Hỏi về chữ Unicode trong Code (1 người xem)
  • Thread starter Thread starter ncq2003
ncq2003
Mình tìm được đoạn code này
Function Klg(rng As String)
Dim i As Integer
Dim strTemp As String
rng = Application.Trim(Right(rng, Len(rng) - InStr(rng, ":")))
rng = Replace(rng, "m2", "")
rng = Replace(rng, "m3", "")
For i = 1 To Len(rng)
    Select Case Asc(Mid(rng, i, 1))
    Case 40 To 57, 94
        strTemp = strTemp & Mid(rng, i, 1)
    End Select
strTemp = Replace(strTemp, ",", ".")
strTemp = Replace(strTemp, "/*", "*")
strTemp = Replace(strTemp, "/+", "+")
strTemp = Replace(strTemp, "/-", "-")
strTemp = Replace(strTemp, "//", "/")
If Right(strTemp, 1) = "/" Then strTemp = Left(strTemp, Len(strTemp) - 1)
Klg = Evaluate(strTemp)
Function DocSo(ByVal Number, Optional ByVal Font = 1) As String
Dim MyArray
Dim Str
Str = Format(Abs(Number), "000000000000000000")
Select Case Font
Case 1
MyArray = Array("không ", "m" & ChrW(7897) & "t ", "hai ", "ba ", "b" & ChrW(7889) & "n ", "n" & ChrW(259) & "m ", "sáu ", "b" & ChrW(7843) & "y ", "tám ", "chín ", "tri" & ChrW(7879) & "u, ", "ngàn, ", "t" & ChrW(7927) & ", ", "tri" & ChrW(7879) & "u, ", "ngàn, ", "", "tr" & ChrW(259) & "m ", "m" & ChrW(432) & ChrW(417) & "i ", "không " & "m" & ChrW(432) & ChrW(417) & "i" & " không ", "không " & "m" & ChrW(432) & ChrW(417) & "i", "l" & ChrW(7867), "m" & ChrW(432) & ChrW(417) & "i" & " không", "m" & ChrW(432) & ChrW(417) & "i", "m" & ChrW(432) & ChrW(417) & "i" & " n" & ChrW(259) & "m", "m" & ChrW(432) & ChrW(417) & "i" & " l" & ChrW(259) & "m", "m" & ChrW(7897) & "t " & "m" & ChrW(432) & ChrW(417) & "i", "m" & ChrW(432) & ChrW(7901) & "i", "m" & ChrW(432) & ChrW(417) & "i" & " m" & ChrW(7897) & "t", "m" & ChrW(432) & ChrW(417) & "i" & " m" & ChrW(7889) & "t", "Âm ")
Case 2
MyArray = Array("khoâng ", "moät ", "hai ", "ba ", "boán ", "naêm ", "saùu ", "baûy ", "taùm ", "chín ", "trieäu, ", "ngaøn, ", "tyû, ", "trieäu, ", "ngaøn, ", "", "traêm ", "möôi ", "khoâng möôi khoâng ", "khoâng möôi", "leû", "möôi khoâng", "möôi", "möôi naêm", "möôi laêm", "moät möôi", "möôøi", "möôi moät", "möôi moát", "AÂm ")
Case 3
MyArray = Array("kh«ng ", "mét ", "hai ", "ba ", "bèn ", "n¨m ", "s¸u ", "b¶y ", "t¸m ", "ch?n ", "triÖu, ", "ngµn, ", "tû, ", "triÖu, ", "ngµn, ", "", "tr¨m ", "m­¬i ", "kh«ng m­¬i kh«ng ", "kh«ng m­¬i", "lÎ", "m­¬i kh«ng", "m­¬i", "m­¬i n¨m", "m­¬i l¨m", "mét m­¬i", "m­êi", "m­¬i mét", "m­¬i mèt", "©m ")
End Select
If Str = "000000000000000000" Then
    DocSo = UCase(Left(MyArray(0), 1)) & Trim(Mid(MyArray(0), 2)) & "."
    Exit Function
For i = 1 To Len(Str)
If Left(Str, i) <> 0 And Mid(Str, (Int((i + 2) / 3) - 1) * 3 + 1, 3) <> 0 Then
    DocSo = DocSo & MyArray(Mid(Str, i, 1)) & MyArray(-(9 + i / 3) * (i Mod 3 = 0) - (15 + i Mod 3) * (i Mod 3 <> 0))
ElseIf i = 9 And Mid(Str, 7, 3) = 0 And Left(Str, 6) <> 0 Then
    DocSo = DocSo & MyArray(12)
DocSo = Trim(Replace(Replace(Replace(Replace(Replace(Replace(DocSo, MyArray(18), MyArray(15)), MyArray(19), MyArray(20)), MyArray(21), MyArray(22)), MyArray(23), MyArray(24)), MyArray(25), MyArray(26)), MyArray(27), MyArray(28)))
If Number < 0 Then
DocSo = MyArray(29) & DocSo
DocSo = Replace(UCase(Left(DocSo, 1)) & Mid(DocSo, 2) & ".", ",.", " ")
Các bạn cho mình hỏi mình muốn thêm chữ đồng vào cuối Hàm thì thêm vào trong code thế nào
Ví dụ : Hàm docso(123) => Một trăm hai mươi ba
Mình muốn hàm trên thành Một trăm hai mươi ba đồng
P/S : mình muốn thêm luôn vào trong code.
Cám ơn các bạn đã đọc và giúp đỡ
Sửa đoạn code gần cuối cùng như sau:
DocSo = Replace(UCase(Left(DocSo, 1)) & Mid(DocSo, 2) & " ", ",.", " ") & ChrW(273) & ChrW(7891) & "ng"
trước tiên cảm ơn Bạn
Cho mình hỏi tiếp Ví dụ mình có : docso(7600000) => Bảy triệu, bảy trăm ngàn, đồng.
Mình muốn bỏ dấu "," trước chữ "đồng" thì sửa code như thế nào
MÌnh đính kèm file nhờ bạn xem giùm
Bạn thêm câu lệnh sau:
DocSo = Replace(DocSo, ", " & ChrW(273) & ChrW(7891) & "ng", " " & ChrW(273) & ChrW(7891) & "ng")
Cám ơn bạn, Đã chạy
Còn tiếp vấn đề docso(7600000;2) => thì chữ đồng không hiện mà chữ như vầy
Bảy triệu, bảy trăm ngàn ồng.
(Ý mình là chọn font VNI đó mà)
Mong bạn giúp mình tiếp
Cám ơn bạn, Đã chạy
Bảy triệu, bảy trăm ngànồng.
Thay cả cụm lệnh cuối luôn nhé!
If Font = 1 Then
    If Font = 2 Then
        DocSo = Replace(UCase(Left(DocSo, 1)) & Mid(DocSo, 2) & " ", ",.", " ") & "ñoàng"
        DocSo = Replace(DocSo, ", ñoàng", " ñoàng")
        DocSo = Replace(UCase(Left(DocSo, 1)) & Mid(DocSo, 2) & " ", ",.", " ") & "®ång"
        DocSo = Replace(DocSo, ", ®ång", " ®ång")
Cám ơn bạn, code này chạy tốt rồi
