Enum ColRes
idNo = 1
idTenHang = 2 [B][COLOR=#ff0000]<-----em chỉnh chổ này[/COLOR][/B]
idMaHang = 3
idDVT = 4
idTonDK = 5
idNhap = 6
idXuat = 7
idTonCK = 8
End Enum
Sub BaoCaoNhapXuatTon()
''Nap cac Du lieu nhap
Dim DmvTon(), MhNhap(), ddNhap(), SlgNhap(), MhXuat(), SlgXuat(), ddXuat()
Dim nDM As Long, nNhap As Long, nXuat As Long, nRes As Long
Dim Dic, arNXT(), aAdd()
Dim I As Long, K As Long, ddFr As Long, ddTo As Long, ik As ColRes
'Nhap cac du lieu Danh muc Hang Hoa va TonDau
With Range("DmvTon")
If .Offset(1).Value <> "" Then
DmvTon = Range(.Offset(1), .Offset(1).End(xlDown)).Resize(, 3).Value2
nDM = UBound(DmvTon)
MsgBox "Xem lai Du lieu Danh muc va Ton", vbOKOnly + vbCritical, "Danh muc va Ton"
Exit Sub
'Nhap Du lieu NHAP
With Range("NHAP")
MhNhap = Range(.Offset(1), .End(xlDown)).Value2
nNhap = UBound(MhNhap)
SlgNhap = .Offset(1, 2).Resize(nNhap).Value2
ddNhap = .Offset(1, -3).Resize(nNhap).Value2
MsgBox "Xem lai Du lieu chung tu NHAP", vbOKOnly + vbCritical, "Chung tu Nhap"
Exit Sub
'Nhap Du lieu XUAT
With Range("XUAT")
MhXuat = Range(.Offset(1), .End(xlDown)).Value2
nXuat = UBound(MhXuat)
SlgXuat = .Offset(1, 2).Resize(nXuat).Value2
ddXuat = .Offset(1, -5).Resize(nXuat).Value2
MsgBox "Xem lai Du lieu chung tu XUAT", vbOKOnly + vbCritical, "Chung tu Xuat"
Exit Sub
'Nhap Du lieu Tu Ngay -> Den Ngay
ddFr = Range("TUNGAY").Value2
ddTo = Range("DENNGAY").Value2
For I = 1 To nDM
Dic(DmvTon(I, 1)) = I
Next I
ReDim arNXT(1 To nDM + 10, idTonDK To idXuat)
For I = 1 To nDM
arNXT(I, idTonDK) = DmvTon(I, 2)
Next I
ReDim Preserve aAdd(1 To 1)
nRes = nDM
For I = 1 To nNhap
If ddNhap(I, 1) <= ddTo Then
K = Dic(MhNhap(I, 1))
If K = 0 Then
nRes = nRes + 1: K = nRes: Dic(MhNhap(I, 1)) = K
ReDim Preserve aAdd(1 To nRes - nDM): aAdd(nRes - nDM) = MhNhap(I, 1)
If ddNhap(I, 1) < ddFr Then 'ton
arNXT(K, idTonDK) = arNXT(K, idTonDK) + SlgNhap(I, 1)
Else 'trong ky
arNXT(K, idNhap) = arNXT(K, idNhap) + SlgNhap(I, 2)
Next I
For I = 1 To nXuat
If ddXuat(I, 1) <= ddTo Then
K = Dic(MhXuat(I, 1))
If K = 0 Then
nRes = nRes + 1: K = nRes: Dic(MhXuat(I, 1)) = K
ReDim Preserve aAdd(1 To nRes - nDM): aAdd(nRes - nDM) = MhXuat(I, 1)
If ddXuat(I, 1) < ddFr Then 'ton
arNXT(K, idTonDK) = arNXT(K, idTonDK) - SlgXuat(I, 1)
Else 'trong ky
arNXT(K, idXuat) = arNXT(K, idXuat) + SlgXuat(I, 1)
Next I
Range("KETQUA").Offset(1).Resize(6000, idTonCK).ClearContents
With Range("KETQUA").Offset(1)
K = -1
For I = 1 To nRes
If arNXT(I, idTonDK) <> 0 Or arNXT(I, idNhap) <> 0 Or arNXT(I, idXuat) <> 0 Then 'khong lay ton, nhap, xuat bang 0
K = K + 1
.Offset(K, idNo - 1).Value = K + 1
If I <= nDM Then
.Offset(K, idMaHang - 1) = DmvTon(I, 1)
.Offset(K, idTenHang - 1) = DmvTon(I, -1) [B][COLOR=#ff0000]<--------em chỉnh chổ này[/COLOR][/B]
.Offset(K, idDVT - 1) = DmvTon(I, 4)
.Offset(K, idMaHang - 1) = aAdd(I - nDM)
For ik = idTonDK To idXuat
.Offset(K, ik - 1) = arNXT(I, ik)
.Offset(K, idTonCK - 1) = arNXT(I, idTonDK) + arNXT(I, idNhap) - arNXT(I, idXuat)
Next I
K = K + 1
If nRes > nDM Then
MsgBox "Chuong trinh ket thuc" _
& vbLf & "co tat ca " & K & " ma hang duoc tinh NXT" _
& vbLf & vbLf & "Co " & nRes - nDM & " mat hang cuoi chua co trong Danh muc", _
vbOKOnly + vbCritical, "THONG BAO"
& vbLf & "co tat ca " & K & " ma hang duoc tinh NXT", _
vbOKOnly, "THONG BAO"
