Mong anh em trong GPE ai giúp chuyển từ công thức qua dạng vòng lặp để tính toán cho nhanh giúp.
Điểm khác biệt trong các công thức đã được chuyển thành màu đỏ.
Xin chân thanh cảm ơn.
Sub PPM_0805()
ThisWorkbook.Worksheets("Flow").Range("I2").Select
Range("[COLOR=#ff0000][B]I3[/B][/COLOR]").Select
ActiveCell.FormulaR1C1 = _
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[B][COLOR=#ff0000][-3][/COLOR][/B])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("[COLOR=#ff0000][B]I4[/B][/COLOR]").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[B][COLOR=#ff0000][-2][/COLOR][/B])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("[COLOR=#ff0000][B]I5[/B][/COLOR]").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[B][COLOR=#ff0000][-1][/COLOR][/B])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I6").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C)/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I7").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[1])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I8").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[2])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I9").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[3])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I10").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[4])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I11").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[5])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I12").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[6])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I13").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[7])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I14").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[8])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I15").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[9])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I16").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[10])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I17").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[11])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I18").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[12])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I19").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[13])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I20").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[14])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I21").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[15])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I22").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[16])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I23").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[17])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I24").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[18])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I25").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[19])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I26").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[20])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I27").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[21])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I28").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[22])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I29").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[23])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I30").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[24])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I31").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[25])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I32").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[26])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I33").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[27])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I34").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[28])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I35").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[29])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I36").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[30])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I37").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[31])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I38").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[32])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I39").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[33])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I40").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[34])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I41").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[35])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I42").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[36])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I43").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[37])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I44").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[38])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I45").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[39])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I46").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[40])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I47").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[41])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I48").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[42])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I49").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[43])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I50").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[44])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I51").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[45])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I52").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[46])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I53").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[47])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I54").Select
"=IFERROR(SUMIF(CHP!C[49],Flow!R2C9,CHP!C[48])/SUMIF(CHP!C[49],Flow!R2C9,CHP!C[-5])*1000000,""-"")"
Range("I3:I55").Select
Selection.Copy
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
:=False, Transpose:=False
ActiveWorkbook.Save
