Sub SortWorksheets()
Dim N As Integer
Dim m As Integer
Dim FirstWSToSort As Integer
Dim LastWSToSort As Integer
Dim SortDescending As Boolean
SortDescending = False
If ActiveWindow.SelectedSheets.Count = 1 Then
'Change the 1 to the worksheet you want sorted first
FirstWSToSort = 1
LastWSToSort = Worksheets.Count
With ActiveWindow.SelectedSheets
For N = 2 To .Count
If .item(N - 1).index <> .item(N).index - 1 Then
MsgBox "You cannot sort non-adjacent sheets"
Exit Sub
Next N
FirstWSToSort = .item(1).index
LastWSToSort = .item(.Count).index
For m = FirstWSToSort To LastWSToSort
For N = m To LastWSToSort
If SortDescending = True Then
If UCase(Worksheets(N).name) > UCase(Worksheets(m).name) Then
Worksheets(N).Move Before:=Worksheets(m)
If UCase(Worksheets(N).name) < UCase(Worksheets(m).name) Then
Next N
Next m
Em có 10 sheets("AA1") -:- sheets("AA10") và sheets("BB1") -:- sheets("BB10")
giờ em muốn code sắp xếp: AA1 > BB1 > AA2 >> BB2 >>... AAn >> BBn... em xin chân thành cảm ơn!
Sub GPE()
Dim i As Long, tmp As String
For i = 1 To Sheets.Count
tmp = "AA" & i
If ExitSheet(tmp) Then
Sheets(tmp).Move Before:=Worksheets(k)
tmp = "BB" & i
Function ExitSheet(ByVal tmp As String) As Boolean
Dim Test As Variant
Test = Sheets(tmp).Range("A1").Value
If Err.Number = 0 Then ExitSheet = True
Sub vidu_SortedList()
Const sMatch1 = "AA*"
Const sMatch2 = "BB*"
Dim oSList As Object, ws As Worksheet, N As Long
Dim i As Long, idex1 As Long, idex2 As Long, sName As String
Set oSList = CreateObject("System.Collections.SortedList")
For Each ws In ThisWorkbook.Worksheets
If (ws.Name Like sMatch1) Or (ws.Name Like sMatch2) Then
oSList.Add ws.Name, ""
Next ws
N = oSList.Count
If N = 0 Or N Mod 2 <> 0 Then Exit Sub
If (oSList.GetKey(N / 2 - 1) Like sMatch1) And (oSList.GetKey(N / 2) Like sMatch2) Then
idex2 = 1
Sheets(oSList.GetKey(0)).Move Before:=Sheets(1)
For i = 1 To N - 1
If i < N / 2 Then
idex1 = idex1 + 1
sName = oSList.GetKey(i)
Sheets(sName).Move After:=Sheets(idex1)
Sheets(sName).Move After:=Sheets(idex2)
idex2 = idex2 + 2
Không đúng như mong muốn anh ạ! nó vẫn theo thứ tự từng loạiMần thử xem đúng yêu cầu của bạn không nhé
Mã:Sub SortWorksheets() Dim N As Integer Dim m As Integer Dim FirstWSToSort As Integer Dim LastWSToSort As Integer Dim SortDescending As Boolean SortDescending = False If ActiveWindow.SelectedSheets.Count = 1 Then 'Change the 1 to the worksheet you want sorted first FirstWSToSort = 1 LastWSToSort = Worksheets.Count Else With ActiveWindow.SelectedSheets For N = 2 To .Count If .item(N - 1).index <> .item(N).index - 1 Then MsgBox "You cannot sort non-adjacent sheets" Exit Sub End If Next N FirstWSToSort = .item(1).index LastWSToSort = .item(.Count).index End With End If For m = FirstWSToSort To LastWSToSort For N = m To LastWSToSort If SortDescending = True Then If UCase(Worksheets(N).name) > UCase(Worksheets(m).name) Then Worksheets(N).Move Before:=Worksheets(m) End If Else If UCase(Worksheets(N).name) < UCase(Worksheets(m).name) Then Worksheets(N).Move Before:=Worksheets(m) End If End If Next N Next m End Sub
code này chạy cũng không như mong muốn anh à! code này chạy giống bài #2Mã:Sub GPE() Dim i As Long, tmp As String For i = 1 To Sheets.Count tmp = "AA" & i If ExitSheet(tmp) Then k = k + 1 Sheets(tmp).Move Before:=Worksheets(k) End If tmp = "BB" & i If ExitSheet(tmp) Then k = k + 1 Sheets(tmp).Move Before:=Worksheets(k) End If Next i End Sub Function ExitSheet(ByVal tmp As String) As Boolean Dim Test As Variant On Error Resume Next Test = Sheets(tmp).Range("A1").Value If Err.Number = 0 Then ExitSheet = True End Function
Code ko chạy được tý nào ạ! em up file lên giúp em với!Thử dùng SortedList...
PHP:Sub vidu_SortedList() Const sMatch1 = "AA*" Const sMatch2 = "BB*" Dim oSList As Object, ws As Worksheet, N As Long Dim i As Long, idex1 As Long, idex2 As Long, sName As String Set oSList = CreateObject("System.Collections.SortedList") For Each ws In ThisWorkbook.Worksheets If (ws.Name Like sMatch1) Or (ws.Name Like sMatch2) Then oSList.Add ws.Name, "" End If Next ws N = oSList.Count If N = 0 Or N Mod 2 <> 0 Then Exit Sub If (oSList.GetKey(N / 2 - 1) Like sMatch1) And (oSList.GetKey(N / 2) Like sMatch2) Then idex2 = 1 Sheets(oSList.GetKey(0)).Move Before:=Sheets(1) For i = 1 To N - 1 If i < N / 2 Then idex1 = idex1 + 1 sName = oSList.GetKey(i) Sheets(sName).Move After:=Sheets(idex1) Else sName = oSList.GetKey(i) Sheets(sName).Move After:=Sheets(idex2) idex2 = idex2 + 2 End If Next i End If End Sub
Số sheet ban có ban đầu! Em có 10 sheets("AA1") -:- sheets("AA10") và sheets("BB1") -:- sheets("BB10")Bạn vui tính nhỉ? "Treo đầu dê bán thịt..."
"10 sheets("AA1") -:- sheets("AA10") và sheets("BB1") -:- sheets("BB10")"
Bài #4 là chuẩn rồi bạn.
Bạn ơi. Bạn có biết thế nào tên sheet không?Số sheet ban có ban đầu! Em có 10 sheets("AA1") -:- sheets("AA10") và sheets("BB1") -:- sheets("BB10")
em muốn nó xếp như này ạ! "sắp xếp: AA1 > BB1 > AA2 >> BB2 >>... AAn >> BBn"
Bài #1 bài yêu cầu tên các sheets là "AA1",... "BB1"... trong khi file bạn vừa đưa không có cái sheet nào tên như thế. Đã trích dẫn và đính kèm hình chụp gần nhau thế cho bạn nhìn rồi!
Đây gọi là sheet "AA1",... "BB1"...
Bạn đổi lại điều kiện nhận biết tên sheet của bạn trong code trên là được. Mình động não chút chứ!!!
Có 20 cái sheets dùng tay kéo cho dẻo!
-------------------------------------------Sub GPE()
tmp = "CD-L" & i
tmp = "DT-L" & i
Dim Test As Variant
Hãy dùng cách đơn giản nhất đi bạn. Mục đích là để tìm đến sheet cần tìm một cách nhanh nhất đúng không.Em có 10 sheets("AA1") -:- sheets("AA10") và sheets("BB1") -:- sheets("BB10")
mục đích của em là để in 1 loạt theo thứ tự mình mong muốn ko phải xếp tay!. các anh cho code ok rồi ạHãy dùng cách đơn giản nhất đi bạn. Mục đích là để tìm đến sheet cần tìm một cách nhanh nhất đúng không.
Hãy tạo một sheet Menu, rồi tạo các hyperlink để di chuyển đến sheet muốn chọn.
Bác này dân cầu đường chắc luôn nè, hihi
Kết bạn với nhau cùng nghiên cứu VBA viết phầm mềm dự toán nhé, mình làm các bước tương đối ổn rồi, còn phần tạo CSDL và tra mã hiệu để sử dụng nữa thôidạ vâng! chuẩn luôn ạ
Kết bạn ok! ^^ https://www.facebook.com/VoVa.tq.86Kết bạn với nhau cùng nghiên cứu VBA viết phầm mềm dự toán nhé, mình làm các bước tương đối ổn rồi, còn phần tạo CSDL và tra mã hiệu để sử dụng nữa thôi
