Đây là cávh làm List of Content cho mỗi CD ,hoặc folders trong Hard drive . Vi dụ có Folder về các bài VBA, hay folder các bản nhac, folder về các Patch Securty Update etc....Trò chơi sắp xếp ngăn nắp
. Mỗi lần tìm dễ hơn
Có 2 cách để List ra, chỉ là Text hay muốn dùng Hyperlink để run file trực tiếp
Sub ListAllFile()
Dim objFSO As Object
Dim objFolder As Object
Dim objFile As Object
Dim ws As Worksheet
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set ws = Worksheets.Add
'Get the folder object associated with the directory
Set objFolder = objFSO.GetFolder("G:\Window Updated\WindowsXP\")
ws.Cells(1, 2).Value = "NAME " & objFolder.Name
ws.Cells(1, 3).Value = "SIZE " & objFolder.Name
'Loop through the Files collection
For Each objFile In objFolder.Files
ws.Cells(ws.UsedRange.Rows.Count + 1, 2).Value = objFile.Name
ws.Cells(ws.UsedRange.Rows.Count, 3).Value = objFile.Size
'Clean up!
Set objFolder = Nothing
Set objFile = Nothing
Set objFSO = Nothing
[/COĐE]
Dùng Hyperlink
[COĐE]
Sub HyperlinksToDirectory()
' starting at the active cell
Dim stDir As String
Dim stFile As String
Dim R As Range
Set R = ActiveCell
stDir = "G:\Window Updated\WindowsXP\"
stFile = Dir(stDir & "\*.*")
Do Until stFile = ""
R.Hyperlinks.Add R, stDir & "\" & stFile, , , stFile
Set R = R.Offset(1)
stFile = Dir()
Loop
R.CurrentRegion.Sort key1:=R, order1:=xlAscending, header:=xlNo
[/COĐE]
