duong22000
Code VBA em đang dùng:
Sub XeptenABC()
Dim n As Long
n = Sheet2.[c65000].End(3).Row
Range("do7:do" & n).FormulaR1C1 = "=MahoaUNI(TachTen(RC3,3))"
Range("dp7:dp" & n).FormulaR1C1 = "=MahoaUNI(TachTen(RC3,2))"
Range("dq7:dq" & n).FormulaR1C1 = "=MahoaUNI(tachten(RC3,1))"
Range("B7:dq" & n).Sort Key1:=[do7], Order1:=1, Key2:=[dp7], Order2:=1, Key3:=[dq7], Order3:=1, Header:=xlNo
Range("do7:dq" & n).Clear
MsgBox "Da xep xong!"
Function TachTen(str As String, Optional Op As Long = 3)
With CreateObject("vbscript.regexp")
.Global = True
.Pattern = "(\S+)( .+ | )(\S+$)"
TachTen = Trim(.Execute(Trim(str))(0).SubMatches(Op - 1))
Public Function MahoaUNI(S) As String
Dim x, Sb, k, mu, skdau, sdau, Bdau, Bkdau As String
Dim i, m, n, dau, idau, ikdau As Integer
If IsNull(S) Then
Exit Function
ElseIf IsNumeric(S) Then
Sb = S
S = Trim(S)
S = LCase(S) & ChrW(32)
skdau = ChrW(259) & ChrW(234) & ChrW(244) & ChrW(432) & ChrW(273) & ChrW(226) & ChrW(417)
Bkdau = "aeoudao"
sdau = ChrW(225) & ChrW(224) & ChrW(7843) & ChrW(227) & ChrW(7841) _
& ChrW(233) & ChrW(232) & ChrW(7867) & ChrW(7869) & ChrW(7865) _
& ChrW(237) & ChrW(236) & ChrW(7881) & ChrW(297) & ChrW(7883) _
& ChrW(243) & ChrW(242) & ChrW(7887) & ChrW(245) & ChrW(7885) _
& ChrW(250) & ChrW(249) & ChrW(7911) & ChrW(361) & ChrW(7909) _
& ChrW(253) & ChrW(7923) & ChrW(7927) & ChrW(7929) & ChrW(7925) _
& ChrW(7855) & ChrW(7857) & ChrW(7859) & ChrW(7861) & ChrW(7863) _
& ChrW(7889) & ChrW(7891) & ChrW(7893) & ChrW(7895) & ChrW(7897) _
& ChrW(7871) & ChrW(7873) & ChrW(7875) & ChrW(7877) & ChrW(7879) _
& ChrW(7913) & ChrW(7915) & ChrW(7917) & ChrW(7919) & ChrW(7921) _
& ChrW(7845) & ChrW(7847) & ChrW(7849) & ChrW(7851) & ChrW(7853) _
& ChrW(7899) & ChrW(7901) & ChrW(7903) & ChrW(7905) & ChrW(7907)
Bdau = "aaaaaeeeeeiiiiiooooouuuuuyyyyyaaaaaoooooeeeeeuuuuuaaaaaooooo"
For m = 1 To Len(S)
k = Mid(S, m, 1)
idau = InStr(1, sdau, k, 0)
ikdau = InStr(1, skdau, k, 0)
If idau > 0 Then
k = Mid(Bdau, idau, 1)
dau = idau Mod 5
If dau = 0 Then
dau = 5
If idau > 0 And idau < 31 Then
mu = ""
ElseIf idau > 30 And idau < 51 Then
mu = "z"
mu = "zw"
k = k & mu
ElseIf ikdau > 0 Then
k = Mid(Bkdau, ikdau, 1)
If ikdau < 6 Then
k = k & "z"
k = k & "zw"
ElseIf k = ChrW(32) Then
k = dau & ChrW(32)
dau = ""
x = x & k
Sb = Sb & x
MahoaUNI = Sb
Tuy nhiên Code trên xếp Alphabet danh sách học sinh chưa được như ý muốn
VD 2 học sinh sau khi xếp thì có thứ tự như sau:
1. Nguyễn Quỳnh Nhi
2. Nguyễn Thị Anh Nhi
Nhưng theo đúng DSHS của GVCN lớp lại xếp là:
1. Nguyễn Thị Anh Nhi
2. Nguyễn Quỳnh Nhi
(Vì Anh Nhi trước Quỳnh Nhi)
(Chắc là lấy từng tên đệm gần tên chính trước, sau đó dịch dần về phía Họ, vì tên đệm của học sinh có thể 1 từ, 2 từ, ... )
Bây giờ em muốn xếp DSHS theo GVCN lớp xếp thì em cần sửa gì không?
Mong mọi người trên GPE giúp em với, xin cảm ơn mọi người....
Sub XeptenABC()
Dim n As Long
.Global = True
If IsNull(S) Then
Exit Function
Sb = S
S = Trim(S)
Bkdau = "aeoudao"
For m = 1 To Len(S)
k = Mid(S, m, 1)
If idau > 0 Then
dau = idau Mod 5
If dau = 0 Then
dau = 5
mu = ""
mu = "z"
mu = "zw"
k = k & mu
If ikdau < 6 Then
k = k & "z"
k = k & "zw"
k = dau & ChrW(32)
dau = ""
x = x & k
Sb = Sb & x
MahoaUNI = Sb
1. Nguyễn Quỳnh Nhi
2. Nguyễn Quỳnh Nhi
