Chuyên mục xử lý, gỡ rối code VBA (10 người xem)
Status
Không mở trả lời sau này.
ndu96081631
Huyền thoại GPE
Thành viên BQT
Super Moderator
Chào Thầy
em co code ben dưới hiện tại sử dụng tìm kiếm được 2 file giờ e muốn thêm 1 file nữa ví dụ tên file đó là "3.xls" thầy thêm code giùm với
Private Sub TextBox1_KeyDown(ByVal KeyCode As MSForms.ReturnInteger, ByVal Shift As Integer)
   If KeyCode.Value = 13 Then
       With Sheet1
           If Len(TextBox1.Text) = 0 Then
               .Range("A2:K20").ClearContents
               Exit Sub
1           Dim cn As Object
           cn.Open ("Provider=Microsoft.JET.OLEDB.4.0;Data Source=" & ThisWorkbook.FullName & ";Extended Properties=Excel 8.0")
2           .Range("A2").CopyFromRecordset cn.Execute("select * from [EXCEL 8.0;Database=" & ThisWorkbook.Path & "\1.xls].[A1:K] where [SO]=" & Sheet1.TextBox1.Text & " Union all select * from [EXCEL 8.0;Database=" & ThisWorkbook.Path & "\2.xls].[A1:K] where [SO]=" & Sheet1.TextBox1.Text)
1           Dim cn As Object
           Dim truyVan As String
           truyVan = " select * from [EXCEL 8.0;Database=" & ThisWorkbook.Path & "\<tenFile>].[A1:K] where [SO]=" & Sheet1.TextBox1.Text
           truyVan = Replace(truyVan, "<tenFile>", "1.xls") & " UNION ALL " & Replace(truyVan, "<tenFile>", "2.xls") & " UNION ALL " & Replace(truyVan, "<tenFile>", "3.xls")
2           .Range("A2").CopyFromRecordset cn.Execute(truyVan)
Bạn xem thử!
Column headings: By default, it is assumed that the first row of your Excel data source contains columns headings that can be used as field names. If this is not the case, you must turn this setting off, or your first row of data "disappears" to be used as field names. This is done by adding the optional HDR= setting to the Extended Properties of the connection string. The default, which does not need to be specified, is HDR=Yes. If you do not have column headings, you need to specify HDR=No; the provider names your fields F1, F2, etc. Because the Extended Properties string now contains multiple values, it must be enclosed in double quotes itself, plus an additional pair of double quotes to tell Visual Basic to treat the first set of quotes as literal values, as in the following example (where extra spaces have been added for visual clarity).
Em hiểu rồi, em cảm ơn ạ :D
E có 1 form, và các TextBox trong đó, dùng 1 button để kiểm tra xem TextBox nào để trống thì báo. Nhưng chẳng nhẽ bao nhiu TextBox là bấy nhiêu Code. Xin nhờ các A/c giúp cho code gọn hơn ạ. E xin cảm ơn !
If TextBox1 = "" Then
        TextBox1.BackStyle = 1
        TextBox1.BackColor = RGB(255, 128, 128)
        MsgBox "KHONG DUOC DE TRONG"
        Exit Sub
If TextBox2 = "" Then
        TextBox2.BackStyle = 1
        TextBox2.BackColor = RGB(255, 128, 128)
        Exit Sub
If TextBox3 = "" Then
        TextBox3.BackStyle = 1
        TextBox3.BackColor = RGB(255, 128, 128)
        Exit Sub
        Exit Sub
        Exit Sub
Anh thử như thế này xem sao:
    Dim Tb
For Each Tb In UserForm1.Controls
    If UCase(TypeName(Tb)) = "TEXTBOX" Then
        If Tb = "" Then
            Tb.BackStyle = 1
            Tb.BackColor = RGB(255, 128, 128)
Next Tb
    Dim Tb
        If Tb = "" Then
            Tb.BackStyle = 1
Next Tb
ủa em thấy ở trên có mấy chữ Exit Sub mà, sao xuống đây mất tiu rồi chị ơi ?
Nếu form của bạn nhiều textbox, có cái yêu cầu không để trống, cái có thể để trống thì bạn có thể dùng đoạn code dưới.
Chịu khó test từng textbox không được để trống thôi.
Private Sub CheckTextBoxEmpty(txt As MSForms.TextBox)
    If Len(Trim$(txt.Text)) = 0 Then
        txt.BackStyle = 1
        txt.BackColor = RGB(255, 128, 128)
        txt.SetFocus
        Err.Raise vbObjectError + 1, "", "KHONG DUOC DE TRONG " & txt.Name
    On Error GoTo ErrHandler
    CheckTextBoxEmpty TextBox1
    CheckTextBoxEmpty TextBox2
    CheckTextBoxEmpty TextBox3
    MsgBox "All textboxes OK :)"
    ' Your code here
    Exit Sub
ErrHandler:
    MsgBox Err.Description, vbCritical Or vbOKOnly, "Error"
Đoạn code của bạn PacificPR sẽ bị lỗi là nếu có bao nhiêu textbox rỗng thì Excel sẽ quăng MsgBox bao nhiêu lần.
MsgBox này tôi đã cố tránh trong code của tôi. Lúc đầu dùng function return Boolean thì do Excel VBA không có tính năng kiểm tra tắt điều kiện logic nên bị MsgBox nhiều lần. Vì vậy tôi mới dùng cách raise Err.
Mạo muội code lại code của bạn PacificPR như sau, dùng cách duyệt qua các TextBox, TextBox nào có Tag property khác rỗng thì check nó có empty hay không. Cách dùng Tag property này chúng tôi hay dùng hồi xưa.
Private Function CheckTextBoxEmptyByTag(frm As MSForms.UserForm) As Boolean
    Dim ctl As Control
    CheckTextBoxEmptyByTag = False
    For Each ctl In frm.Controls
        If TypeName(ctl) Like "TextBox" And Len(ctl.Tag) <> 0 Then
            If Len(Trim$(ctl.Text)) = 0 Then
                ctl.BackStyle = 1
                ctl.BackColor = RGB(255, 128, 128)
                ctl.SetFocus
                MsgBox "KHONG DUOC DE TRONG TEXTBOX " & ctl.Tag, vbCritical Or vbOKOnly, "Error"
                CheckTextBoxEmptyByTag = True
                Exit Function
    If CheckTextBoxEmptyByTag(UserForm1) = True Then Exit Sub
Vãi, bao nhiêu năm rồi mới ngồi gõ lại code, mà là code Vê Bê mới ngán chứ, báo lỗi tùm lum :)
Có gì bỏ qua, đừng cười em nhé
Em không biết. Chắc nó đi chơi mất rồi " Chị " à. Hì hì ......
Không đơn giản là câu hỏi "nó đâu mất tiu" đâu bạn ạ. Đấy là bài học kinh nghiệm cho bạn đấy. Bài ở trên có người đã nói cho bạn biết rồi. Hi vọng bạn hiểu.
    Dim Tb
        If Tb = "" Then
            Tb.BackStyle = 1
Next Tb
        txt.BackStyle = 1
        txt.SetFocus
    ' Your code here
    Exit Sub
ErrHandler:
    Dim ctl As Control
                ctl.BackStyle = 1
                ctl.SetFocus
                Exit Function
Cám ơn các Anh chị nhiều !
Em chào anh chị, em có một vấn đề cần anh, chị giúp đỡ ạ. Hiện tại em có danh sách khoảng 15 xưởng, hàng ngày em đều phải cập nhập kế hoạch xuống cho các xưởng, mỗi lần cập nhật mất khá nhiều thời gian. Phương pháp hiện tại em đang dùng là chọn lần lượt tên các xưởng trong listbox và đẩy dữ liệu đi. Em muốn hỏi anh chị là có cách nào chỉ cần chạy marco 1 lần dữ liệu tự động đẩy lần lượt đến các xưởng mà không phải chọn lần lượt trong listbox không ạ. Mong anh chị gợi ý phương pháp làm cho em ạ. Em cảm ơn.
    Dim Tb
        If Tb = "" Then
            Tb.BackStyle = 1
Next Tb
Muốn đi qua controls thì dùng tên của nó, dễ điều khiển hơn:
For Each cNme In Array("TextBox1", "TextBox2", ...)
Set ctrl = UserForm1.Controls(ctrl)
If ctrl.Text = "" Then
Next ctrl
Next ctrl
Chỗ em bôi đỏ phải là cNme chứ a nhỉ
        Exit Sub
        Exit Sub
        Exit Sub
Gợi ý thêm một khả năng mới.
Giả sử có 2 textbox, và chúng đều rỗng, khi click phát textbox1 đỏ choét, sau đó người dùng nhập liệu textbox1. Click phát nữa thì cả hai textbox cùng đỏ choet ( do textbox2 lúc này vẫn rỗng). Có nên chăng ta phải khôi phục màu của các textbox trước khi tô màu cho cái textbox rỗng đầu tiền?
Em đoán nhà họ đặt cái màu đỏ choét đó để kiểm soát. Nhưng có bài #1367 thì không cần cái đó nữa. Chị #1368 chả mắng cho còn rồi( Mà cái Bà đó khó tính mà vẫn đẹp gái thế mới sợ chứ ... :D:D:D)
Chỉ 1 lúc đủ 100% ngừoi ta hổng nhớ đâu. Cứ để đỏ toét loét một thời gian rồi tự động nhớ nguyên tắc "khi tô màu phải nghĩ đến lúc cần xoá đi."
Nhưng mà biết đâu người ta đã có chuyện khôi phục trong cái sự kiện focus hay change gì gì đó rồi.
Status
