hungnguyen1011
Hi mọi người,
như tiêu đề giúp em fix lỗi mấy dòng code.
Sub HighOrLow()
Dim name As String
Dim balance As Long
Dim Cards
Dim Bet
Dim HiLo As String
name = InputBox("Please enter your name:")
MsgBox ("Hi " & name & " Welcome to High and Low game")
balance = 100
If name = vbNullString Then Exit Sub
Cards = Array("Ace", 2, 3, 4, 5, 6, 7, 8, 9, 10, "Jack", "Queen", "King")
Call GetBet((name), (balance))
Call GetHighOrLow((name), (balance), (Bet), (Cards))
Function GetBet(name As String, balance As Long)
Dim Bet As Integer
Bet = Application.InputBox(name & ", your current balance is $" & balance & "." & vbNewLine & "How much do you want to bet?")
MsgBox ("So you want to bet: " & Bet & "$")
If Bet = False Then Exit Function
If Bet <> Int(Bet) Or Bet < 1 Or Bet > balance Then
MsgBox (name & ", you must enter a whole number between 1 and " & balance & ".")
Call GetBet(name, balance)
Function GetHighOrLow(name As String, balance As Long, Bet As Integer, Cards)
Dim HiLo As String
Dim ComCard As String
Dim RanCard(1 To 2) As Integer
Randomize
RanCard(1) = Int(13 * Rnd + 1)
RanCard(2) = Int(13 * Rnd + 1)
HiLo = InputBox(name & ", your card is: " & RanCard(1) & vbNewLine & "Do you think the computer's card is higher [H] or lower [L]?")
If Not UCase(HiLo) Like "[HL]" Then
MsgBox (name & ", you must enter [H] for higher or [L] for lower.")
Call GetHighOrLow(name, balance, Bet, Cards)
If HiLo = vbNullString Then Exit Function
ComCard = (vbNewLine & "The computer's card is: " & Application.Index(Cards, RanCard(2)))
Select Case UCase(HiLo)
Case "H"
Select Case True
Case RanCard(2) > RanCard(1)
MsgBox "That's correct, " & name & "." & ComCard, vbInformation, "Result" & balance = balance + Bet
Case RanCard(2) < RanCard(1)
MsgBox "That's incorrect, " & name & "." & ComCard, vbInformation, "Result" & balance = balance - Bet
Case Else
MsgBox "It's a tie, " & name & "." & ComCard, vbInformation, "Result"
End Select
Case "L"
Select Case True
Case Else
End Select
End Select
If balance > 0 Then
MsgBox (name & ", your balance is $0." & "Thanks for playing this game" & " see ya")
Sub HighOrLow()
Dim name As String
Dim balance As Long
Dim Cards
Dim Bet
Dim HiLo As String
balance = 100
Dim Bet As Integer
Dim HiLo As String
Randomize
Case "H"
Select Case True
Case Else
End Select
Case "L"
Select Case True
Case Else
End Select
End Select
If balance > 0 Then
