Tạo giúp em Code copy cột dọc thành hàng ngang! (2 người xem)
diepminhhong
Anh chị có thể giúp mình viết code copy chuyển cột dọc thành hàng ngang như trong file giúp em với được k ạ? E cảm ơn mọi người.
Bạn thử đoạn sau:
Sub Doc2Ngang()
Dim lr As Long, rw As Long, i As Long, m As Long, rc As Long, CV As Long, ii As Long, j As Long
Dim arr, drr(), tmp, cel1 As Range, cel2 As Range
Set cel1 = Sheet1.Range("A1")
Set cel2 = Sheet1.Range("AA9") 'Sua lai thành = Sheet1.Range("AA1")
lr = cel1.End(xlDown).Row
arr = UniqueArray(Sheet1.Range("A2:A" & lr))
For i = 1 To UBound(arr)
    If arr(i, 1) <> "" Then
        rw = rw + 1
        cel2.Offset(1, 0).Offset(rw - 1).Value = arr(i, 1)
ReDim drr(1 To rw)
For i = 1 To rw
    drr(i) = WorksheetFunction.CountIf(Sheet1.Range("A2:A" & lr), arr(i, 1))
m = WorksheetFunction.Max(drr)
cel2.Value = cel1.Value
For i = 1 To 5
    For j = 1 To m
        rc = rc + 1
        If j = 1 Then cel2.Offset(0, rc) = cel1.Offset(0, i)
        If j > 1 Then cel2.Offset(0, rc) = cel1.Offset(0, i) & j - 1
cel2.Offset(0, 5 * m + 1).Resize(1, 16).Value = _
cel1.Offset(0, 6).Resize(1, 16).Value
tmp = cel2.Offset(1).Resize(rw, 1).Value
For i = 1 To UBound(tmp)
    CV = WorksheetFunction.Match(tmp(i, 1), Sheets(1).Range("A1:A" & lr), 0)
    j = 1
    For ii = 1 To (5 * m) Step m
        cel2.Offset(i, ii).Resize(1, drr(i)).Value = _
        Application.Transpose(cel1.Offset(CV - 1, j).Resize(drr(i)))
        j = j + 1
    Next ii
    cel2.Offset(i, 5 * m + 1).Resize(1, 16).Value = _
    cel1.Offset(CV - 1, 6).Resize(1, 16).Value
Function UniqueArray:
Function UniqueArray(SrcRng As Range) 'ndu96081631 -GPE
  Dim Src, tmp As String, arr()
  Dim i As Long, j As Long, n As Long
  Src = SrcRng.Value
  ReDim arr(1 To UBound(Src, 1), 1 To UBound(Src, 2))
    For i = LBound(Src, 1) To UBound(Src, 1)
      tmp = ""
      For j = LBound(Src, 2) To UBound(Src, 2)
        tmp = tmp & Src(i, j)
      If tmp <> "" Then
        If Not .Exists(tmp) Then
          n = n + 1
          .Add tmp, ""
            arr(n, j) = Src(i, j)
  If j <> 0 Then
    UniqueArray = arr
chạy thử code nầy
Sub CopyDoc_Ngang()
Dim Darr, arr(), i As Long, j As Integer, n As Integer, k As Integer
Darr = Range("a2:v" & Range("a2").End(xlDown).Row)
ReDim arr(1 To UBound(Darr), 1 To 97)
For i = 1 To UBound(Darr)
    arr(k, 1) = Darr(i, 1)
    For j = 82 To 97
        arr(k, j) = Darr(i, j - 75)
    cot = 0
    For n = i To UBound(Darr)
        If Darr(n, 1) = Darr(i, 1) Then
            cot = cot + 1
            arr(k, cot + 1) = Darr(n, 2)
            arr(k, cot + 17) = Darr(n, 3)
            arr(k, cot + 33) = Darr(n, 4)
            arr(k, cot + 49) = Darr(n, 5)
            arr(k, cot + 65) = Darr(n, 6)
            If n = UBound(Darr) Then GoTo thoat
            i = n - 1
            GoTo tiep
    Next n
tiep:
thoat:
Range("aa2:ds" & Range("aa2").End(xlDown).Row).ClearContents
Range("aa2").Resize(k, 97) = arr
Hai anh HieuCDhpkhuong xem lại giúp em:
Số CV (chắc viết tắt của từ "công việc") ứng với mỗi "BBS" là tùy ý, dữ liệu trong file là em thí dụ thôi chứ còn nhiều "BBS" lắm.
Và khi đó, tiêu đề mục cũng thay đổi theo (không phải là tới CV15, ĐV15... mà là CV20, ĐV20 chẳng hạn).
Sub CopyDoc_Ngang1()
Dim Darr, arr(), i As Long, j As Integer, n As Integer, k As Integer, max As Integer
Darr = Range("a1:v" & Range("a2").End(xlDown).Row)
tmp = "": max = 0
For i = 2 To UBound(Darr)
    If Darr(i, 1) = tmp Then
        j = j + 1
        j = 1: tmp = Darr(i, 1)
    If j > max Then max = j
ReDim arr(1 To UBound(Darr), 1 To 17 + max * 5)
For j = 1 To 5 * max + 17
    Select Case j
        Case 1 To 2
            arr(1, j) = Darr(1, j)
        Case 3 To max + 1
            arr(1, j) = Darr(1, 2) & (j - 2)
        Case max + 2
            arr(1, j) = Darr(1, 3)
        Case max + 3 To 2 * max + 1
            arr(1, j) = Darr(1, 3) & (j - max - 2)
        Case 2 * max + 2
            arr(1, j) = Darr(1, 4)
        Case 2 * max + 3 To 3 * max + 1
            arr(1, j) = Darr(1, 4) & (j - 2 * max - 2)
        Case 3 * max + 2
            arr(1, j) = Darr(1, 5)
        Case 3 * max + 3 To 4 * max + 1
            arr(1, j) = Darr(1, 5) & (j - 3 * max - 2)
        Case 4 * max + 2
            arr(1, j) = Darr(1, 6)
        Case 4 * max + 3 To 5 * max + 1
            arr(1, j) = Darr(1, 6) & (j - 4 * max - 2)
        Case 5 * max + 2 To 5 * max + 17
            arr(1, j) = Darr(1, j - 5 * max + 5)
    End Select
k = 1
    For j = 5 * max + 2 To 5 * max + 17
        arr(k, j) = Darr(i, j - 5 * max + 5)
    cot = 0
            cot = cot + 1
            arr(k, cot + 1 + max) = Darr(n, 3)
            arr(k, cot + 1 + 2 * max) = Darr(n, 4)
            arr(k, cot + 1 + 3 * max) = Darr(n, 5)
            arr(k, cot + 1 + 4 * max) = Darr(n, 6)
            i = n - 1
            GoTo tiep
    Next n
tiep:
thoat:
Range("aa1").CurrentRegion.ClearContents
Range("aa1").Resize(k, 5 * max + 17) = arr
Ối anh ơi! Anh cứu em với. Em chạy code của anh xong mất hết dữ liệu ban đầu. Em nhờ các anh copy giúp em, chứ dữ liệu ban đầu thì giữ nguyên ạ.
mình chạy thử vẫn bình thường, chắc ăn bạn sửa chổ màu đỏ lại theo đoạn code dưới
thoat:
[COLOR=#ff0000]Range("aa1:dsC" & Range("aa65000").End(xlUp).Row).ClearContents[/COLOR]
thoat:
Code trên nếu bạn ở 1 sheet bất kì nào đó mà chạy thì mất hết dữ liệu là đúng rồi, nó tự hiểu range("aa1") nằm trong Active sheet.
Em cám ơn các anh đã giúp đỡ e code này. Phải nói là đúng như ý e mong muốn. Em chúc các anh sức khoẻ và công tác tốt.
    Select Case j
        Case 1 To 2
        Case 3 To max + 1
        Case max + 2
        Case 2 * max + 2
        Case 3 * max + 2
        Case 4 * max + 2
    End Select
dùng code dưới thay thế đoạn code trên cho gọn hơn
    If j = 1 Then
    ElseIf j >= 5 * max + 2 Then
    ElseIf j Mod max = 2 Then
        arr(1, j) = Darr(1, Int(j / max) + 2)
        arr(1, j) = Darr(1, Int((j - 2) / max) + 2) & ((j - 2) Mod max)
    Select Case j
        Case 1 To 2
        Case 3 To max + 1
        Case max + 2
        Case 2 * max + 2
        Case 3 * max + 2
        Case 4 * max + 2
    End Select
    If j = 1 Then
Anh HieuCD ơi, Anh có thể giúp e xử lý file này (file đính kèm) với được không ạ? Vẫn là file hôm trước anh làm giúp e nhưng e có thay đổi 1 chút đi. E cảm ơn anh nhiều, Chúc anh sức khỏe và thành công.
nhìn file của bạn, mình hơi hoảng, từ từ mình nghiên cứu và gởi code sau
bạn kiể tra lại code
Dim Dic2 As Object, Dic3 As Object, Darr, arr()
Dim i As Long, j As Integer, n As Integer, m As Integer, k As Integer
Dim max1 As Integer, max2 As Integer, max3 As Integer, k2 As Integer, k3 As Integer
Set Dic2 = CreateObject("Scripting.Dictionary")
Set Dic3 = CreateObject("Scripting.Dictionary")
Darr = Range("a1:aa" & Range("a2").End(xlDown).Row)
Tmp = Darr(2, 1):   max1 = 0
max2 = 0:           max3 = 0
    If Darr(i, 1) = Tmp Then
        k1 = k1 + 1
        For j = 22 To 24
            If Not Dic2.Exists(Darr(i, j)) Then
                k2 = k2 + 1: Dic2.Add Darr(i, j), ""
                If k2 > max2 Then max2 = k2
        For n = 25 To 27
            If Not Dic3.Exists(Darr(i, n)) Then
                k3 = k3 + 1: Dic3.Add Darr(i, n), ""
                If k3 > max3 Then max3 = k3
        Next n
        k1 = 1:      Tmp = Darr(i, 1)
        k2 = 0:     k3 = 0
    If k1 > max1 Then max1 = k1
ReDim arr(1 To UBound(Darr), 1 To 16 + max1 * 5 + max2 + max3)
For j = 1 To 16 + max1 * 5
    If j <= 2 Then
    ElseIf j >= 5 * max1 + 3 Then
        arr(1, j) = Darr(1, j - 5 * max1 + 5)
    ElseIf j Mod max1 = 3 Then
        arr(1, j) = Darr(1, Int(j / max1) + 3)
        arr(1, j) = Darr(1, Int((j - 3) / max1) + 3) & ((j - 3) Mod max1)
For j = 1 To max2
    arr(1, j + 16 + max1 * 5) = "TC" & j
For j = 1 To max3
    arr(1, j + 16 + max1 * 5 + max2) = "NDTC" & j
k = 1
    arr(k, 1) = Darr(i, 1): arr(k, 2) = Darr(i, 2)
    For j = 5 * max1 + 3 To 5 * max1 + 16
        arr(k, j) = Darr(i, j - 5 * max1 + 5)
    cot = 1
            cot = cot + 1
            arr(k, cot + 1) = Darr(n, 3)
            arr(k, cot + 1 + max1) = Darr(n, 4)
            arr(k, cot + 1 + 2 * max1) = Darr(n, 5)
            arr(k, cot + 1 + 3 * max1) = Darr(n, 6)
            arr(k, cot + 1 + 4 * max1) = Darr(n, 7)
            i = n - 1
            GoTo tiep
    Next n
tiep:
thoat:
For n = 2 To k
    k2 = 5 * max1 + 16: k3 = 5 * max1 + 16 + max2
    Dic2.RemoveAll: Dic3.RemoveAll
    For j = 22 To 27
        For m = 2 To UBound(Darr)
            If arr(n, 1) = Darr(m, 1) Then
                If j <= 24 Then
                    If Not Dic2.Exists(Darr(m, j)) Then
                        Dic2.Add Darr(m, j), ""
                        k2 = k2 + 1
                        arr(n, k2) = Darr(m, j)
                    If Not Dic3.Exists(Darr(m, j)) Then
                        Dic3.Add Darr(m, j), ""
                        k3 = k3 + 1
                        arr(n, k3) = Darr(m, j)
        Next m
Next n
Set Dic2 = Nothing: Set Dic3 = Nothing
Range("af1:dsC" & Range("af65000").End(xlUp).Row).ClearContents
Range("af1").Resize(k, 16 + max1 * 5 + max2 + max3) = arr
Chào diepminhhong,
Ôi ghen tị quá đi --=0
Hổng biết bạn có thử code ở bài #2 chưa? (mình trả lời đầu tiên mà vẫn bị cho ra rìa. hức)
Code mình thì kiểu cùi bắp thôi (bạn HieuCD chơi sang dùng tận 2 Dic liền). Bạn thử xem nhé.
(p/s: Có 6 cột cuối thì không hiểu quy luật so với kết quả của bạn: TC1->TC3 mà kết quả cần TC1->TC10)
Sub chính:
Sub Doc2Ngang()
Sheet1.Range("AF9:ZZ6500").ClearContents
Set cel2 = Sheet1.Range("AF1")
        rw = rw + 1
ReDim drr(1 To rw)
For i = 1 To rw
m = Application.Max(drr)
cel2.Value = cel1.Value '// BBS
cel2.Offset(0, 1).Value = cel1.Offset(0, 1).Value '// HM
cel2.Offset(1, 1).Resize(rw, 1) = cel1.Offset(1, 1).Value
'// Tieu de CV->KLNT
For i = 1 To 5
    For j = 1 To m
        rc = rc + 1
        If j = 1 Then cel2.Offset(0, 1).Offset(0, rc) = cel1.Offset(0, 1).Offset(0, i)
        If j > 1 Then cel2.Offset(0, 1).Offset(0, rc) = cel1.Offset(0, 1).Offset(0, i) & j - 1
'// Tieu de GBD->NDTC3
cel2.Offset(0, 5 * m + 2).Resize(1, 20).Value = _
cel1.Offset(0, 7).Resize(1, 20).Value
'// Ghi gia tri:
    j = 1
        cel2.Offset(0, 1).Offset(i, ii).Resize(1, drr(i)).Value = _
        Application.Transpose(cel1.Offset(0, 1).Offset(CV - 1, j).Resize(drr(i)))
        j = j + 1
    Next ii
    cel2.Offset(i, 5 * m + 2).Resize(1, 20).Value = _
    cel1.Offset(CV - 1, 7).Resize(1, 20).Value
Còn Function UniqueArray(), bạn chép lại ở bài #2 nhé.
bạn HieuCD chơi sang dùng tận 2 Dic liền.
dùng 2 Dic để giảm bớt vòng lặp và tăng tốc xử lý
6 cột cuối mới khó xơi, qui luật chia cột tương tự như 5 cột trước không biết trước số cột, nhưng lấy các dòng của nhóm 3 cột và không trùng, và xếp thứ tự từ nhỏ đến lớn. mình không viết lệnh xếp thứ tự mà theo thứ tự có trước
Đã xem lại và rõ quy luật của 2 nhóm TC và NDTC. Cảm ơn HieuCD.
Số lượng phần tử TC = max (số giá trị không lặp lại của nhóm TC ứng với mỗi BBS) và tương tự với nhóm NDTC.
Theo kết quả đã cho thì quy luật xếp giá trị vào tương ứng với các phần tử của nhóm (ứng với mỗi BBS) lấy theo cột (đã loại trùng) từ trái sang phải rồi xoay thành hàng.
max2 = 0:           max3 = 0
        k1 = k1 + 1
        For j = 22 To 24
        For n = 25 To 27
        Next n
        k2 = 0:     k3 = 0
    If j <= 2 Then
For j = 1 To max2
For j = 1 To max3
k = 1
    cot = 1
            cot = cot + 1
            i = n - 1
            GoTo tiep
    Next n
tiep:
thoat:
For n = 2 To k
    For j = 22 To 27
                If j <= 24 Then
                        k2 = k2 + 1
                        k3 = k3 + 1
        Next m
Next n
Vâng, em cảm ơn anh nhiều ạ. E chúc anh sức khỏe và thành công ạ!
Chào diepminhhong,
Sub chính:
Sub Doc2Ngang()
        rw = rw + 1
ReDim drr(1 To rw)
For i = 1 To rw
For i = 1 To 5
    For j = 1 To m
        rc = rc + 1
'// Ghi gia tri:
    j = 1
        j = j + 1
    Next ii
Anh befaint ơi, Code ở bài 2 e cũng thử rồi anh ạ. Cũng ok anh ạ. Và cả code xóa trắng bảng số liệu trong Word anh gửi cho e nữa, e đã thử và làm được rồi. E cảm ơn anh nhiều nhé! Đừng ghen tị chứ vì diễn đàn có những người như anh HieuCD và anh befaint thì những người yếu về excel như bọn e đây được nhờ nhiều lắm anh ạ. E chúc a sức khỏe nhiều để công tác tốt nhé!
TC1, TC2, TC3 của em bên cột dọc ứng với mỗi công việc có thể giống nhau, có thể khác nhau. Mỗi TC thì ứng với 1 nội dung. Khi copy chuyển sang ngang thì e cũng muốn chuyển các TC sang hàng ngang và ứng với nó là các NDTC Nhưng các công việc mà có TC giống nhau thì khi copy sang hàng ngang thì mình loại bỏ cái TC giống nhau đi(giả sử có 3 TC giống nhau thì chỉ lấy 1 TC thôi còn 2 cái giống còn lại thì bỏ đi. NDTC cũng vậy anh ạ).
max2 = 0:           max3 = 0
        k1 = k1 + 1
        For j = 22 To 24
        For n = 25 To 27
        Next n
        k2 = 0:     k3 = 0
    If j <= 2 Then
For j = 1 To max2
For j = 1 To max3
k = 1
    cot = 1
            cot = cot + 1
            i = n - 1
            GoTo tiep
    Next n
tiep:
thoat:
For n = 2 To k
    For j = 22 To 27
                If j <= 24 Then
                        k2 = k2 + 1
                        k3 = k3 + 1
        Next m
Next n
Anh HieuCD ơi, code anh gửi cho em thì nếu chạy cái file e tải lên thì chạy được còn nếu chạy file khác hoặc thêm dòng ngang ở phía dưới ( nghĩa là ở cột BBS không phải là tới 4 mà có thể là vài trăm chẳng hạn) thì nó báo lỗi Run-time error '9'. Sau đó em kích vào chứ debug thì nó hiện code lên và bôi vàng dòng "arr(n, k3) = Darr(m, j) ". E chẳng hiểu mô tê gì. Anh có thể giúp em với được không ạ. E cảm ơn nhiều ạ. (E có file đính kèm phía dưới đấy ạ).
bạn thêm đoạn code màu đỏ vào
thoat:
For n = 2 To k
    For j = 22 To 27
            If arr(n, 1) = Darr(m, 1) [COLOR=#ff0000]And Darr(m, j) <>[/COLOR] [COLOR=#ff0000]""[/COLOR] Then
                If j <= 24 Then
                        k2 = k2 + 1
                        k3 = k3 + 1
        Next m
Next n
Chào diepminhhong,
Góp ý với bạn, lần sau trích dẫn bài của ai đó để trả lời thì bạn chỉ cần trích dẫn phần cần thiết, phần cần lưu tâm tới, không nên trích dẫn nguyên cả bài (nhất là bài chứa code dài như trên) dẫn đến kéo dài trang, khó xem.
Nếu không cần trích dẫn thì bạn có thể bắt đầu bài viết của mình muốn nói với một hoặc nhiều người thì viết vầy:
"Chào một ai đó" hoặc "Gửi một ai đó"
"Chào người một, người thứ hai..."
Thân,
Chào diepminhhong,
Thân,
Vâng ạ, e cảm ơn anh befaint đã góp ý cho e ạ. E cũng là thành viên mới có gì chưa đúng với nội quy của diễn đàn các anh chỉ bảo giúp e ạ.
thoat:
For n = 2 To k
    For j = 22 To 27
                If j <= 24 Then
                        k2 = k2 + 1
                        k3 = k3 + 1
        Next m
Next n
Anh ơi không hiểu sao e chạy code đó vào file của em thì vẫn báo lỗi. File của em có tất cả số BBS là 81 nhưng e chạy code chỉ được tới BBS 62 thôi. Còn chạy tới BBS 63 trở đi thì lại bị lỗi. Từ BBS 63 trở đi thì cái được cái thì bị lỗi (vì em ngồi dò thủ công từng BBS một nên e thấy như vậy). E có gửi file đính kèm, anh có thể kiểm tra giúp e với được không ạ. E biết e hỏi hơi nhiều, nhưng thực sự e không biết gì về phần code này cả. Mong anh thông cảm ạ.
bạn kiểm tra lại code
max2 = 0:           max3 = 0
        k1 = k1 + 1
        For j = 22 To 24
            If Not Dic2.Exists(Darr(i, j)) And Darr(i, j) <> "" Then
        For n = 25 To 27
            If Not Dic3.Exists(Darr(i, n)) And Darr(i, n) <> "" Then
        Next n
        k2 = 0:     k3 = 0
        For j = 22 To 24
        For n = 25 To 27
        Next n
    If j <= 2 Then
For j = 1 To max2
For j = 1 To max3
k = 1
    cot = 1
            cot = cot + 1
            i = n - 1
            GoTo tiep
    Next n
tiep:
thoat:
For n = 2 To k
    For j = 22 To 27
            If arr(n, 1) = Darr(m, 1) And Darr(m, j) <> "" Then
                If j <= 24 Then
                    If Not Dic2.Exists(Darr(m, j)) And Darr(m, j) <> "" Then
                        k2 = k2 + 1
                    If Not Dic3.Exists(Darr(m, j)) And Darr(m, j) <> "" Then
                        k3 = k3 + 1
        Next m
Next n
Range("ac1:hh" & Range("ac65000").End(xlUp).Row).ClearContents
Range("ac1").Resize(k, 16 + max1 * 5 + max2 + max3) = arr
Anh HieuCD ơi, Anh có thể xem lại giúp em file này với được k ạ? (file đính kèm). E cảm ơn anh ạ
như vậy là lúc nào cũng có 16 cột CV? code sẽ đơn giản hơn nhiều
các cột cuối TC và NDTC có qui định số cột không? hay lấy vừa đủ?
bạn cho biết và sáng mai mình sẽ viết code lại, đơn giản hơn nhiều
Vâng ạ. Khi chuyển sang hàng ngang thì dù số BBS có nhiều hay ít thì khi chuyển sang hàng ngang thì lúc nào cũng phải có từ CV, CV1 tới CV15 tương ứng là ĐV, KLTK, KLTC, KLNT(Code đầu tiên anh gửi cho e là anh viết như thế). Còn cột TC và NDTC thì chỉ cần tới 10 thôi ạ. Tức là TC1....TC10 và NDTC1.... tới NDTC10. Cột TC và NDTC thì TC1 tương ứng với NDTC1, TC2 tương ứng với NDTC2...... và loại bỏ trùng nhau. E làm tới 10 để phòng thôi chứ thực ra chỉ tới 6 là nhiều rồi anh ạ. Tóm lại cái cột TC với NDTC đấy anh viết sao cũng được chỉ cần TC1 tương ứng với NDTC1........ và loại bỏ trùng nhau thôi ạ.
Vậy thì bạn còn chưa nắm được quy luật tạo ra số lượng CV.
Số lượng CV = max (count BBS(i) trong BBS)
Còn số lượng nhóm TC và NDTC như tôi đã diễn đạt lại theo hướng dẫn của HieuCD ở bài #18.
Cái đó thì e biết rồi anh befaint ạ. Sở dĩ e muốn cái nào cũng là 16 là vì nó liên quan tới 1 file sau này của e. E để mặc định nó là 16 rồi. file đó = max số BBS anh ạ. Vì phần code em k biết gì nên khó chỉnh sửa nên e phải để vậy. Mong các anh giúp đỡ.
code chạy với số cột cố định, khi cần thay đổi thì bạn khai báo lại số cột trong code
Sub CopyDoc_Ngang()
Dim Dic As Object, Darr, arr()
Dim i As Long, n As Long, m As Long, j As Integer, k As Integer, k2 As Integer, Scot1 As Integer, Scot2 As Integer
Darr = Range("a1:aa" & Range("a1").End(xlDown).Row)
Scot1 = 16  'so cot NV
Scot2 = 6   'so cot TC. Khi can thay doi thi dieu chinh cac so cot lai
ReDim arr(1 To UBound(Darr), 1 To 16 + 5 * Scot1 + 2 * Scot2)   'tong cot la 108=16+5*16+2*6
'tao tieu de cot
For j = 1 To 16 + 5 * Scot1
    If j <= 2 Then
    ElseIf j >= 5 * Scot1 + 3 Then
        arr(1, j) = Darr(1, j - 5 * Scot1 + 5)
    ElseIf j Mod Scot1 = 3 Then
        arr(1, j) = Darr(1, Int(j / Scot1) + 3)
        arr(1, j) = Darr(1, Int((j - 3) / Scot1) + 3) & ((j - 3) Mod Scot1)
For j = 1 To Scot2
    arr(1, j + 16 + Scot1 * 5) = "TC" & j
    arr(1, j + 16 + Scot1 * 5 + Scot2) = "NDTC" & j
'Lay du lieu toi cot Nam1
k = 1
    For j = 5 * Scot1 + 3 To 5 * Scot1 + 16
        arr(k, j) = Darr(i, j - 5 * Scot1 + 5)
    cot = 1
            cot = cot + 1
            arr(k, cot + 1 + Scot1) = Darr(n, 4)
            arr(k, cot + 1 + 2 * Scot1) = Darr(n, 5)
            arr(k, cot + 1 + 3 * Scot1) = Darr(n, 6)
            arr(k, cot + 1 + 4 * Scot1) = Darr(n, 7)
            i = n - 1
            GoTo tiep
    Next n
tiep:
thoat:
'Lay du lieu  cot TC va NDTC
For n = 2 To k
    k2 = 5 * Scot1 + 16
    Dic.RemoveAll
    For j = 22 To 24
                If Not Dic.Exists(Darr(m, j)) And Darr(m, j) <> "" Then
                    Dic.Add Darr(m, j), ""
                    k2 = k2 + 1
                    arr(n, k2 + Scot2) = Darr(m, j + 3)
        Next m
Next n
Set Dic = Nothing
Range("ac1:en" & Range("ac65000").End(xlUp).Row).Clear
Range("ac1").Resize(k, 16 + Scot1 * 5 + 2 * Scot2) = arr
Range("ac1").Resize(k, 16 + Scot1 * 5 + 2 * Scot2).Borders.LineStyle = 1
Chào diepminhhong,
Tôi viết code cho trường hợp số BBS, số TC/ NDTC là tuỳ dữ liệu nhập vào (theo cấu trúc File của bạn).
Số dòng trong Sub chính cũng gần bằng bài #33 nhưng lại dùng thêm 4 Function --=0--=0
Mời bạn xem file.
Chào diepminhhong,
Mời bạn xem file.
E cảm ơn anh befaint. Hôm nay đi làm e mới vào diễn đàn và đọc được bài của anh. E đang down về thử xem sao. Cảm ơn anh nhiều nhé.
