Lỗi run time error 91 (mới xuất hiện, trước vẫn dùng bình thường) !!! (3 người xem)
  • Thread starter Thread starter Miccpro
Miccpro
Em có sưu tầm được 1 đoạn code trên GPE như sau:
Sub GetdatawebAccuweather(ByVal Tram As String, fDate As Date, eDate As Date)
    Dim hrq As Object, html As Object, url As String, dated As Date, row As Object, cell As Object, a As Object, reg As Object, str As String, id As String
    Dim i As Long, j As Long, k As Long, nmonth As Long, wf As WorksheetFunction, url2 As String, url3 As String, id2 As String, lcal As String
    Dim dArr(), dArr1(), R As Long
    Dim Dk As Boolean
    Set wf = WorksheetFunction: Set hrq = CreateObject("msxml2.xmlhttp"): Set html = CreateObject("htmlfile")
    url = "https://www.accuweather.com/vi/vn/thai-binh/356177/january-weather/356177?monyr="
    R = Range("A" & Rows.count).End(xlUp).row + 1
    If R > 5 Then Sheet15.Range("K12:N" & R).ClearContents
    R = eDate - fDate + 1:        ReDim dArr(1 To R, 1 To 8):  ReDim dArr1(1 To R, 1 To 4)
    With hrq
        .Open "POST", "https://www.accuweather.com/vi/search-locations", False
        .setRequestHeader "Content-Type", "application/x-www-form-urlencoded"
        .send "s=" & Tram
        Do While .readystate <> 4
            DoEvents
        Loop
        html.body.innerhtml = .responsetext
    Dim RX As Object
    Set RX = CreateObject("vbscript.regexp")
    RX.Pattern = "^(?:https://www.accuweather.com)/.+/(\w+)/[^\/]+/(\w+)$": RX.Global = True
    For Each a In html.getelementsbytagname("a")
        If RX.Test(a.href) And (a.innertext Like "*" & Tram & "*" Or a.innertext Like "*" & Split(Tram, ",")(0) & "*") Then '
            id = RX.Replace(a.href, "$1")
            id2 = RX.Replace(a.href, "$2")
    RX.Global = True
    RX.Pattern = "\/\d+"
    url2 = Replace(Replace(RX.Replace(url, "@@"), "@@", "/" & id, , 1), "@@", "/" & id2)
    For nmonth = 0 To DateDiff("m", wf.EoMonth(fDate, -1) + 1, wf.EoMonth(eDate, 0) + 1)
        url3 = url2 & Format(wf.eDate(fDate, nmonth), "m/d/yyyy") & "&view=table"
        With hrq
            .Open "GET", url3, False
            .send
                DoEvents
            Loop
        For Each row In html.getelementsbytagname("tbody")(0).Rows
            dated = DateValue(Split(Trim(row.Cells(0).innertext), " ")(1) & "/" & Year(wf.eDate(fDate, nmonth)))
            If dated >= fDate And dated <= eDate Then
                i = i + 1: j = 0: k = k + 1
                For Each cell In row.Cells
                    j = j + 1
                    dArr(i, j) = cell.innertext:
    Next nmonth
    Sheet15.Range("K12").Resize(k, 4) = dArr1
    Set hrq = Nothing:    Set html = Nothing
    Set RX = Nothing
Trước giờ em chạy bình thường, hôm nay chạy báo lỗi "run time error 91 object variable or with block variable not set" ở dòng:
Em chuyển file sang máy tính khác vẫn bị. Mong các anh chị giúp đỡ, em xin cảm ơn
    Dim Dk As Boolean
    With hrq
        .send "s=" & Tram
            DoEvents
        Loop
    Dim RX As Object
    RX.Global = True
        With hrq
            .send
                DoEvents
            Loop
                    j = j + 1
    Next nmonth
    Set RX = Nothing
Bạn phải cho biết bạn chạy sub với tham số nào thì người ta mới chạy thử và biết lỗi được chứ?
Như vậy có thể do https://www.accuweather.com thay đổi "cái gì đó" phải không bác? Bác có cách nào sửa giúp em không ạ, mục đích cái này em dùng file này để lấy thông số thời tiết của 1 trạm trong khoảng thời gian nào đó. Mong bác giúp đỡ
em cũng muốn dùng file này nhưng giờ bị lỗi, không biết các bác đã ai sửa được lỗi như trên chưa ạ. Em cảm ơn
