Có ai biết sửa giúp mình NGÀN thành Nghìn và bỏ hộ chữ CHẴN cuối dòng
Dưới đây là đoạn mã chuyển số ra chữ
Function UnicodeChar(UniCharCode As String) As String
On Error GoTo Loi
Dim str
Dim desStr As String
Dim i
If Mid(UniCharCode, 1, 1) = ";" Then
UniCharCode = Mid(UniCharCode, 2)
If Right(UniCharCode, 1) = ";" Then
UniCharCode = Mid(UniCharCode, 1, Len(UniCharCode) - 1)
str = UniCharCode
str = Split(str, ";")
For i = LBound(str) To UBound(str)
desStr = desStr & ChrW$("&H" & str(i))
UnicodeChar = desStr
Loi:
Exit Function
Function VND (ByVal NumCurrency As Currency) As String
Static CharVND(9) As String, BangChu As String, i As Integer
Dim SoLe, SoDoi As Integer, PhanChan, Ten As String
Dim DonViTien As String, DonViLe As String
Dim NganTy As Integer, Ty As Integer, Trieu As Integer, Ngan As Integer
Dim Dong As Integer, Tram As Integer, Muoi As Integer, DonVi As Integer
DonViTien = ";111;1ED3;6E;67" ' ?o^`ng
DonViLe = ";78;75" ' xu
If NumCurrency = 0 Then
VND = UnicodeChar(";4B;68;F4;6E;67;20" & DonViTien)
Exit Function
If NumCurrency > 922337203685477# Then ' So^' lo+'n nha^'t cu?a loa.i CURRENCY
VND = UnicodeChar(";4B;68;F4;6E;67;20;111;1ED5;69;20;111 ;1B0;1EE3;63;20;73" & _
";1ED1;20;6C;1EDB;6E;20;68;1A1;6E;20;39;32;32;2C;3 3;33;37" & _
";2C;32;30;33;2C;36;38;35;2C;34;37;37")
Exit Function
CharVND(1) = ";6D;1ED9;74" ' mo^.t
CharVND(2) = ";68;61;69" ' hai
CharVND(3) = ";62;61" ' ba
CharVND(4) = ";62;1ED1;6E" ' bo^'n
CharVND(5) = ";6E;103;6D" ' na(m
CharVND(6) = ";73;E1;75" ' su
CharVND(7) = ";62;1EA3;79" ' ba?y
CharVND(8) = ";74;E1;6D" ' tm
CharVND(9) = ";63;68;ED;6E" ' chn
SoLe = Int((NumCurrency - Int(NumCurrency)) * 100) ' 2 k so^'
PhanChan = Trim$(str$(Int(NumCurrency)))
PhanChan = Space(15 - Len(PhanChan)) + PhanChan
NganTy = Val(Left(PhanChan, 3))
Ty = Val(Mid$(PhanChan, 4, 3))
Trieu = Val(Mid$(PhanChan, 7, 3))
Ngan = Val(Mid$(PhanChan, 10, 3))
Dong = Val(Mid$(PhanChan, 13, 3))
If NganTy = 0 And Ty = 0 And Trieu = 0 And Ngan = 0 And Dong = 0 Then
BangChu = ";6B;68;F4;6E;67;20" + DonViTien + ";20"
i = 5
BangChu = ""
i = 0
' Ba('t ?a^`u ?o^?i
While i <= 5
Select Case i
Case 0
SoDoi = NganTy
Ten = ";6E;67;E0;6E;20;74;1EF7" ' ngn ty?
Case 1
SoDoi = Ty
Ten = ";74;1EF7" ' ty?
Case 2
SoDoi = Trieu
Ten = ";74;72;69;1EC7;75" ' trie^.u
Case 3
SoDoi = Ngan
Ten = ";6E;67;E0;6E" ' ngn
Case 4
SoDoi = Dong
Ten = DonViTien ' ?o^`ng
Case 5
SoDoi = SoLe
Ten = DonViLe ' xu
End Select
If SoDoi <> 0 Then
Tram = Int(SoDoi / 100)
Muoi = Int((SoDoi - Tram * 100) / 10)
DonVi = (SoDoi - Tram * 100) - Muoi * 10
If Right(BangChu, 3) = ";20" Then
BangChu = Left(BangChu, Len(BangChu) - 3)
BangChu = BangChu + IIf(Len(BangChu) = 0, "", ";2C;20") + _
IIf(Tram <> 0, Trim(CharVND(Tram)) + ";20;74;72;103;6D;20", "")
If Muoi = 0 And Tram <> 0 And DonVi <> 0 Then
BangChu = BangChu + ";6C;1EBB;20"
If Muoi <> 0 Then
BangChu = BangChu + IIf(Muoi <> 0 And Muoi <> 1, _
Trim(CharVND(Muoi)) + ";20;6D;1B0;1A1;69;20", ";6D;1B0;1EDD;69;20")
If Muoi <> 0 And DonVi = 5 Then
BangChu = BangChu + ";6C;103;6D;20" + Ten + ";20"
If Muoi > 1 And DonVi = 1 Then
BangChu = BangChu + ";6D;1ED1;74;20" + Ten + ";20"
BangChu = BangChu + IIf(DonVi <> 0, Trim(CharVND(DonVi)) + ";20" + Ten, Ten) + ";20"
BangChu = BangChu + IIf(i = 4, DonViTien + "", "")
i = i + 1
Wend
If SoLe = 0 Then
BangChu = BangChu + IIf(Right(BangChu, 3) = ";20", "", ";20") + ";63;68;1EB5;6E"
BangChu = UnicodeChar(BangChu)
'?o^?i sang tie^'ng Vie^.t Unicode
' ?o^?i chu+~ ci ?a^`u tin thnh chu+~ hoa
Mid$(BangChu, 1, 1) = UCase$(Mid$(BangChu, 1, 1))
VND = BangChu
On Error GoTo Loi
Dim str
Dim i
str = UniCharCode
Loi:
Exit Function
Exit Function
Exit Function
i = 5
BangChu = ""
i = 0
' Ba('t ?a^`u ?o^?i
While i <= 5
Select Case i
Case 0
SoDoi = NganTy
Case 1
SoDoi = Ty
Case 2
SoDoi = Trieu
Case 3
SoDoi = Ngan
Case 4
SoDoi = Dong
Case 5
SoDoi = SoLe
Ten = DonViLe ' xu
End Select
If SoDoi <> 0 Then
If Muoi <> 0 Then
i = i + 1
Wend
If SoLe = 0 Then
VND = BangChu
