ultimatum86
Const CharCode = "ChrW(7855), ChrW(7857), ChrW(7859), ChrW(7861), ChrW(7863), ChrW(7845), ChrW(7847),ChrW(7849), ChrW(7851), ChrW(7853), ChrW(225), ChrW(224), ChrW(7843), ChrW(227), ChrW(7841),ChrW(259), ChrW(226), ChrW(273), ChrW(7871), ChrW(7873), ChrW(7875), ChrW(7877), ChrW(7879),ChrW(233), ChrW(232), ChrW(7867), ChrW(7869), ChrW(7865), ChrW(234), ChrW(237), ChrW(236),ChrW(7881), ChrW(297), ChrW(7883), ChrW(7889), ChrW(7891), ChrW(7893), ChrW(7895), ChrW(7897),ChrW(7899), ChrW(7901), ChrW(7903), ChrW(7905), ChrW(7907), ChrW(243), ChrW(242), ChrW(7887),ChrW(245), ChrW(7885), ChrW(244), ChrW(417), ChrW(7913), ChrW(7915), ChrW(7917), ChrW(7919),ChrW(7921), ChrW(250), ChrW(249), ChrW(7911), ChrW(361), ChrW(7909), ChrW(432), ChrW(253),ChrW(7923), ChrW(7927), ChrW(7929), ChrW(7925)"
Const ResText = "aaaaaaaaaaaaaaaaadeeeeeeeeeeeiiiiiooooooooooooooooouuuuuuuuuuuyyyyy"
Function TV(ByVal Text As String) As String
Dim Uni(), i As Long, tmp As String
tmp = Text
Uni = Split(CharCode, ",")
For i = 0 To UBound(Uni)
tmp = Replace(tmp, Uni(i), UCase(Mid(ResText, i + 1, 1)))
TV = tmp
Sub Loc()
Dim Tm, Tm1(), i, j
Tm = Sheet4.Range("A4:A" & Sheet4.[A65536].End(3).Row)
For i = 1 To UBound(Tm, 1)
If Tm(i, 1) <> "" Then
If TV(Tm(i, 1)) Like TV("*" & ActiveSheet.TextBox1.Value & "*") Then
j = j + 1
ReDim Preserve Tm1(1 To j)
Tm1(j) = Tm(i, 1)
If Sheet4.ListBox2.ListCount > 0 Then Sheet4.ListBox2.Clear
Sheet4.ListBox2.List() = Tm1
dạ đúng là có chạy nhanh hơn rồi ah, nhưng cho e hỏi muốn chạy hơn có được không ạ,Code của bạn nặng vì Hàm TV là chính, bạn sửa lại như sau sẽ nhanh hơn:
Mã:Option Explicit Const CharCode = "ChrW(7855), ChrW(7857), ChrW(7859), ChrW(7861), ChrW(7863), ChrW(7845), ChrW(7847),ChrW(7849), ChrW(7851), ChrW(7853), ChrW(225), ChrW(224), ChrW(7843), ChrW(227), ChrW(7841),ChrW(259), ChrW(226), ChrW(273), ChrW(7871), ChrW(7873), ChrW(7875), ChrW(7877), ChrW(7879),ChrW(233), ChrW(232), ChrW(7867), ChrW(7869), ChrW(7865), ChrW(234), ChrW(237), ChrW(236),ChrW(7881), ChrW(297), ChrW(7883), ChrW(7889), ChrW(7891), ChrW(7893), ChrW(7895), ChrW(7897),ChrW(7899), ChrW(7901), ChrW(7903), ChrW(7905), ChrW(7907), ChrW(243), ChrW(242), ChrW(7887),ChrW(245), ChrW(7885), ChrW(244), ChrW(417), ChrW(7913), ChrW(7915), ChrW(7917), ChrW(7919),ChrW(7921), ChrW(250), ChrW(249), ChrW(7911), ChrW(361), ChrW(7909), ChrW(432), ChrW(253),ChrW(7923), ChrW(7927), ChrW(7929), ChrW(7925)" Const ResText = "aaaaaaaaaaaaaaaaadeeeeeeeeeeeiiiiiooooooooooooooooouuuuuuuuuuuyyyyy" Function TV(ByVal Text As String) As String Dim Uni(), i As Long, tmp As String On Error Resume Next tmp = Text Uni = Split(CharCode, ",") For i = 0 To UBound(Uni) tmp = Replace(tmp, Uni(i), UCase(Mid(ResText, i + 1, 1))) Next TV = tmp End Function
Code Loc() như sau sẽ lọc trên mảng và nạp 1 lần bằng phương thức List() cũng cải thiện về tốc độ:
Mã:Sub Loc() Dim Tm, Tm1(), i, j Tm = Sheet4.Range("A4:A" & Sheet4.[A65536].End(3).Row) For i = 1 To UBound(Tm, 1) If Tm(i, 1) <> "" Then If TV(Tm(i, 1)) Like TV("*" & ActiveSheet.TextBox1.Value & "*") Then j = j + 1 ReDim Preserve Tm1(1 To j) Tm1(j) = Tm(i, 1) End If End If Next If Sheet4.ListBox2.ListCount > 0 Then Sheet4.ListBox2.Clear Sheet4.ListBox2.List() = Tm1 End Sub
If Tm(i, 1) Like "*" & ActiveSheet.TextBox1.Value & "*" Then
j = j + 1
Tm1(j) = Tm(i, 1)
if j>0 then Sheet4.ListBox2.List() = Tm1
Đúng là nhanh hơn rất nhiều, thanks anh,Mình chả thấy cái Textbox của bạn ở đâu cả nên đoán thuốc thôi:
1/ Vùng DS tạo List là vùng mã, vậy nên chả cần Tiếng Việt làm chi. Bạn sửa như sau sẽ rất nhanh. Thay dòng:
bằng dòng:
2/Code Loc() nên sửa lại như sau:
Mã:Sub Loc() Dim Tm, Tm1(), i, j If Sheet4.ListBox2.ListCount > 0 Then Sheet4.ListBox2.Clear Tm = Sheet4.Range("A4:A" & Sheet4.[A65536].End(3).Row) For i = 1 To UBound(Tm, 1) If Tm(i, 1) <> "" Then If Tm(i, 1) Like "*" & ActiveSheet.TextBox1.Value & "*" Then j = j + 1 ReDim Preserve Tm1(1 To j) Tm1(j) = Tm(i, 1) End If End If Next if j>0 then Sheet4.ListBox2.List() = Tm1 End Sub
