Chuyển file công thức excel thành code VBA (1 người xem)
LightStar252
Ai giúp mình chuyển mấy công thức excel này thành code VBA cho đỡ nặng với ạ, hoặc là giúp mình code VBA tìm kiếm và tổng hợp dữ liệu thay thế các công thức excel cũng được ạ!
Trong File có code
Sub baocaodaumaythang()
' baocaodaumaythang Macro
' so may
' =IFERROR(INDEX('BCHN.T1.2017.xls'!SM,MATCH(0,COUNTIF(C$9:$C11,'BCHN.T1.2017 .xls'!SM),0)),"")
    Range("C12").Select
    Selection.FormulaArray = _
        "=IFERROR(INDEX('BCHN.T1.2017.xls'!SM,MATCH(0,COUNTIF(R9C:R[-1]C3,'BCHN.T1.2017.xls'!SM),0)),"""")"
' loai may
' =IFERROR((VLOOKUP(C12,CSDL!$B$10:$C$275,2,0))," ")
    Range("B12").Select
    ActiveCell.FormulaR1C1 = _
        "=IFERROR((VLOOKUP(RC[1],CSDL!R10C2:R275C3,2,0)),"" "")"
' dm chieu cao
' =IFERROR((VLOOKUP(C12,CSDL!$B$10:$H$275,5,0))," ")
    Range("D12").Select
        "=IFERROR((VLOOKUP(RC[-1],CSDL!R10C2:R275C8,5,0)),"" "")"
' dm gio
' =IFERROR((VLOOKUP(C12,CSDL!$B$10:$H$275,6,0)),"")
    Range("E12").Select
        "=IFERROR((VLOOKUP(RC[-2],CSDL!R10C2:R275C8,6,0)),"""")"
' tong gio
' =IF(C12<>"",SUMIF(BCHN!$D$10:$D$3139,C12,BCHN!$I$10:$I$3139),"")
    Range("F12").Select
        "=IF(RC[-3]<>"""",SUMIF(BCHN!R10C4:R3139C4,RC[-3],BCHN!R10C9:R3139C9),"""")"
' tong dau
' =IF(C12<>"",SUMIF(BCHN!$D$10:$D$3139,C12,BCHN!$J$10:$J$3139),"")
    Range("G12").Select
        "=IF(RC[-4]<>"""",SUMIF(BCHN!R10C4:R3139C4,RC[-4],BCHN!R10C10:R3139C10),"""")"
' ton dau dau
' =IF(D12="K do dc",0,IFERROR(J12*D12,""))
    Range("H12").Select
    ActiveCell.FormulaR1C1 = "=IF(RC[-4]=""K do dc"",0,IFERROR(RC[2]*RC[-4],""""))"
' ton dau cuoi
' =IF(D12="K do dc",0,IFERROR(K12*D12,""))
    Range("I12").Select
    ActiveCell.FormulaR1C1 = "=IF(RC[-5]=""K do dc"",0,IFERROR(RC[2]*RC[-5],""""))"
' chieu cao dau dau
' =IFERROR(OFFSET(INDEX('BCHN.T1.2017.xls'!data, MATCH(C12&$A$6, 'BCHN.T1.2017.xls'!SM&Ngay, 0), MATCH($J$9,BCHN!$C$8:$O$8,0)),2,0),"")
    Range("J12").Select
        "=IFERROR(OFFSET(INDEX('BCHN.T1.2017.xls'!data, MATCH(RC[-7]&R6C1, 'BCHN.T1.2017.xls'!SM&Ngay, 0), MATCH(R9C10,BCHN!R8C3:R8C15,0)),2,0),"""")"
' chieu cao dau cuoi
' =IFERROR((OFFSET(INDEX('BCHN.T1.2017 .xls'!data, MATCH(C12&$A$7, 'BCHN.T1.2017.xls'!SM&Ngay, 0), MATCH($K$9,BCHN!$C$8:$Q$8, 0)),2,0)),"")
    Range("K12").Select
        "=IFERROR((OFFSET(INDEX('BCHN.T1.2017.xls'!data, MATCH(RC[-8]&R7C1, 'BCHN.T1.2017.xls'!SM&Ngay, 0), MATCH(R9C11,BCHN!R8C3:R8C17, 0)),2,0)),"""")"
' dau theo dinh muc
' =IFERROR(F12*E12,"")
    Range("L12").Select
    ActiveCell.FormulaR1C1 = "=IFERROR(RC[-6]*RC[-7],"""")"
' ton dau
' =IFERROR(L12-(G12+H12-I12),"")
    Range("M12").Select
    ActiveCell.FormulaR1C1 = "=IFERROR(RC[-1]-(RC[-6]+RC[-5]-RC[-4]),"""")"
' tieu thu dau trung binh
' =IFERROR(IF(F12=0,"",(H12+G12-I12)/F12),"")
    Range("N12").Select
        "=IFERROR(IF(RC[-8]=0,"""",(RC[-6]+RC[-7]-RC[-5])/RC[-8]),"""")"
' chenh lech gio thuc te
' =IFERROR(IF(F12=0,"",E12-N12),"")
    Range("O12").Select
    ActiveCell.FormulaR1C1 = "=IFERROR(IF(RC[-9]=0,"""",RC[-10]-RC[-1]),"""")"
' cong truong
' =IFERROR((VLOOKUP(C12,LK!$C$12:$P$128,14,0))," ")
    Range("P12").Select
        "=IFERROR((VLOOKUP(RC[-13],LK!R12C3:R128C16,14,0)),"" "")"
' =1
    Range("A12").Select
    ActiveCell.FormulaR1C1 = "1"
    Range("A13").Select
' so thu tu
' =IF(C13<>"",A12+1,"")
    ActiveCell.FormulaR1C1 = "=IF(RC[2]<>"""",R[-1]C+1,"""")"
    Range("B12:P12").Select
    Selection.AutoFill Destination:=Range("B12:P128"), Type:=xlFillDefault
    Range("B12:P128").Select
    ActiveWindow.SmallScroll Down:=-129
    Range("A13").Select
    Selection.AutoFill Destination:=Range("A13:A128"), Type:=xlFillDefault
    Range("A13:A128").Select
    ActiveWindow.SmallScroll Down:=-123
    Range("A12:P128").Select
    ActiveWindow.SmallScroll Down:=-120
    Selection.Copy
    Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
        :=False, Transpose:=False
    Range("C9:C10").Select
    ActiveCell.FormulaR1C1 = "S? máy"
    Range("C11").Select
' ham tinh tong ton dau (du tru dung sau): k lien quan lam =SUMIFS(BCHN!$J$10:$J$3264,'BCHN.T1.2017 .xls'!Ngay,"<="&$A$7,'BCHN.T1.2017 .xls'!SM,C12)-SUMIFS(BCHN!$Q$10:$Q$3264,'BCHN.T1.2017 .xls'!Ngay,"<="&$A$7,SM,C12)
Mà cũng khóa làm gì vậy trời
Có cách nào khác chỉ dùng code VBA thôi chứ không phải dùng công thức Excel, rồi lại chuyển từ công thức excel sang code như thế này k mn
1 tháng của bạn có 30 ngày chẳng hạn thì file BCTH cột 10 và cột 11 tính như thế nào
Chiều cao dầu đó tìm kiếm theo 2 điều kiện ngày tháng và cột "chiều cao dầu đầu" hay "chiều cao dầu cuối" ở sheet BCHN đó. Còn muốn tìm chiều cao ngày nào thì sửa 2 ô A6 và A7 ở sheet BCTH đấy
Bạn thử xem file xem có đúng không
Cao thu giai thich doan code nay de minh tham khao nhe
Public Sub Tonghop()
    Dim sArr(), tArr(), dArr(), I As Long, K As Long, Thang As Long
    Dim Dic As Object, Tem As String
Set Dic = CreateObject("Scripting.Dictionary") ' tao mot doi tung DIC
Thang = Month(Sheets("BCTH").Range("G6")) 'Lay gia tri Thang tai G6 gan vao bien Thang
With Sheets("CSDL")
    tArr = .Range(.Range("B11"), .Range("B65535").End(3)).Resize(, 6).Value ' chon Vung tu B1 den , co du lieu cuoi cung
For I = 1 To UBound(tArr, 1) ' cho bien I chay tu B4 cho den cuoi cung co chua du lieu
    Dic.Item(tArr(I, 1)) = I ' Thiet lap gia tri Item bang I
Next I
With Sheets("BCHN")
    sArr = .Range(.Range("B10"), .Range("B65535").End(3)).Resize(, 15).Value ' chon vung du lieu B10 den cot P co chua du lieu cuoi cung
ReDim dArr(1 To UBound(sArr, 1), 1 To 15) ' Xac dinh lai kich co cua mang dArr
For I = 1 To UBound(sArr, 1)                ' Cho Bien I chay tu 1 cho den het trong cot B
    If Month(sArr(I, 1)) = Thang Then       ' Neu tung dong, co thang = gia tri thang da khai bao ben sheet BCTH thi
        Tem = sArr(I, 3)                    ' Them so may vao bien Tem
        If Not Dic.Exists(Tem) Then         ' Kiem tra trong Dic co so may chua?
            K = K + 1                       ' Tang bien K len
            Dic.Add Tem, K                  ' Chua co thi Add vao, Key la Tem, Items la K
            dArr(K, 1) = K                  ' Them vao mang darr STT K,
            dArr(K, 2) = sArr(I, 2)         'Them Loai may vao mang
            dArr(K, 3) = Tem                ' Them So May vao mang
            dArr(K, 4) = tArr(Dic.Item(Tem), 5) 'Them Dinh Muc theo chieu cao vao mang
            dArr(K, 5) = tArr(Dic.Item(Tem), 6) ' Them Dinh Muc theo So Lit vao mang
            dArr(K, 6) = sArr(I, 8)             'Them Gio lam vao mang
            dArr(K, 7) = sArr(I, 9)             'Them Dau Nhan vao Mang
            dArr(K, 10) = sArr(I, 6)            ' Them Chieu cao dau dau
            dArr(K, 11) = ""                    ' Trong
            dArr(Dic.Item(Tem), 6) = dArr(Dic.Item(Tem), 6) + sArr(I, 8)
            dArr(Dic.Item(Tem), 7) = dArr(Dic.Item(Tem), 7) + sArr(I, 9)
            dArr(Dic.Item(Tem), 11) = sArr(I, 7)
            dArr(K, 8) = dArr(K, 4) * dArr(K, 10): dArr(K, 9) = dArr(K, 4) * dArr(K, 11)
            dArr(K, 12) = dArr(K, 5) * dArr(K, 6)
            dArr(K, 13) = dArr(K, 12) - (dArr(K, 7) + dArr(K, 8) - dArr(K, 9))
            dArr(K, 14) = (dArr(K, 8) + dArr(K, 7) - dArr(K, 9)) / dArr(K, 6)
            dArr(K, 15) = dArr(K, 5) - dArr(K, 14)
Next I
With Sheets("BCTH")                                                     ' chon Sheet
    .Range("A12:P" & .Range("A65535").End(3).Row + 1).ClearContents     ' Xac dinh vung du lieu can xoa
    .Range("A12").Resize(K, 15) = dArr                                  ' Xac dinh Vung du lieu can dan Mang xuong bang tinh
Set Dic = Nothing
Hy vọng giúp đỡ được bạn./
Minh hiểu rồi, thank so much!
P/s: Mình có 1 câu hỏi them là muốn viết code copy dữ liệu "A1:A100" row lẽ thì paste cột "B1:B50" chẳn thì "C1:C50"
Sao đã "lẽ thì " rồi còn "chẳn thì" :D. Bạn cần diễn đạt rõ ràng thêm .......
Bạn chú ý không dùng mấy từ thank so much! này
