Chào cả nhà GPE. Nhờ mọi người sửa dùm mình sao mình gõ tên hàng là "Bang dien" mà sao không tìm thấy. Em xin chân thành cảm ơn
Code này của bác Hiếu CD tại bài này https://www.giaiphapexcel.com/diend...c-dữ-liệu-siêu-tốc-khoảng-10-000-dòng.131143/
Code:
Code:
Dim Dic As Object, Test As Boolean, sArr As Variant
Private Sub ListBox1_KeyDown(ByVal KeyCode As MSForms.ReturnInteger, ByVal Shift As Integer)
If KeyCode = 13 Then
Range("N4").Value = ListBox1.Value
If Range("N4").Value > 0 Then
Range("O4").Value = ListBox1.List(ListBox1.ListIndex, 0)
Dim i As Long
i = Range("O4").Value + 3
Unload Me
Range("c" & i).Select
Private Sub TextBox1_Change()
If Range("B4") <> "" Then
Locspeedtocdo
Private Sub Locspeedtocdo()
Dim arr(), dArr(), i As Long, k As Long, dk As String, lcol As Byte
If Test = False Then Call Add_Dic
If Not IsArray(sArr) Then Call Add_Data
dk = Up_TV_KhongDau(UCase(TextBox1.Value))
lcol = UBound(sArr, 2)
ReDim arr(1 To 1)
For i = 1 To UBound(sArr)
If sArr(i, lcol) Like "*" & dk & "*" Then
ReDim Preserve arr(1 To k)
arr(k) = i
ReDim dArr(1 To k, 1 To lcol - 1)
For i = 1 To UBound(arr)
For J = 1 To lcol - 1
dArr(i, J) = sArr(arr(i), J)
Next J
ListBox1.Clear
ListBox1.ColumnCount = lcol
ListBox1.List = dArr
Private Sub Add_Data()
Dim dArr As Variant, Tmp As String, i As Long, k As Long, lcol As Byte
If Range("c5003") = "" Then
i = Range("c5003").End(xlUp).Row ' O cuoi cot ben Trai
i = 5003
dArr = Range("a4:g" & i).Value ' Vung can Tim kiem
lcol = UBound(dArr, 2)
ReDim sArr(1 To UBound(dArr), 1 To lcol + 1)
For i = 1 To UBound(dArr)
Tmp = dArr(i, 3) ' loc theo cot Ten hang
Tmp = Up_TV_KhongDau(UCase(Tmp))
sArr(k, lcol + 1) = Tmp
For J = 1 To lcol
sArr(k, J) = dArr(i, J)
Next J
Private Sub Add_Dic()
Dim CharCode, ResText As String, i As Byte
CharCode = Array(ChrW(7855), ChrW(7857), ChrW(7859), ChrW(7861), ChrW(7863), ChrW(7845), ChrW(7847), _
ChrW(7849), ChrW(7851), ChrW(7853), ChrW(225), ChrW(224), ChrW(7843), ChrW(227), ChrW(7841), _
ChrW(259), ChrW(226), ChrW(273), ChrW(7871), ChrW(7873), ChrW(7875), ChrW(7877), ChrW(7879), _
ChrW(233), ChrW(232), ChrW(7867), ChrW(7869), ChrW(7865), ChrW(234), ChrW(237), ChrW(236), _
ChrW(7881), ChrW(297), ChrW(7883), ChrW(7889), ChrW(7891), ChrW(7893), ChrW(7895), ChrW(7897), _
ChrW(7899), ChrW(7901), ChrW(7903), ChrW(7905), ChrW(7907), ChrW(243), ChrW(242), ChrW(7887), _
ChrW(245), ChrW(7885), ChrW(244), ChrW(417), ChrW(7913), ChrW(7915), ChrW(7917), ChrW(7919), _
ChrW(7921), ChrW(250), ChrW(249), ChrW(7911), ChrW(361), ChrW(7909), ChrW(432), ChrW(253), _
ChrW(7923), ChrW(7927), ChrW(7929), ChrW(7925))
ResText = "aaaaaaaaaaaaaaaaadeeeeeeeeeeeiiiiiooooooooooooooooouuuuuuuuuuuyyyyy"
For i = 0 To UBound(CharCode)
'Dic.Add CharCode(i), Mid(ResText, i + 1, 1)
Dic.Add UCase(CharCode(i)), UCase(Mid(ResText, i + 1, 1))
Test = True
Private Function Up_TV_KhongDau(ByVal Text As String) As String ' bo dau tieng viet
Dim i As Long, key As String
If Len(Text) = 0 Then Up_TV_KhongDau = "": Exit Function
For i = 1 To Len(Text)
key = Mid(Text, i, 1)
If Dic.exists(key) Then Mid(Text, i, 1) = Dic.Item(key)
Up_TV_KhongDau = Text
