iloveit
- Giới tính
- Nam
- Nghề nghiệp
- Tự do
Tôi có một file Excel như đính kèm dưới đây. Trong file có các đoạn code VBA nhưng tôi cũng chưa hiểu quy luật nào để lấy ra số CD Key.
Tôi gửi file đính kèm nhờ mọi người giải thích giúp. Cám ơn!
Sub GetID()
Dim fso As Object, Drv As Object
Dim sComm As String, tmpFile, biosSN
'LAY BIOS
If DriveLetter <> "" Then
Set Drv = fso.GetDrive(DriveLetter)
Set Drv = fso.GetDrive(fso.GetDriveName(Application.path))
With Drv
If .IsReady Then
DriveSerial = Abs(.SerialNumber)
DriveSerial = -1
Set Drv = Nothing
Set fso = Nothing
'Range("C3").Value = DriveSerial
'LAY BIOS
Set objWMIService = GetObject("winmgmts:\\.\root\cimv2")
Set colItems = objWMIService.ExecQuery("Select * from Win32_Processor")
For Each objItem In colItems
Range("I15").Value = DriveSerial & Range("A12").Value
'MsgBox "DI 1: " & DriveSerial & "ID 2:" & objItem.ProcessorId
Sub I10100110()
Dim O00000111, O10111111, O11000100 As Variant
O10111111 = Sheets("S10001000").Cells(I01100011("O00000100"), I01100011("O00001001")).Value
If Worksheets("S10001000").Cells(I01100011("O00001001"), I01100011("O00000100")).Value = 5 Then
MsgBox "Ban da dang ky su dung cho 5 may"
Exit Sub
Call I00011110
O11000100 = Sheets("S10001000").Cells(I01100011("O00000001"), I01100011("O00000001")).Value
O00000111 = Mid(O10111111, I01100011("O00000010"), I01100011("O00000001"))
O00000111 = O00000111 & Mid(O10111111, I01100011("O00000101"), I01100011("O00000001"))
O00000111 = O00000111 & Mid(O10111111, I01100011("O00000011"), I01100011("O00000001"))
O00000111 = O00000111 & Mid(O10111111, I01100011("O00001001"), I01100011("O00000001"))
O00000111 = O00000111 & Mid(O10111111, I01100011("O00001101"), I01100011("O00000001"))
O00000111 = O00000111 & Mid(O10111111, I01100011("O00001011"), I01100011("O00000001"))
O00000111 = O00000111 & Mid(O10111111, I01100011("O00000110"), I01100011("O00000001"))
O00000111 = O00000111 & Mid(O10111111, I01100011("O00001000"), I01100011("O00000001"))
If O00000111 = O11010000 Or O00000111 = O00000001 Or O00000111 = O00011111 Then
O01011001 = I01100011("O00000001")
O01011001 = I01100011("O00000000")
O00011110 = I01100011("O00000000")
Call I10011000
Call I11100000
Sub I10011000()
O00000111 = Mid(O10111111, I01100011("O00000111"), I01100011("O00000001"))
O00000111 = O00000111 & Mid(O10111111, I01100011("O00001100"), I01100011("O00000001"))
O00000111 = O00000111 & Mid(O10111111, I01100011("O00001010"), I01100011("O00000001"))
O00000111 = O00000111 & Mid(O10111111, I01100011("O00000100"), I01100011("O00000001"))
If O00000111 = Mid(O11000100, I01100011("O00001101"), I01100011("O00000100")) Then
O00011110 = I01100011("O00000001")
Sub I11100000()
If O01011001 = I01100011("O00000001") And O00011110 = I01100011("O00000001") Then
Worksheets("S10001000").Range("A3").Offset(I01100011("O00000001") + Worksheets("S10001000").Cells(I01100011("O00001001"), I01100011("O00000100")).Value, 0).Value = Worksheets("S10001000").Cells(I01100011("O00000001"), I01100011("O00000001")).Value
Worksheets("S01111111").Activate
Worksheets("S01111111").Visible = True
Worksheets("S10001000").Visible = xlVeryHidden
MsgBox "DANG KY THANH CONG"
' text = "" & ChrW$(272) & ChrW$(258) & "NG K" & ChrW$(221) & " TH" & ChrW$(192) & "NH C" & ChrW$(212) & "NG!"
' MsgBoxUni text
Sheets("S10001000").Cells(I01100011("O00000100"), I01100011("O00001001")).Value = ""
O10000010 = I01100011("O00000001")
Sheets("S10001000").Cells(I01100011("O00000100"), I01100011("O00001101")).Value = ""
If Sheets("S00100111").Cells(I01100011("O00000100"), I01100011("O00001101")).Value = "" Then
Sheets("S00100111").Cells(I01100011("O00000100"), I01100011("O00001101")).Value = I01100011("O00000001")
Sheets("S00100111").Cells(I01100011("O00000100"), I01100011("O00001101")).Value = Sheets("S00100111").Cells(I01100011("O00000100"), I01100011("O00001101")).Value + I01100011("O00000001")
MsgBox " SAI MA XAC NHAN,NHAP LAI"
' text = "SAI M" & ChrW$(195) & " X" & ChrW$(193) & "C NH" & ChrW$(7852) & "N! VUI L" & ChrW$(210) & "NG NH" & ChrW$(7852) & "P L" & ChrW$(7840) & "I"
' MsgBoxUni text
O10000010 = I01100011("O00000000")
