Giúp đỡ code VBA!!! (4 người xem)
nguyenanhdung8111982
tôi có file gốc như hình dưới
và sau khi copy ra file mới
Đây là code:
Sub ProcessMultipleFiles()
    Dim NewFileName As String
    Dim FileList As Variant, FilePath As Variant
    Dim FolderPath As String
    Dim FSO As Object
    Set FSO = CreateObject("Scripting.FileSystemObject")
    FolderPath = "D:\file_csv\"
    FileList = Array("20190928.csv", "20190927.csv")
    For Each FilePath In FileList
        FilePath = FolderPath & FilePath
        If FSO.FileExists(FilePath) Then
            NewFileName = FSO.GetBaseName(FilePath)
            NewFileName = NewFileName & "_N.csv"
            FSO.CopyFile FilePath, FolderPath & NewFileName, True
            CSVAmend2 FolderPath, NewFileName
            MsgBox FilePath & " not found"
    Next FilePath
Sub CSVAmend2(FolderPath As String, FileName As String)
    Dim wb As Workbook, ws As Worksheet, rng As Range, headers As Variant
    headers = Array("ID", "trksegID", "lat", "lon", "ele", "time", "time_N", "Heading")
    'open file (immediate save not needed)
    'Set wb = Workbooks.Open("D:\test_file\test\20200310_07_002_QTB_GS023662-gps.csv")
    Set wb = Workbooks.Open(FolderPath & FileName)
    'wb.SaveAs ("D:\test_file\test\20200310_07_002_QTB_GS023662.csv")
    Set ws = wb.Sheets(1)
    Set rng = ws.Range("A2", ws.Range("A" & ws.Rows.Count).End(xlUp))
    'add time columns
    With rng.Offset(, 8)
        .Formula = "=F2"
        .Value = .Value
        .Offset(, 8).Value = .Value
        .Formula = "=A2"
        .Value = .Value
        .Offset(, 6).Value = .Value
         .Offset(, 6).NumberFormat = "yyyy/mm/dd hh:mm:ss"
        .Formula = "=A2+ TIME(7,0,0)"
        .Offset(, 7).Value = .Value
        .Offset(, 7).NumberFormat = "yyyy/mm/dd hh:mm:ss"
    'add ID columns
    ws.Range("B:B").Insert Shift:=xlToRight, CopyOrigin:=xlFormatFromLeftOrAbove
    rng.Formula = "=row()-1"
    rng.Offset(, 1).Value = 1
    'delete columns not required and insert headers
    ws.Range("F:O").Delete Shift:=xlToLeft
    ws.Range("A1:H1").Value = headers
    ActiveSheet.Range("A2:H50000").RemoveDuplicates Columns:=6, Header:=xlYes
    'save and close
    'wb.Save
    wb.Close SaveChanges:=True                        'False
Nhờ mọi người giúp đỡ chỉnh sửa code để
cột "ID" là số thứ tự tăng dần theo dòng cột A
,cột "trksegID" giá trị luôn =1
link file:
Theo tôi đoán thì cột A đã tăng số thứ tự lần lượt từ 1 đến hết, cột B đã có giá trị mặc định bằng 1. Vấn đề chỉ là định dạng thôi. Bạn cho cột A và B định dạng General là xong.
định dạng sao bạn, khi chạy nó ra kết quả không đúng, bạn sửa giúp mình
Đoạn code này đã làm theo yêu cầu của bạn rồi. Vấn đề chỉ là ĐỊNH DẠNG SỐ.[/php]
Tên chủ đề:
Giúp đỡ code VBA!!!
Thì cả đống
Dạ, nhưng em không biết định dạng sao cho ra đúng
Đăng bài lộn tiệm (hỏi VBA đăng trong hàm).
Tiêu đề không rõ ràng.
Cám ơn anh, em đã dò lại đúng là định dạng bị sai, em sửa lại chạy ra đúng rồi. A cho em hỏi thêm xíu là lúc em định dạng thời gian theo format:
"yyyy-mm-dd hh:mm:ss" thì nó hiển thị không đúng. nó vẫn hiển thị "yyyy/mm/dd hh:mm:ss". Nếu em chỉnh khoảng trắng trước năm thì hiển thị đúng " yyyy/mm/dd hh:mm:ss".
        .Formula = "=A2"
        .Value = .Value
        .Offset(, 6).NumberFormat = "yyyy-mm-dd hh:mm:ss"
Không hiểu ý của bạn. Đoạn code .Offset(, 6).NumberFormat = "yyyy-mm-dd hh:mm:ss" không sai gì cả.
Cột A2 ngay từ đầu nó là định dạng ngày tháng, có cách nào ngay từ đầu mình dùng công thức hay hàm nào cho nó về General không anh.
Có thể giá trị đang nhận là text. Thử sửa đoạn code này:
.Offset(, 6).Value = .Value * 1
K
không được anh ơi. File gốc em định dạng lại file là General. em sửa lại code
    Dim FSO As Object
    FolderPath = "C:\Users\dungna\Desktop\Vidu\"
    FileList = Array("GS033690.csv")
            NewFileName = NewFileName & "_Heading.csv"
    Next FilePath
        .Formula = "=F2"
        .Value = .Value
        .Formula = "=A2"
        .Value = .Value
        .Value = .Value
        .Offset(, 7).NumberFormat = "yyyy-mm-dd hh:mm:ss"
    ActiveSheet.Range("A1:H50000").RemoveDuplicates Columns:=6, Header:=xlYes
Nhưng khi chạy xóa giá trị trùng chỉ giữ lại 1 nó không xóa hết giá trị trùng cột time
