re = VBA.CreateObject("VBScript.RegExp")
    With re
      .Global = True
      .IgnoreCase = True
      .MultiLine = True
      .pattern = "([\n':-] +(\d{4,30}))|((\d{4,30}) ?[,_-])"
  Dim m, ms, t$, i%, k%, Arr()
  Set ms = re.Execute(text)
  If ms.Count Then
    ReDim Arr(ms.Count - 1)
    For i = 0 To ms.Count - 1
      For k = 0 To 1
        t = ms(i).submatches(k * 2 + 1)
        If t <> vbNullString Then
          Arr(i) = t
          Exit For
    scraper = Arr
