Giúp mình code kiểm tra khi thêm Item trong Listbox (1 người xem)
  • Thread starter Thread starter quyenpv
quyenpv
Thu nhặt kiến thức
Decode cuộc đời!
Private Sub cmdAdd_Tinh_Click()
    Dim StrPath As String
    StrPath = Application.GetOpenFilename(VNI("Teäp tin Ñôn giaù") & "(*.xls),*.xls,All Files (*.*),*.*", 1, VNI("Choïn teäp tin Ñôn giaù"), VNI("Môû"), False)
    If StrPath = "False" Then Exit Sub
    If SheetExist(get_Foldername_ofpath(StrPath), Get_FileName(StrPath), "Infor") = False Then
        ShowHelp VNI("File [" & Get_FileName(StrPath) & "] khoâng thuoäc kieåu döõ lieäu cuûa chöông trình"), 116
        Exit Sub
    If Kiemtra_Duongdan(get_Foldername_ofpath(StrPath) & "\Infor.ini") = False Then
        ShowHelp VNI("Baïn vui loøng kieåm tra laïi file thoâng tin ñôn giaù keøm theo döõ lieäu"), 117
        Exit Sub
    '- Kiem tra xem co trung so voi du lieu mac dinh
    If lb1.ListCount > 0 Then
        For i = 1 To lb1.ListCount
            If Replace(lb1.List(i), "*", "", 1, -1, vbTextCompare) Like StrPath Then
                ShowWarning VNI("Ñöông daãn : [" & StrPath & "] ñaõ coù. Baïn vui loøng choïn laïi ñöôøng daãn khaùc")
                Exit Sub
    'Kiem tra trung so voi du lieu Dung chung
    Dim tmpDG As String
            tmpDG = Replace(lb1.List(i), "#[0]", "", 1, -1, vbTextCompare)
            tmpDG = Replace(tmpDG, "#[1]", "", 1, -1, vbTextCompare)
            tmpDG = Replace(tmpDG, "#[2]", "", 1, -1, vbTextCompare)
            tmpDG = Replace(tmpDG, "#[3]", "", 1, -1, vbTextCompare)
'            tmpDG = Replace(tmpDG, "#[4]", "", 1, -1, vbTextCompare)
            If tmpDG Like StrPath Then
                Exit Sub
        Exit Sub
        Exit Sub
    If lb1.ListCount = 0 Then
        lb1.AddItem "**" & StrPath
        '- Nap thong tin vao file ConfigRibbon
        Dim strInfor As String
        strInfor = get_Foldername_ofpath(StrPath) & "\Infor.ini"
        With ThisWorkbook.Sheets("Config_Ribbon")
            .Range("B118").Value = Write_Ini_Excel(strInfor, "Thongtin", "DG:", "DG")
            .Range("B119").Value = Write_Ini_Excel(strInfor, "Thongtin", "DM:", "DM")
            .Range("B120").Value = Write_Ini_Excel(strInfor, "Thongtin", "TDVT:", "TDVT")
            .Range("B121").Value = Write_Ini_Excel(strInfor, "Thongtin", "GVT:", "GVT")
            .Range("B122").Value = Write_Ini_Excel(strInfor, "Thongtin", "PLV:", "PLV")
            .Range("B123").Value = Write_Ini_Excel(strInfor, "Thongtin", "CVC:", "CVC")
            .Range("B124").Value = Write_Ini_Excel(strInfor, "Thongtin", "TDCM:", "TDCM")
        lb1.AddItem StrPath
Mình có đoạn code này, khi thêm đường dẫn 1 file vào Listbox. Mục đích sẽ kiểm tra có chọn trùng file trước đó không thì bị báo lỗi
Mong anh chị em ghé qua giúp đỡ
    88.7 KB · Đọc: 7
    83.1 KB · Đọc: 7
For i = 0 To lb1.ListCount - 1
ShowWarning VNI("Nöông daan : [" & StrPath & "] nao cou. Bain vui loong choin laii nöôong daan khauc")
Exit Sub
Những chỗ giống thế sửa tương tự. Tại sao? Xem hình. Có một kho kiến thức nằm ngay trong tầm tay mà bỏ đấy thì quá phí hoài.list.JPG
Những chỗ giống thế sửa tương tự. Tại sao? Xem hình. Có một kho kiến thức nằm ngay trong tầm tay mà bỏ đấy thì quá phí hoài.View attachment 213476
Không đúng, trong List của em có giá trị rồi, bây giờ thêm giá trị muốn kiểm tra nó có trung với giá trị đã có trong Listbox không thì xuất hiện lỗi
Thanks a, em không để ý chỗ biến chạy Vòng lặp for
    20 KB · Đọc: 8
Cảm ơn a, em không để ý chỗ biến chạy Vòng lặp for
