Mấy anh xem giúp em code này khi xóa dữ liệu củ thì báo lỗi run time "13" tyle mismatch và code dừng không chạy nữa.
Dim MaTP As String
Dim lastRowDM As Integer, RowCount As Integer, i As Integer, j As Integer
Dim DataArr As Variant
'Kiem tra xem có phai thay doi tren cot C hay khong
If Target.Column = 3 Then
'Lay thong so dau vao
MaTP = Target.Value
lastRowDM = Sheets("DM_NVL").Range("D" & Rows.Count).End(xlUp).Row
RowCount = WorksheetFunction.CountIf(Sheets("DM_NVL").Range("D21
" & lastRowDM), MaTP)
'Kiem tra dieu kien co so lieu
If RowCount > 0 Then
'Chen so dong trong de dien dinh muc tuong ung
Sheets("XUAT_VT").Range(Target.Row + 1 & ":" & Target.Row + RowCount - 1).Insert Shift:=xlDown, CopyOrigin:=xlFormatFromLeftOrAbove
'Dien so lieu
DataArr = Sheets("DM_NVL").Range("D21:J" & lastRowDM).Value
For i = LBound(DataArr, 1) To UBound(DataArr, 1)
If DataArr(i, 1) = MaTP Then
Sheets("XUAT_VT").Range("C" & Target.Row + j).Value = MaTP
Sheets("XUAT_VT").Range("E" & Target.Row + j).Value = DataArr(i, 2)
Sheets("XUAT_VT").Range("F" & Target.Row + j).Value = DataArr(i, 3)
Sheets("XUAT_VT").Range("G" & Target.Row + j).Value = DataArr(i, 4)
Sheets("XUAT_VT").Range("J" & Target.Row + j).Value = DataArr(i, 7)
j = j + 1
Dim MaTP As String
MaTP = Target.Value
'Dien so lieu
j = j + 1
