Hoàng Nhật Phương
Thành viên gắn bó
Bạn thử xem:Xin chào các bạn,
Nhờ các bạn giúp đỡ tôi xóa các số 0 theo điều kiện nêu trong file đính kèm với ạ.
Sub RunMe()
Dim DicNCC As Object, ArrRuler1 As Variant, ArrRuler2 As Variant, ArrData1 As Variant, ArrData2 As Variant, EndR As Long, i As Long
Set DicNCC = CreateObject("Scripting.Dictionary")
ArrRuler1 = Range("B6:B9").Value
ArrRuler2 = Range("E6:AI9").Value
EndR = Cells(&H100000, 2).End(xlUp).Row
ArrData1 = Range("B15:B" & CStr(EndR)).Value
ArrData2 = Range("E15:AI" & CStr(EndR)).Value
For i = 1 To UBound(ArrRuler2, 2)
DefineDic DicNCC, ArrRuler1, ArrRuler2, i
Clear0 DicNCC, ArrData1, ArrData2, i
Range("E15:AI" & CStr(EndR)).Value = ArrData2
Private Sub DefineDic(ByRef DicNCC As Object, ByRef ArrNCC As Variant, ByRef ArrData As Variant, ByVal Col As Long)
Dim i As Long
DicNCC.RemoveAll
For i = 1 To UBound(ArrNCC, 1)
If ArrData(i, Col) = "X" Then
DicNCC.Add ArrNCC(i, 1), 0
Private Sub Clear0(ByRef DicNCC As Object, ByRef ArrNCC As Variant, ByRef ArrData As Variant, ByVal Col As Long)
Dim i As Long
If DicNCC.Count = 0 Then Exit Sub
If DicNCC.Exists(ArrNCC(i, 1)) Then
If ArrData(i, Col) = 0 Then ArrData(i, Col) = Empty
Bạn thử xem:
@be09: Xóa có điều kiện.PHP:Sub RunMe() Dim DicNCC As Object, ArrRuler1 As Variant, ArrRuler2 As Variant, ArrData1 As Variant, ArrData2 As Variant, EndR As Long, i As Long Set DicNCC = CreateObject("Scripting.Dictionary") ArrRuler1 = Range("B6:B9").Value ArrRuler2 = Range("E6:AI9").Value EndR = Cells(&H100000, 2).End(xlUp).Row ArrData1 = Range("B15:B" & CStr(EndR)).Value ArrData2 = Range("E15:AI" & CStr(EndR)).Value For i = 1 To UBound(ArrRuler2, 2) DefineDic DicNCC, ArrRuler1, ArrRuler2, i Clear0 DicNCC, ArrData1, ArrData2, i Next Range("E15:AI" & CStr(EndR)).Value = ArrData2 End Sub Private Sub DefineDic(ByRef DicNCC As Object, ByRef ArrNCC As Variant, ByRef ArrData As Variant, ByVal Col As Long) Dim i As Long DicNCC.RemoveAll For i = 1 To UBound(ArrNCC, 1) If ArrData(i, Col) = "X" Then DicNCC.Add ArrNCC(i, 1), 0 End If Next End Sub Private Sub Clear0(ByRef DicNCC As Object, ByRef ArrNCC As Variant, ByRef ArrData As Variant, ByVal Col As Long) Dim i As Long If DicNCC.Count = 0 Then Exit Sub For i = 1 To UBound(ArrNCC, 1) If DicNCC.Exists(ArrNCC(i, 1)) Then If ArrData(i, Col) = 0 Then ArrData(i, Col) = Empty End If Next End Sub
Sub test()
Dim rngFilter As Range, rngTarget As Range, rngSource As Range, cel As Range
Set rngSource = Sheet1.Range("B14:AI2000")
Set rngFilter = Sheet1.Range("B6:B9")
For Each cel In rngFilter
rngSource.AutoFilter 1, cel.Value
Set rngTarget = cel.Offset(, 3).Resize(, 31).SpecialCells(xlCellTypeConstants).EntireColumn
If Not rngTarget Is Nothing Then
On Error GoTo 0
Set rngTarget = Intersect(rngTarget, rngSource.Offset(1))
rngTarget.Replace 0, Empty, xlWhole
Sheet1.AutoFilterMode = False
Anh thiếu dòng Set rngTarget = Nothing. Kết quả không sai nhưng một vùng được thực hiện nhiều lần không cần thiết.Bài này thấy làm bằng Autofilter cũng ra. Nguyên tắc:
- Quét từ dòng 5 đến dòng 9 (quét từng dòng) trong khu vực E5:AI9
- Dùng SpecialCells định vị các cells có nội dung
- Xong "chiếu" xuống dòng 15, dùng Find and Replace xóa số 0
Mã:Sub test() Dim rngFilter As Range, rngTarget As Range, rngSource As Range, cel As Range Set rngSource = Sheet1.Range("B14:AI2000") Set rngFilter = Sheet1.Range("B6:B9") For Each cel In rngFilter rngSource.AutoFilter 1, cel.Value On Error Resume Next Set rngTarget = cel.Offset(, 3).Resize(, 31).SpecialCells(xlCellTypeConstants).EntireColumn If Not rngTarget Is Nothing Then On Error GoTo 0 Set rngTarget = Intersect(rngTarget, rngSource.Offset(1)) rngTarget.Replace 0, Empty, xlWhole End If Next Sheet1.AutoFilterMode = False End Sub
