duyet_vbatg
Bạn thử với:Xin Anh Chị diễn đàn hỗ trợ mình code vba tính tổng của 3 ô trong 3 file excel khác nhau vào một ô trong 1 file excel khác có file ví dụ đính kèm
Xin cảm ơn nhiều !
Sub Update_abc()
Dim vFile As Variant, i As Integer, sWB As String, rRng As Range, Sh As Worksheet
vFile = Application.GetOpenFilename _
(FileFilter:="Excel Files, *.xls*", _
Title:="Xin moi chon File o day", _
MultiSelect:=True)
If Not IsArray(vFile) Then
MsgBox "Ban da khong chon File nao?", vbExclamation
Exit Sub
For i = LBound(vFile) To UBound(vFile)
Workbooks.Open Filename:=vFile(i)
sWB = ActiveWorkbook.Name
If i = 1 Then
Set rRng = Range("A1:B100")
Set rRng = Range("A1:B100").Offset(1)
rRng.Copy ThisWorkbook.Sheets("TH").Range("A" & Rows.Count).End(xlUp).Offset(1)
Workbooks(sWB).Close False
ActiveSheet.AutoFilterMode = False
Rows("2:2").ClearContents
If MsgBox("Ban muon tong hop du lieu?", vbYesNo, "Thong bao") = vbNo Then
Exit Sub
Call Consolidation_abc
Rows("1:1").Resize(, 2) = Array("STT", "LOAI")
Sub Consolidation_abc()
Dim a, i%
a = Range("A2:B29").Value
.CompareMode = 1
For i = 1 To UBound(a, 1)
If Not .exists(a(i, 1)) Then
.Item(a(i, 1)) = a(i, 2)
.Item(a(i, 1)) = .Item(a(i, 1)) + a(i, 2)
If .Count Then
Range("A1:B1000").ClearContents
Range("A1").Resize(.Count, 2).Value = Application.Transpose(Array(.Keys, .Items))
Cám ơn Phulien1902 rất nhiều. mình sẽ thử xem nó chạy đúng không nhéBạn thử với:
PHP:Option Explicit Sub Update_abc() Dim vFile As Variant, i As Integer, sWB As String, rRng As Range, Sh As Worksheet vFile = Application.GetOpenFilename _ (FileFilter:="Excel Files, *.xls*", _ Title:="Xin moi chon File o day", _ MultiSelect:=True) If Not IsArray(vFile) Then MsgBox "Ban da khong chon File nao?", vbExclamation Exit Sub End If Application.ScreenUpdating = False For i = LBound(vFile) To UBound(vFile) Workbooks.Open Filename:=vFile(i) sWB = ActiveWorkbook.Name If i = 1 Then Set rRng = Range("A1:B100") Else Set rRng = Range("A1:B100").Offset(1) End If rRng.Copy ThisWorkbook.Sheets("TH").Range("A" & Rows.Count).End(xlUp).Offset(1) Workbooks(sWB).Close False Next i ActiveSheet.AutoFilterMode = False Application.ScreenUpdating = True Rows("2:2").ClearContents If MsgBox("Ban muon tong hop du lieu?", vbYesNo, "Thong bao") = vbNo Then Exit Sub Else Call Consolidation_abc End If Rows("1:1").Resize(, 2) = Array("STT", "LOAI") End Sub Sub Consolidation_abc() Dim a, i% a = Range("A2:B29").Value With CreateObject("Scripting.Dictionary") .CompareMode = 1 For i = 1 To UBound(a, 1) If Not .exists(a(i, 1)) Then .Item(a(i, 1)) = a(i, 2) Else .Item(a(i, 1)) = .Item(a(i, 1)) + a(i, 2) End If Next If .Count Then Range("A1:B1000").ClearContents Range("A1").Resize(.Count, 2).Value = Application.Transpose(Array(.Keys, .Items)) End If End With End Sub
Bạn hãy lập 1 topic mới để các thành viên trợ giúp.Xin các Anh, Chị trong diễn đàn sửa giúp code vba để lọc 1 số chứng từ có thể đến 65.000 dòng, lọc 1 số tài khoản có thể lên đến 65.000 dòng với ạ. Tức là khi thêm dòng bên sheet PHATSINH lên tới 65.000 dòng thì các sheet bên (CTGS, socai, DKCTGS) cũng lọc lên 65.000 dòng ạ, (các dòng tổng cộng và người lập, ký dưới cùng vẫn giữ nguyên).
Xin cảm ơn các anh, chị nhiều>
Cảm ơn phulien1902 nhiềuBạn hãy lập 1 topic mới để các thành viên trợ giúp.
lỡ làm nên gởi luôn, lần sau mở topic mớiXin các Anh, Chị trong diễn đàn sửa giúp code vba để lọc 1 số chứng từ có thể đến 65.000 dòng, lọc 1 số tài khoản có thể lên đến 65.000 dòng với ạ. Tức là khi thêm dòng bên sheet PHATSINH lên tới 65.000 dòng thì các sheet bên (CTGS, socai, DKCTGS) cũng lọc lên 65.000 dòng ạ, (các dòng tổng cộng và người lập, ký dưới cùng vẫn giữ nguyên).
Public Sub S_CTGS()
Dim sArr(), dArr(), Rng As Range, I As Long, K As Long, R As Long, Num As Long
With Sheets("CTGS")
.Rows("10:31").Hidden = False
.Range("A10:E31").ClearContents
Num = .Range("C4").Value
With Sheets("PHATSINH")
R = .Range("C" & Rows.Count).End(xlUp).Row
If R < 15 Then MsgBox ("Khong co du lieu phat sinh"): Exit Sub
Set Rng = .Range("B15:B" & R).Find(Num, LookIn:=xlValues, Lookat:=xlWhole)
If Not Rng Is Nothing Then
sArr = .Range("C" & Rng.Row, .Range("H" & R)).Value
Sheets("CTGS").Rows("10:30").Hidden = True
MsgBox ("Chung tu ghi so so: " & Num & " khong tim thay")
Exit Sub
ReDim dArr(1 To UBound(sArr), 1 To 4)
For I = 1 To UBound(sArr)
If sArr(I, 1) = Num Then
K = K + 1
dArr(K, 1) = sArr(I, 3): dArr(K, 2) = sArr(I, 4)
dArr(K, 3) = sArr(I, 5): dArr(K, 4) = sArr(I, 6)
Exit For
Next I
With Sheets("CTGS")
If K Then
.Range("C5") = sArr(K, 2)
.Range("A10:D10").Resize(K) = dArr
.Rows(K + 10 & ":31").Hidden = True
Cảm ơn anh HieuCD nhiều ạ, em thay code code của anh vào code cũ thì không chạy các sheet socai và sheet DKCTGS ạ. code cũ ở đây chạy hết các sheet tốt mà chỉ giới hạn ở sheet PHATSINH đến dòng 1090 thôi ạ, chính vậy nên khi em chèn thêm dòng (đến 65.000 chẳng hạn) thì các sheet bên phải sheet PHATSINH không lọc được. Nhờ anh xem lại và chỉnh giúp em với?lỡ làm nên gởi luôn, lần sau mở topic mới
dùng code sau để tăng tốc xử lýMã:Public Sub S_CTGS() Dim sArr(), dArr(), Rng As Range, I As Long, K As Long, R As Long, Num As Long With Sheets("CTGS") .Rows("10:31").Hidden = False .Range("A10:E31").ClearContents Num = .Range("C4").Value End With With Sheets("PHATSINH") R = .Range("C" & Rows.Count).End(xlUp).Row If R < 15 Then MsgBox ("Khong co du lieu phat sinh"): Exit Sub Set Rng = .Range("B15:B" & R).Find(Num, LookIn:=xlValues, Lookat:=xlWhole) If Not Rng Is Nothing Then sArr = .Range("C" & Rng.Row, .Range("H" & R)).Value Else Sheets("CTGS").Rows("10:30").Hidden = True MsgBox ("Chung tu ghi so so: " & Num & " khong tim thay") Exit Sub End If End With ReDim dArr(1 To UBound(sArr), 1 To 4) For I = 1 To UBound(sArr) If sArr(I, 1) = Num Then K = K + 1 dArr(K, 1) = sArr(I, 3): dArr(K, 2) = sArr(I, 4) dArr(K, 3) = sArr(I, 5): dArr(K, 4) = sArr(I, 6) Else Exit For End If Next I With Sheets("CTGS") If K Then .Range("C5") = sArr(K, 2) .Range("A10:D10").Resize(K) = dArr .Rows(K + 10 & ":31").Hidden = True End If End With End Sub
file của bạn gởi lên có một số vấn đề:Cảm ơn anh HieuCD nhiều ạ, em thay code code của anh vào code cũ thì không chạy các sheet socai và sheet DKCTGS ạ. code cũ ở đây chạy hết các sheet tốt mà chỉ giới hạn ở sheet PHATSINH đến dòng 1090 thôi ạ, chính vậy nên khi em chèn thêm dòng (đến 65.000 chẳng hạn) thì các sheet bên phải sheet PHATSINH không lọc được. Nhờ anh xem lại và chỉnh giúp em với?
Cảm ơn anh HieuCD nhiều ạ.
Dạ, xin đa tạ các anh, nhất là anh Ba Tê và anh ạ.file của bạn gởi lên có một số vấn đề:
1/ chỉ có mấy sheet và vài trăm dòng mà kích thước hơn 3M là quá lớn nếu đủ các sheet khác và các dòng dữ liệu thì chạy rất chậm: thiết kế không hiệu quả
2/ Vừa dùng code vừa dùng công thức trong một sheet như dòng tổng cộng là không ổn, dùng chức năng Hide dòng tương đối đơn giản nhưng file sẽ nặng và bị giới hạn dòng dữ liệu
3/ nếu bạn tạo sổ cái quí 2 thì số dư đầu kỳ tính như thế nào, số đầu kỳ bảng CDPS sẽ như thế nào
4/ kế toán bằng Excel nên hạn chế trang trí màu mè làm tăng kích thước file
chỉ góp ý nhỏ, code thì bạn Ba tê đã giúp
Bạn Phulien1902 code chạy báo lỗi như sau: Run time error '9': subscript out of rangeBạn thử với:
Bài này có thể giải quyết = ADO?Xin Anh Chị diễn đàn hỗ trợ mình code vba tính tổng của 3 ô trong 3 file excel khác nhau vào một ô trong 1 file excel khác có file ví dụ đính kèm
Xin cảm ơn nhiều !
không bạn ơiBài này có thể giải quyết = ADO?
