nhờ chỉnh sửa code trích lọc dữ liệu (1 người xem)
huonglien1901
GPE là ngôi nhà thứ 2 của tôi!!!
Nhân viên kỹ thuật in ấn
Sub Macro1()
' Macro1 Macro
' Keyboard Shortcut: Ctrl+x
    Selection.Insert Shift:=xlToRight
    Windows("filemau.xls").Activate
    Range("G1:H1").Select
    Selection.Copy
    Windows("Document.xls").Activate
    Range("G1").Select
    ActiveSheet.Paste
    Rows("1:1").RowHeight = 51
    Columns("A:A").EntireColumn.AutoFit
    Columns("B:B").EntireColumn.AutoFit
    Columns("C:C").EntireColumn.AutoFit
    Columns("D:D").EntireColumn.AutoFit
    Columns("E:E").EntireColumn.AutoFit
    Columns("F:F").EntireColumn.AutoFit
    Columns("G:G").EntireColumn.AutoFit
    Columns("H:H").EntireColumn.AutoFit
    Columns("I:I").EntireColumn.AutoFit
    Columns("J:J").EntireColumn.AutoFit
    Application.PrintCommunication = False
    With ActiveSheet.PageSetup
        .PrintTitleRows = "$1:$1"
        .PrintTitleColumns = ""
    Application.PrintCommunication = True
    ActiveSheet.PageSetup.PrintArea = "$B$1:$J$1"
        .LeftHeader = ""
        .CenterHeader = ""
        .RightHeader = ""
        .LeftFooter = ""
        .CenterFooter = ""
        .RightFooter = ""
        .LeftMargin = Application.InchesToPoints(0.75)
        .RightMargin = Application.InchesToPoints(0.75)
        .TopMargin = Application.InchesToPoints(1)
        .BottomMargin = Application.InchesToPoints(1)
        .HeaderMargin = Application.InchesToPoints(0.5)
        .FooterMargin = Application.InchesToPoints(0.5)
        .PrintHeadings = False
        .PrintGridlines = False
        .PrintComments = xlPrintNoComments
        .PrintQuality = 600
        .CenterHorizontally = False
        .CenterVertically = False
        .Orientation = xlPortrait
        .Draft = False
        .PaperSize = xlPaperA4
        .FirstPageNumber = xlAutomatic
        .Order = xlDownThenOver
        .BlackAndWhite = False
        .Zoom = 100
        .PrintErrors = xlPrintErrorsDisplayed
        .OddAndEvenPagesHeaderFooter = False
        .DifferentFirstPageHeaderFooter = False
        .ScaleWithDocHeaderFooter = True
        .AlignMarginsHeaderFooter = True
        .EvenPage.LeftHeader.Text = ""
        .EvenPage.CenterHeader.Text = ""
        .EvenPage.RightHeader.Text = ""
        .EvenPage.LeftFooter.Text = ""
        .EvenPage.CenterFooter.Text = ""
        .EvenPage.RightFooter.Text = ""
        .FirstPage.LeftHeader.Text = ""
        .FirstPage.CenterHeader.Text = ""
        .FirstPage.RightHeader.Text = ""
        .FirstPage.LeftFooter.Text = ""
        .FirstPage.CenterFooter.Text = ""
        .FirstPage.RightFooter.Text = ""
    Columns("A:J").Select
        .LeftHeader = ""
        .CenterHeader = ""
        .RightHeader = ""
        .LeftFooter = ""
        .CenterFooter = ""
        .RightFooter = ""
        .PrintQuality = 600
        .Draft = False
        .Zoom = False
        .FitToPagesWide = 1
        .FitToPagesTall = 0
        .LeftHeader = ""
        .CenterHeader = ""
        .RightHeader = ""
        .LeftFooter = ""
        .CenterFooter = ""
        .RightFooter = ""
        .LeftMargin = Application.InchesToPoints(0.25)
        .RightMargin = Application.InchesToPoints(0.25)
        .TopMargin = Application.InchesToPoints(0.75)
        .BottomMargin = Application.InchesToPoints(0.75)
        .HeaderMargin = Application.InchesToPoints(0.3)
        .FooterMargin = Application.InchesToPoints(0.3)
        .PrintQuality = 600
        .Draft = False
        .Zoom = False
        .FitToPagesWide = 1
        .FitToPagesTall = False
        .LeftHeader = ""
        .CenterHeader = ""
        .RightHeader = ""
        .LeftFooter = ""
        .CenterFooter = "Page &P of &N"
        .RightFooter = ""
        .PrintQuality = 600
        .Draft = False
        .Zoom = False
        .FitToPagesWide = 1
    Selection.PrintOut Copies:=1, Collate:=True
Em có đoạn code trên khi chạy code(đối với file tên document) nó mới chạy.
Em muốn nhờ mọi người hỗ trợ cho trường hợp tổng quát là file có chứa phân vùng nào thì code vẫn chạy.
Em cảm ơn mọi người nhiều!
Sub Macro1()
' Macro1 Macro
    Selection.Copy
    Range("G1").Select
    ActiveSheet.Paste
        .LeftHeader = ""
        .CenterHeader = ""
        .RightHeader = ""
        .LeftFooter = ""
        .CenterFooter = ""
        .RightFooter = ""
        .PrintQuality = 600
        .Draft = False
        .Zoom = 100
        .LeftHeader = ""
        .CenterHeader = ""
        .RightHeader = ""
        .LeftFooter = ""
        .CenterFooter = ""
        .RightFooter = ""
        .PrintQuality = 600
        .Draft = False
        .Zoom = False
        .FitToPagesWide = 1
        .FitToPagesTall = 0
        .LeftHeader = ""
        .CenterHeader = ""
        .RightHeader = ""
        .LeftFooter = ""
        .CenterFooter = ""
        .RightFooter = ""
        .PrintQuality = 600
        .Draft = False
        .Zoom = False
        .FitToPagesWide = 1
        .LeftHeader = ""
        .CenterHeader = ""
        .RightHeader = ""
        .LeftFooter = ""
        .RightFooter = ""
        .PrintQuality = 600
        .Draft = False
        .Zoom = False
        .FitToPagesWide = 1
thì đúng là như vậy mà code bạn chỉ mở file document thôi mà nên nó chỉ thực hiện thế là đúng rồi.bạn còn muốn gì nữa.
Em muốn đối với các phân vùng như A01, A02 thì code sẽ chạy, vậy trường hợp này sửa code sao Anh?
Đối với file có tên là PR01 thì file sẽ có 2 cột
2nd count result (So luong kiem dem lan 2)
Verification (Signature)
hai cột này nằm giữa cột Quanlity và Cột Division đó Anh.
không hiểu lắm bạn nói rõ ý cụ thể đi.
Yêu cầu của em cần làm là:
1: Làm thế nào khi mở file có tên những ký tự như A,B,C....................có kết hợp với ký tự số như 01, 02, 03.....,thì file này sẽ có 2 cột
hai cột này nằm giữa cột Quanlity và Cột Division đó Anh .
2: 2 cột này sẽ lấy từ file mẫu.
Code này sẽ tự động in như @#1 em đã record macro lại.
Sub Macro1()
' Macro1 Macro
    Selection.Copy
    Range("G1").Select
    ActiveSheet.Paste
        .LeftHeader = ""
        .CenterHeader = ""
        .RightHeader = ""
        .LeftFooter = ""
        .CenterFooter = ""
        .RightFooter = ""
        .PrintQuality = 600
        .Draft = False
        .Zoom = 100
        .LeftHeader = ""
        .CenterHeader = ""
        .RightHeader = ""
        .LeftFooter = ""
        .CenterFooter = ""
        .RightFooter = ""
        .PrintQuality = 600
        .Draft = False
        .Zoom = False
        .FitToPagesWide = 1
        .FitToPagesTall = 0
        .LeftHeader = ""
        .CenterHeader = ""
        .RightHeader = ""
        .LeftFooter = ""
        .CenterFooter = ""
        .RightFooter = ""
        .PrintQuality = 600
        .Draft = False
        .Zoom = False
        .FitToPagesWide = 1
        .LeftHeader = ""
        .CenterHeader = ""
        .RightHeader = ""
        .LeftFooter = ""
        .RightFooter = ""
        .PrintQuality = 600
        .Draft = False
        .Zoom = False
        .FitToPagesWide = 1
Chọn file cần insert 2 cột, chạy code bằng phím tắt
Xem lại lệnh in có đúng không? và tự chỉnh
Sub Macro1()
' Macro1 Macro
  Dim wb As Workbook, sh As Worksheet
  Set wb = ActiveWorkbook
  If wb.Name <> ThisWorkbook.Name Then
    With wb.ActiveSheet
      .Columns("G:H").Insert Shift:=xlToRight
      ThisWorkbook.ActiveSheet.Range("G1:H1").Copy Destination:=.Range("G1:H1")
      .Rows("1:1").RowHeight = 51
      .Columns("A:J").EntireColumn.AutoFit
      With .PageSetup
      With .PageSetup
        .LeftHeader = ""
        .CenterHeader = ""
        .RightHeader = ""
        .LeftFooter = ""
        .RightFooter = ""
        .PrintQuality = 600
        .Draft = False
        .Zoom = False
        .FitToPagesWide = 1
Sub Macro1()
' Macro1 Macro
    With wb.ActiveSheet
      With .PageSetup
      With .PageSetup
        .LeftHeader = ""
        .CenterHeader = ""
        .RightHeader = ""
        .LeftFooter = ""
        .RightFooter = ""
        .PrintQuality = 600
        .Draft = False
        .Zoom = False
        .FitToPagesWide = 1
Em cảm ơn Anh!
Nhưng khi in ra thì chỉ có cột B thôi, Em muốn lấy tất cả dữ liệu.
Sub Macro1()
' Macro1 Macro
    With wb.ActiveSheet
      With .PageSetup
      With .PageSetup
        .LeftHeader = ""
        .CenterHeader = ""
        .RightHeader = ""
        .LeftFooter = ""
        .RightFooter = ""
        .PrintQuality = 600
        .Draft = False
        .Zoom = False
        .FitToPagesWide = 1
anh ơi code thì đúng rồi đó Anh.nhưng lệnh in ra mới lấy cột B thôi. Em muốn lấy hết dữ liệu luôn. Tại sao khi em định dạng header chọn ngày tháng khi chạy code nó không hiển thị.
