Em có code như thế này
Nhờ anh/chị sửa giùm sao cho nó chạy lặp để chèn dọc theo cột đó liên tục từ Q23,Q24 đế Q150,Q151
Đồng thời cứ 4 ảnh thì đường dẫn folder thay đổi 1, 2, 3...
Em cảm ơn anh chị trước ạ
HTML:
Sub CHENANHAUTO()'' CHENANH Macro' Macro recorded 10/24/2015 by TRAN VAN LINH'' Keyboard Shortcut: Ctrl+Shift+L' '////////ANH SO 1//////// Range("Q23:Q24").Select ActiveSheet.Pictures.Insert( _ "C:\Windows\system32\config\systemprofile\Desktop\Bu venh base\Du lieu\ANH SO HOA BU VENH\BU VENH LOP 1 86 87\1\1.jpg" _ ).Select ActiveWindow.SmallScroll Down:=3 Selection.ShapeRange.LockAspectRatio = msoTrue Selection.ShapeRange.Height = 110.25 Selection.ShapeRange.Width = 220.5 Selection.ShapeRange.Rotation = 0# With Selection .Placement = xlMoveAndSize .PrintObject = True End With
'///////ANH SO 2/////// Range("Q25:Q26").Select ActiveSheet.Pictures.Insert( _ "C:\Windows\System32\config\systemprofile\Desktop\Bu venh base\Du lieu\ANH SO HOA BU VENH\BU VENH LOP 1 86 87\1\5.jpg" _ ).Select Selection.ShapeRange.LockAspectRatio = msoTrue Selection.ShapeRange.Height = 110.25 Selection.ShapeRange.Width = 220.5 Selection.ShapeRange.Rotation = 0# With Selection .Placement = xlMoveAndSize .PrintObject = True End With
'//////ANH SO 3/////// Range("Q27:Q28").Select ActiveSheet.Pictures.Insert( _ "C:\Windows\System32\config\systemprofile\Desktop\Bu venh base\Du lieu\ANH SO HOA BU VENH\BU VENH LOP 1 86 87\1\3.jpg" _ ).Select Selection.ShapeRange.LockAspectRatio = msoTrue Selection.ShapeRange.Height = 110.25 Selection.ShapeRange.Width = 220.5 Selection.ShapeRange.Rotation = 0# With Selection .Placement = xlMoveAndSize .PrintObject = True End With
'/////////ANH SO 4////// Range("Q29:Q30").Select ActiveSheet.Pictures.Insert( _ "C:\Windows\System32\config\systemprofile\Desktop\Bu venh base\Du lieu\ANH SO HOA BU VENH\BU VENH LOP 1 86 87\1\7.jpg" _ ).Select Selection.ShapeRange.LockAspectRatio = msoTrue Selection.ShapeRange.Height = 110.25 Selection.ShapeRange.Width = 220.5 Selection.ShapeRange.Rotation = 0# With Selection .Placement = xlMoveAndSize .PrintObject = True End With
