| Name | Required/Optional | Description |
[TH="width: 10%"]
Data Type
[/TH]
[TD="class: mainsection"]
Field
[/TD]
[TD="class: mainsection"]Optional[/TD]
Variant
[/TD]
[TD="class: mainsection"]The integer offset of the field on which you want to base the filter (from the left of the list; the leftmost field is field one).[/TD]
Criteria1
[/TD]
Variant
[/TD]
[TD="class: mainsection"]The criteria (a string; for example, "101"). Use "=" to find blank fields, or use "<>" to find nonblank fields. If this argument is omitted, the criteria is All. If
Operator
is
xlTop10Items
Criteria1
specifies the number of items (for example, "10").[/TD]
Operator
[/TD]
XlAutoFilterOperator
[/TD]
[TD="class: mainsection"]One of the constants of XlAutoFilterOperator specifying the type of filter.[/TD]
Criteria2
[/TD]
Variant
[/TD]
[TD="class: mainsection"]The second criteria (a string). Used with
Criteria1
and
Operator
to construct compound criteria.[/TD]
VisibleDropDown
[/TD]
Variant
[/TD]
True
to display the AutoFilter drop-down arrow for the filtered field.
False
to hide the AutoFilter drop-down arrow for the filtered field.
True
by default.[/TD]
