toantinhte87
Đây là 1 đoạn code của các bạn trên diễn đàn. Nhưng khi mình copy qua file khác thì Không chạy được đoạn code dưới khi copy vào file excel khác????
Private Sub ListFilesInFolder(FolderName As String, InSub As Boolean)
Dim FileItem As Scripting.File, SubFolder As Scripting.Folder, FileName As String
On Error GoTo ExitSub
With New Scripting.FileSystemObject
For Each FileItem In .GetFolder(FolderName).Files
If .GetExtensionName(FileItem.Path) = "xls" Then
With Range("A65536").End(xlUp)
With .Offset(1, 0)
.Value = FileItem.Path
.Parent.Hyperlinks.Add .Cells, .Value
.Offset(1, 1) = FileItem.Size
.Offset(1, 2) = FileItem.DateCreated
.Offset(1, 3) = FileItem.DateLastModified
Next FileItem
If InSub Then
For Each SubFolder In .GetFolder(FolderName).SubFolders
ListFilesInFolder SubFolder.Path, True
Next SubFolder
ExitSub:
Sub GetFileList()
Sheet1.Select
Range("A2
60000").ClearContents
With Application.FileDialog(4)
.Show: .AllowMultiSelect = False
ListFilesInFolder .SelectedItems(1), True
Columns("A:E").AutoFit
ExitSub:
With .Offset(1, 0)
Next FileItem
If InSub Then
Next SubFolder
ExitSub:
Sub GetFileList()
Sheet1.Select
Range("A2
ExitSub:
