Chuyên đề giải đáp các bài tập Excel (Phần 4) (12 người xem)
Ae giúp em tính điểm của cửa hàng dựa vào bảng điểm phân loại hàng hóa . Cám ơn rất nhiều ạ
Bạn dùng công thức sau =C2*VLOOKUP(B2,$F$2:$G$13,2,0)
[TABLE="width: 294"]
[TR]
[TD]CỬA HÀNG[/TD]
[TD]MODEL[/TD]
[TD]SỐ LƯỢNG[/TD]
[TD]TÍNH ĐiỂM[/TD]
[/TR]
[TR]
[TD]SIEUTHI[/TD]
[TD]CANCAU[/TD]
[TD]1[/TD]
[TD]1[/TD]
[/TR]
[TR]
[TD]CHO[/TD]
[TD]TULANH[/TD]
[TD]2[/TD]
[TD]#VALUE![/TD]
[/TR]
[TR]
[TD]CUAHANG[/TD]
[TD]GAO[/TD]
[TD]2[/TD]
[TD]4[/TD]
[/TR]
[TR]
[TD]TAPHOA[/TD]
[TD]BANH[/TD]
[TD]56[/TD]
[TD]56[/TD]
[/TR]
[TR]
[TD]BIGC[/TD]
[TD]THIT[/TD]
[TD]2[/TD]
[TD]#VALUE![/TD]
[/TR]
[TR]
[TD]METRO[/TD]
[TD]CA[/TD]
[TD]2[/TD]
[TD]#VALUE![/TD]
[/TR]
[TR]
[TD]SIEUTHI[/TD]
[TD]RAU[/TD]
[TD]4[/TD]
[TD]#VALUE![/TD]
[/TR]
[TR]
[TD]CUAHANG[/TD]
[TD]RAU[/TD]
[TD]3[/TD]
[TD]#VALUE![/TD]
[/TR]
[TR]
[TD]CUAHANG[/TD]
[TD]BANH[/TD]
[TD]14[/TD]
[TD]14[/TD]
[/TR]
[TR]
[TD]SIEUTHI[/TD]
[TD]KEO[/TD]
[TD]24[/TD]
[TD]#VALUE![/TD]
[/TR]
[TR]
[TD]TAPHOA[/TD]
[TD]GIAY[/TD]
[TD]532[/TD]
[TD]1064[/TD]
[/TR]
[TR]
[TD]CUAHANG[/TD]
[TD]TIVI[/TD]
[TD]2356[/TD]
[TD]4712[/TD]
[/TR]
[TR]
[TD]SIEUTHI[/TD]
[TD]DVD[/TD]
[TD]1343[/TD]
[TD]#VALUE![/TD]
[/TR]
[TR]
[TD]HOBOI[/TD]
[TD]PHAO[/TD]
[TD]212[/TD]
[TD]#VALUE![/TD]
[/TR]
[TR]
[TD]CUAHANG[/TD]
[TD]PHAO[/TD]
[TD]323[/TD]
[TD]#VALUE![/TD]
[/TR]
[/TABLE]
1 SÓ BỊ LỖI
[TR]
[TD]CỬA HÀNG[/TD]
[TD]MODEL[/TD]
[TD]SỐ LƯỢNG[/TD]
[TD]TÍNH ĐiỂM[/TD]
[/TR]
[TR]
[TD]SIEUTHI[/TD]
[TD]CANCAU[/TD]
[TD]1[/TD]
[TD]1[/TD]
[/TR]
[TR]
[TD]CHO[/TD]
[TD]TULANH[/TD]
[TD]2[/TD]
[TD]#VALUE![/TD]
[/TR]
[TR]
[TD]CUAHANG[/TD]
[TD]GAO[/TD]
[TD]2[/TD]
[TD]4[/TD]
[/TR]
[TR]
[TD]TAPHOA[/TD]
[TD]BANH[/TD]
[TD]56[/TD]
[TD]56[/TD]
[/TR]
[TR]
[TD]BIGC[/TD]
[TD]THIT[/TD]
[TD]2[/TD]
[TD]#VALUE![/TD]
[/TR]
[TR]
[TD]METRO[/TD]
[TD]CA[/TD]
[TD]2[/TD]
[TD]#VALUE![/TD]
[/TR]
[TR]
[TD]SIEUTHI[/TD]
[TD]RAU[/TD]
[TD]4[/TD]
[TD]#VALUE![/TD]
[/TR]
[TR]
[TD]CUAHANG[/TD]
[TD]RAU[/TD]
[TD]3[/TD]
[TD]#VALUE![/TD]
[/TR]
[TR]
[TD]CUAHANG[/TD]
[TD]BANH[/TD]
[TD]14[/TD]
[TD]14[/TD]
[/TR]
[TR]
[TD]SIEUTHI[/TD]
[TD]KEO[/TD]
[TD]24[/TD]
[TD]#VALUE![/TD]
[/TR]
[TR]
[TD]TAPHOA[/TD]
[TD]GIAY[/TD]
[TD]532[/TD]
[TD]1064[/TD]
[/TR]
[TR]
[TD]CUAHANG[/TD]
[TD]TIVI[/TD]
[TD]2356[/TD]
[TD]4712[/TD]
[/TR]
[TR]
[TD]SIEUTHI[/TD]
[TD]DVD[/TD]
[TD]1343[/TD]
[TD]#VALUE![/TD]
[/TR]
[TR]
[TD]HOBOI[/TD]
[TD]PHAO[/TD]
[TD]212[/TD]
[TD]#VALUE![/TD]
[/TR]
[TR]
[TD]CUAHANG[/TD]
[TD]PHAO[/TD]
[TD]323[/TD]
[TD]#VALUE![/TD]
[/TR]
[/TABLE]
1 SÓ BỊ LỖI
Bị lỗi là do bạn định dạng ở phần dò tìm sai. Ví dụ 1,5 mà không phải 1.5
nhờ anh chị giải dùm em bài này , Sheet 1 là em export tất cả con hàng từ 4 kho ra, có cách nào dùng 1 công thức để tính được số lượng có tất cả kho không ạ, chứ dùng hàm vlook up từng kho thì rất tốn thời gian , vì có rất nhiều kho , mỗi kho dùng 1 hàm thì tốn thời gian rất nhiều
upppppppp -+*/
Tính điểm đã được rồi. Giờ muốn cộng điểm của từng cửa hàng lại thì bạn lọc ra danh sách cửa hàng duy nhất. Sau đó sumif lại
Các anh chị gíup em bài này với ạ. Em cảm ơn!
    56 KB · Đọc: 57
Các bác ơi trình dùng hàm của em còn non, phụ em một tay với.
Em muốn tổng hợp dữ liệu vào sheet sum. Phụ em cái công thức ah. Cảm ơn cả nhà.
=SUMPRODUCT((('basic data'!$F$2:$F$346)*1=sum!$B3)*('basic data'!$J$2:$J$346)*(MONTH('basic data'!$A$2:$A$346)=COLUMNS($A:A)))
Không biết bạn tính cột nào và điều kiện ra sao, làm đại cho bạn hên suôi, với 2 đk, tháng và tài khoản
Bạn xem trong file đính kèm nhé!
=SUMPRODUCT((MONTH('basic data'!$A$2:$A$346)=sum!C$2)*(('basic data'!$F$2:$F$346+0)=sum!$B3)*'basic data'!$G$2:$G$346)
Dữ liệụ tài khoản bên sheet "data basic" là chuỗi trong khi sheet "sum" là số
Cột mà bạn cần tính tổng
Chào minhabc
Để xử lý nhanh và nhẹ tập tin, ngoài việc dùng hàm như bạn phihndhsp đã giúp bạn, bạn thử thêm phương án khác như dùng công cụ Insert/Pivot table cho yêu cầu tổng hợp tài khoản theo từng tháng (năm). Khi thay đổi thông tin nguồn (bảng basic data), bạn chỉ cần "làm tươi" (refresh) bên bảng Pivot table là có thông tin mới. Bạn xem thử đính kèm có như ý của bạn không!
Chúc bạn ngày vui.
Các bác ơi giúp em làm sheet 1 với, bỏ câu vẽ biểu đồ ạ.
Mong các bác giúp, em cảm ơn nhiều! -\\/.
sheet 1 chắc là sheet có tên "BAI SO 1" ?
mình cũng mới học excel nên đánh liều làm thử câu đầu tiên :
công thức ô K2 mình sử dụng là
=SUM(G2:J2)
mấy câu dưới khó quá mình chưa làm nỗi . híc +-+-+-++-+-+-+
=SUM(G2:J2)
Không đúng rồi bác "Chim Hồng"
2. Lập công thức cho cột Tổng điểm biết các môn không có hệ số
=> Tổng điểm = "Không"
