Giải đáp giùm em, cách khắc phục lỗi này trên VBA (1 người xem)
  • Thread starter Thread starter Huy@@*
Huy@@*
Dim rngCho As Range, rngNhan As Range, rngData As Range, rngDMTK As Range
Dim endR&, eRow&, eR&, iR&, iRow&, soDong&
Dim i&, j&, k&, m&, s&, t&, u&, n&
Dim DemNo&, DemCo&, Dem&, dongDau&, iCT&
Public sSoCT As String
Dim wf As WorksheetFunction, Dic As Object
Const ColTkNo = 8: Const ColTkCo = 9: Const RowEnd = 1000000
Dim Arr(), ArrNo(), ArrCo(), ArrTK(), arrCho(), arrNhan(), ArrSap(), ArrDM(), ArrSoCT()
Dim Tg
Dim ArrKQ(1 To 100, 1 To 16)
Sub TaoRng()
Set wf = WorksheetFunction
iRow = 2 'dong dau NKC
With Sheets("NKC")
.Range("A" & iRow & ":P" & RowEnd).ClearContents
With Sheets("Tmp")
endR = .Range("A" & RowEnd).End(xlUp).Row
ArrTK = .Range(.Cells(2, 14), .Cells(u, 16)).Value
dongDau = 0
eRow = UBound(ArrTK)
For iCT = 1 To eRow
sSoCT = ArrTK(iCT, 1) 'so CT
Dem = ArrTK(iCT, 2) + ArrTK(iCT, 3) 'so lan N + C
If Dem = 0 Then GoTo exit_for
''Day la phan tinh toan cac TH, co ban la xac dinh cac vung RngCho va RngNhan'
DemNo = ArrTK(iCT, 2) 'so lan N'
DemCo = ArrTK(iCT, 3) 'so lan C'
TaoSubRng
'Truong hop nay la toan No
If DemCo = 0 Then
TinhToan07
GoTo exit_for
''Truong hop nay la toan Co
If DemNo = 0 Then
TinhToan08
GoTo exit_for
''Truong hop khac - TH nay nhieu nhat
'Truong hop nay la soct vua co No vua co Co
Select Case Dem
Case 2
''luc nay DemNo=1 va demCo =1
TinhToan01
Case Is > 2 'so record > 2
''Them 1 TH neu so TK No = So TK Co, STien No(1)=sotienco(1), SotienNo(end)=sotienco(end)
If Dem < 5 And DemNo = DemCo Then
If rngNhan(1, 9) = rngCho(1, 8) And rngNhan(DemCo, 9) = rngCho(DemNo, 8) Then
TinhToan04
GoTo exit_for
If DemNo = 1 Then 'quan he 1N nhieu C
TinhToan02
GoTo exit_for
If DemCo = 1 Then 'quan he 1C nhieu N
TinhToan03
GoTo exit_for
''quan he nhieu no nhieu co
If wf.CountIf(rngCho.Offset(, 7).Resize(, 1), "<0") = DemNo Then
''Truong hop nay la so tien No toan am
TinhToan06
GoTo exit_for
TinhToan05
GoTo exit_for
End Select
exit_for:
dongDau = dongDau + Dem
If dongDau >= endR Then Exit Sub
Next iCT
Erase ArrTK, arrCho(), arrNhan(), ArrKQ
Set rngCho = Nothing: Set rngNhan = Nothing
Sub TaoNKC()
With Application
.ScreenUpdating = False: .DisplayAlerts = False: .Calculation = xlCalculationManual: .EnableEvents = False
Tg = Timer
Sheets("NKC").Select
Sheets("NKC").AutoFilterMode = False
'Co the them 1 UDF kiem tra sh Tmp da ton tai
If SheetExists("Tmp") Then
With Sheets("Tmp")
.Cells.ClearContents
.[B1] = "SoCT" 'them tieu de
.[N1] = "SoCT": .[O1] = "DemNo": .[P1] = "DemCo": .[Q1] = "NgayHT"
'Neu chua co thi add
Sheets.Add
ActiveSheet.Name = "Tmp"
ConvertGoc2Tmp
TaoTmp
TaoRng
'GanTKVN
XuLySoCT
Sheets("Tmp").Delete
MsgBox "OK" & Chr(13) & Timer - Tg
With Application
.ScreenUpdating = True: .DisplayAlerts = True: .Calculation = xlCalculationAutomatic: .EnableEvents = True
Sub TaoSubRng()
With Sheets("Tmp")
If DemNo = 0 Then
Set rngNhan = .Cells(2 + dongDau, 2).Offset(DemNo, -1).Resize(DemCo, 13)
GoTo bien
If DemCo = 0 Then
Set rngCho = .Cells(2 + dongDau, 2).Offset(, -1).Resize(DemNo, 12)
GoTo bien
bien:
'rngCho.Select
'rngNhan.Select
arrCho = rngCho.Value: arrNhan = rngNhan.Value
Sub XuLySoCT()
Dim endR&, i&
Dim Arr(), ArrSoTT()
Dim SearchChar$, myPos&
SearchChar = ";"
With Sheets("NKC")
endR = .Cells(RowEnd, 1).End(3).Row
Arr = .Range("B2:B" & endR).Value
ReDim ArrSoTT(1 To UBound(Arr), 1 To 1)
For i = 1 To UBound(Arr)
myPos = InStr(Arr(i, 1), SearchChar)
Arr(i, 1) = Right(Arr(i, 1), Len(Arr(i, 1)) - myPos)
ArrSoTT(i, 1) = i
With Sheets("NKC")
.Range("B2:B" & endR).Value = Arr
.Range("F2:F" & endR).Value = ArrSoTT
Erase Arr, ArrSoTT
Sub GanArr()
With Sheets("NKC")
.Cells(iRow, 1).Resize(soDong, 9) = ArrKQ
iRow = iRow + soDong
Erase ArrKQ
Sub TaoTmp()
With Sheets("Tmp")
endR = .Cells(RowEnd, 2).End(xlUp).Row
Arr = .Range("A2:M" & endR + 1).Value 'them +1'
endR = UBound(Arr)
ReDim ArrNo(1 To endR, 1 To 13), ArrCo(1 To endR, 1 To 13), ArrTK(1 To endR, 1 To 4)
s = 0: t = 0: u = 1
For i = 1 To endR - 1
'Gan phan no
If Arr(i, 8) <> 0 Then 'sotien no <>0
s = s + 1
For k = 1 To 4
ArrNo(s, k) = Arr(i, k)
Next k
If Arr(i, 12) <> 0 Then
For k = 10 To 11
Next k
ArrNo(s, 12) = Arr(i, 12)
ArrNo(s, 6) = Arr(i, 12) / Arr(i, 8)
ArrNo(s, 5) = "N"
ArrNo(s, 7) = CStr(Arr(i, 7)) ' & Arr(i, 5)) SHTK & CostStr
ArrNo(s, 8) = Arr(i, 8) 'so tien
ArrTK(u, 2) = ArrTK(u, 2) + 1 ' dem so N
'Gan phan co
If Arr(i, 9) <> 0 Then 'sotien co <>0
t = t + 1
For k = 1 To 4
ArrCo(t, k) = Arr(i, k)
Next k
If Arr(i, 13) <> 0 Then
For k = 10 To 11
Next k
ArrCo(t, 13) = Arr(i, 13)
ArrCo(t, 6) = Arr(i, 13) / Arr(i, 9)
ArrCo(t, 5) = "C"
ArrCo(t, 7) = CStr(Arr(i, 7)) '& Arr(i, 5)) 'SHTK & CostStr
ArrCo(t, 9) = Arr(i, 9) 'so tien
ArrTK(u, 3) = ArrTK(u, 3) + 1 ' dem so N
'tao DM TK duy nhat voi dieu kien la soct da sort******
ArrTK(u, 1) = Arr(i, 2) 'soct
ArrTK(u, 4) = Arr(i, 1) 'NgayHT
If ArrTK(u, 1) <> Arr(i + 1, 2) Then u = u + 1
'co nen gan bien dem vao
With Sheets("tmp")
.[B1] = "SoCT"
.Range("A2:M" & RowEnd).ClearContents
.Range("N2:Q" & RowEnd).ClearContents
.Range("A2").Resize(s, 13) = ArrNo
.Range("A2").Offset(s, 0).Resize(t, 13) = ArrCo
.Range("N2").Resize(u, 4) = ArrTK
Erase Arr(), ArrNo(), ArrCo(), ArrTK
With Sheets("Tmp")
endR = s + t + 1
'sort tmp
Set rngData = .Range(.Cells(1, 1), .Cells(endR, 13))
With .Sort
With .SortFields
.Clear
.Add Key:=Range("A1"), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 1 ngayCT
.Add Key:=Range("B1"), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 2 soct
.Add Key:=Range("H1"), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 4 Tien No
.Add Key:=Range("I1"), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 5 Tien co
.SetRange rngData
.Header = xlYes ' co tieu de hay khong'
.Apply
'sort soct duy nhat
Set rngData = .Range("N2:Q" & u)
With .Sort
With .SortFields
.Clear
.Add Key:=rngData.Cells(1, 4), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 1 ngayHT
.Add Key:=rngData.Cells(1, 1), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 2 soct
.SetRange rngData
.Header = xlNo ' co tieu de hay khong'
.Apply
Set rngData = Nothing
Sub ConvertGoc2Tmp()
Dim ArrKQ()
With Sheets("NKCGoc")
Arr = .Range("A3:I" & endR).Value
ReDim ArrKQ(1 To UBound(Arr), 1 To 9)
s = 0
If Len(Arr(i, 7)) > 0 Then
s = s + 1
ArrKQ(s, 1) = Arr(i, 1)
ArrKQ(s, 2) = Arr(i, 1) & ";" & Arr(i, 2)
ArrKQ(s, 3) = Arr(i, 3)
ArrKQ(s, 7) = CStr(Arr(i, 7))
ArrKQ(s, 4) = Arr(i, 4)
ArrKQ(s, 5) = Arr(i, 5)
ArrKQ(s, 6) = Arr(i, 6)
ArrKQ(s, 8) = Arr(i, 8) * 1
ArrKQ(s, 9) = Arr(i, 9) * 1
With Sheets("Tmp")
.[A2].Resize(RowEnd, 9).ClearContents
.[A2].Resize(s, 9) = ArrKQ
Set rngData = .Range("A2:I" & s + 1)
With .Sort
With .SortFields
.Clear
.Add Key:=rngData.Cells(1, 1), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 1 ngayHT
.Add Key:=rngData.Cells(1, 2), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 2 soct
.Add Key:=rngData.Cells(1, 3), SortOn:=xlSortOnValues, Order:=xlAscending 'Dieu kien 2 ngayCT
.SetRange rngData
.Apply
Erase Arr(), ArrKQ()
Private Function SheetExists(ShName) As Boolean
Dim x As Object
Set x = ActiveWorkbook.Sheets(ShName)
If Err = 0 Then SheetExists = True _
Else SheetExists = False
Sub TinhToan01()
'Truong hop nay danh cho 1N va 1C - Dem=2
soDong = 1
ArrKQ(soDong, 1) = arrNhan(1, 1) 'ngay HT
ArrKQ(soDong, 2) = sSoCT 'SoCT
ArrKQ(soDong, 3) = arrNhan(1, 3) 'NgayCT
ArrKQ(soDong, 4) = arrNhan(1, 4) 'diengiai
ArrKQ(soDong, ColTkNo) = arrCho(1, 7) 'TKNo
ArrKQ(soDong, ColTkCo) = arrNhan(1, 7) 'TKCo;
ArrKQ(soDong, 7) = arrNhan(1, 9) 'sotien
If arrNhan(1, 6) > 0 Then
ArrKQ(soDong, 14) = arrNhan(1, 10) 'MaKH
ArrKQ(soDong, 15) = arrNhan(1, 11) 'TenKH
ArrKQ(soDong, 16) = Round(arrNhan(1, 6) * ArrKQ(soDong, 7), 0) 'ST VND
GanArr
Sub TinhToan05()
Dim curCho&, curNhan&
Dim curSLCho As Double, curSLNhan As Double
Dim curSLChoDu As Double, curSLNhanThieu As Double, SLChia As Double
curCho = 0: curNhan = 0: s = 1
curSLNhanThieu = 0: curSLChoDu = 0: SLChia = 0
'Phan nay la nhieu no nhieu co
Do While Not (curCho = UBound(arrCho) And curSLChoDu = 0)
If curSLChoDu = 0 Then
curCho = curCho + 1
curSLCho = arrCho(curCho, 8)
curSLChoDu = curSLCho
If curSLNhanThieu = 0 Then
curNhan = curNhan + 1
curSLNhan = arrNhan(curNhan, 9)
curSLNhanThieu = curSLNhan
If curSLChoDu <= curSLNhanThieu Then
SLChia = curSLChoDu
SLChia = curSLNhanThieu
ArrKQ(s, 1) = arrCho(curCho, 1) 'Ngay HT
ArrKQ(s, 2) = sSoCT 'SoCT
ArrKQ(s, 3) = arrCho(curCho, 3) 'NgayCT
ArrKQ(s, 4) = arrCho(curCho, 4) 'Dien giai
ArrKQ(s, ColTkNo) = arrCho(curCho, 7) ' TK No
ArrKQ(s, ColTkCo) = arrNhan(curNhan, 7) ' TK Co
ArrKQ(s, 7) = SLChia 'So tien
If arrCho(curCho, 6) > 0 Then
ArrKQ(s, 14) = arrCho(curCho, 10) 'MaKH
ArrKQ(s, 15) = arrCho(curCho, 11) 'TenKH
ArrKQ(s, 16) = Round(arrCho(curCho, 6) * ArrKQ(s, 7), 0) 'ST VND
curSLChoDu = curSLChoDu - SLChia
curSLNhanThieu = curSLNhanThieu - SLChia
s = s + 1
Loop
soDong = s - 1
GanArr
'Phan code duoi day it khi dung
Sub TinhToan06()
'With Sheets("NKC")
'Phan nay la nhieu no nhieu co vµ tat ca la so <0
curCho = curCho + 1
If curSLChoDu >= curSLNhanThieu Then 'lay so < lon hon
SLChia = curSLChoDu
If arrCho(curCho, 6) > 0 Then 'Ti gia
ArrKQ(s, 16) = Round(ArrKQ(s, 7) * arrCho(curCho, 6), 0) 'VND
s = s + 1
Loop
soDong = s - 1
GanArr
Sub TinhToan02()
'Truong hop nay danh cho 1N va many C - Dem>2
soDong = UBound(arrNhan)
n = 1 '1 No
For i = 1 To soDong
For k = 1 To 4
ArrKQ(i, k) = arrNhan(i, k) '4 cot dau
Next k
For k = 14 To 16
ArrKQ(i, k) = arrNhan(i, k - 4) '3 cot sau
Next k
ArrKQ(i, ColTkNo) = arrCho(n, 7) 'TKNo
ArrKQ(i, ColTkCo) = arrNhan(i, 7) 'TKCo
ArrKQ(i, 7) = arrNhan(i, 9) 'So tien
If arrNhan(i, 6) > 0 Then
ArrKQ(i, 14) = arrNhan(i, 10) 'MaKH
ArrKQ(i, 15) = arrNhan(i, 11) 'TenKH
ArrKQ(i, 16) = Round(arrNhan(i, 6) * ArrKQ(i, 7), 0) 'ST VND
GanArr
Sub TinhToan03()
'Truong hop nay danh cho 1C va many N - Dem>2
'TH nay nguoc voi TinhToan02 - be care Tuan
soDong = UBound(arrCho)
n = 1 '1 No
For i = 1 To soDong
For k = 1 To 4
ArrKQ(i, k) = arrCho(i, k) '4 cot dau
Next k
ArrKQ(i, ColTkNo) = arrCho(i, 7) 'TKNo
ArrKQ(i, ColTkCo) = arrNhan(n, 7) 'TKCo
ArrKQ(i, 7) = arrCho(i, 8) 'So tien
If arrCho(i, 6) > 0 Then
ArrKQ(i, 14) = arrCho(i, 10) 'MaKH
ArrKQ(i, 15) = arrCho(i, 11) 'TenKH
ArrKQ(i, 16) = Round(arrCho(i, 6) * ArrKQ(i, 7), 0) 'ST VND
GanArr
Sub TinhToan04()
' TH neu so TK No = So TK Co, STien No(1)=sotienco(1), SotienNo(end)=sotienco(end)
'MsgBox "OK"
For i = 1 To soDong
For k = 1 To 4
Next k
GanArr
Sub TinhToan07()
' TH neu co nhieu TK No va khong co TK Co
For i = 1 To soDong
For k = 1 To 4
Next k
For k = 10 To 3
ArrKQ(i, k) = arrCho(i, k) '4 cot sau
Next k
ArrKQ(i, ColTkCo) = "" 'TKCo
GanArr
Sub TinhToan08()
' TH neu co nhieu TK Co va khong co TK No
n = 1 '1 No
For i = 1 To soDong
For k = 1 To 4
Next k
For k = 10 To 13
ArrKQ(i, k) = arrNhan(i, k) '4 cot sau
Next k
ArrKQ(i, ColTkNo) = "" 'arrCho(n, 7) 'TKNo
GanArr
Code là như vậy, giới hạn dòng của e là 1 triệu dòng
@Thớt: Em gửi file lên nhé. Hoặc chí ít úp hình lúc báo lỗi.
1 0 4 8 5 7 6
tại là e chỉ chỉnh nội dung khoảng mức thấp hơn 1 triệu dòng ạ.
Mình đọc và vẫn không hiểu bạn đang muốn gì :D
Bạn cụ thể hơn chút là cái gì đang 1 triệu dòng, và bạn muốn chỉnh là gì ? Bạn rõ ràng vấn đề thì mới giúp được.
Dạ là em muốn tách sổ Nhật ký chung từ 1 file khác có tổng dữ liệu dòng xấp xỉ gần 1 triệu dòng ra thành Tài khoản Nợ và Tài khoản Có và 1 cột phát sinh số tiền ra riêng ấy ạ
Hì, vậy để bạn khác giúp, do không có chuyên môn chỗ này nên không thể hiểu được bạn đang cần gì.
Bạn đưa một đống dòng lệnh lên và ghi "giới hạn dòng của e là 1 triệu dòng"; Mình chưa thấy mối liên hệ giữa việc tách sổ và một triệu dòng?
p/s: Mình bấm nút thì thấy vẫn chạy bình thường.
Chạy code với dữ liệu ít thì không thấy lỗi.
Khi lỗi (dòng tô vàng hình bài 1), trong tình trạng pause, kiểm tra s bằng bao nhiêu.
Nếu vậy thì sẽ fix lại như thế nào để hợp lý ạ
Tôi không biết "vậy" là thế nào. Đáng lẽ bạn phải nói nếu s = 0 thì làm thế nào, nếu curCho bằng 0 thì thế nào
Hoặc s= 1 tỷ thì làm thế nào, ...
Với cách hỏi của chủ nhân bài này thì không biết bao nhiêu bài nữa mới về đích đây. Thậm chí có thể sẽ không về đến đich đã dừng.
Dạ anh có gì xem dùm em nên sửa thế nào ạ
Bạn hỏi "nếu vậy", mà tôi không biết "vậy" là cái gì. Nếu bạn làm theo bài 10, thì bạn biết s bằng bao nhiêu, curCho bằng bao nhiêu, bạn mà cho tôi biết 2 giá trị đó thì tôi đội ơn bạn, bạn có công đức vô lượng. Căn cứ vào 2 giá trị đó tôi mới có thể gợi ý cách sửa, mà cũng có thể tôi bó tay. Còn cứ "nếu vậy" thì tôi bó tay ngay lập tức.
Dạ hiện tại em đang muốn tách dữ liệu của sổ sách nhiều nợ nhiều có thành Cột Nợ , cột Có, phát sinh. Nhưng mà khi làm xong thì thấy có nhiều trường bị sai, nên không biết là các cao nhân nào hỗ trợ giúp em fix lại code VBA trong file này với ạ :(((. Em cảm ơn rất nhiều ạ
Bạn này kiếm đâu ra được file từ cách đây gần 10 năm rồi, kiểu này chắc copy ở đâu về rồi đem lên hỏi chứ không phải file đang làm.
Thêm chủ đề mới, mà em đọc cũng chưa biết bạn này muốn gì.
Trình bày cái mình muốn mà sao thấy khó khăn quá.
Không biết trong công việc thì giao tiếp kiểu gì.
Nói bạn đừng tự ái, chứ bạn mất khoảng 4-5 post trao đổi, trong này có 5 người mà vẫn không thể hiểu bạn đang muốn gì, thì bạn cần phải xem lại.
Bạn trình bày trên diễn đàn, suy rộng ra là công việc của bạn nữa, nó phải có đầu có cuối. Như là em có (chụp hình hoặc note trực tiếp trong file excel), dữ liệu nguồn là A em chạy code (do em lập hoặc do em lượm). Chạy ít nó ngon lành hay vướng, vướng là gì ? Chạy nhiều thì bị gì ? Em mong muốn tách nhiều file, triệu dòng thì nó ở đâu ?
Kết quả em mong muốn ra sao. Nếu tốt về trình bày thì trình bày hình ảnh, nếu không thì diễn giải ghi chú, lời nói.
Dạ em gửi file lên ạ, nhờ các cao nhân giúp e fix lại với ạ, tại là e chỉ chỉnh nội dung khoảng mức thấp hơn 1 triệu dòng ạ.
Nhật ký chung của bạn thuộc loại đơn giản, không phức tạp. Gửi bạn File mình đã chia sẽ trong 1 bài trước. File này đã gắn data của bạn và đã chạy chuyển đổi !
Dạ anh đợi em chút xíu, để e trình bày lại ạ :(((, em xin lỗi mọi người
1. Dạ tình hình là các mã Code này là e vô tình cóp nhặt trên mạng về và làm, file số liệu thì chạy vẫn ra nhưng khi kiểm tra lại thì có các trường hợp như "1 Nợ nhiều Có", "Nhiều Có 1 Nợ", "Nhiều Nợ Nhiều Có" thì bị sai. ==> Đó là các vấn đề mà e gặp phải ạ.
2. Mục đích của em là tách dữ liệu từ phần mềm kế toán ERP ==> Các Cột "Tài khoản nợ", "Tài khoản có", "Số tiền phát sinh" => Để dễ dàng xử lý trong việc soát xét sổ sách ạ.
3. Chỗ vướng của em là không biết tách như thế nào các trường hợp nhiều nợ, nhiều có, 1 nợ, 1 có ạ?
4. Nhờ các anh xem trên file của em gửi, giúp em xem bị sai sót ở đâu ạ.
Em xin cảm ơn ạ.
Dạ e gửi thêm file e em có mẫu dữ liệu a ạ, "NKC" là sheet ra kết quả cuối cùng, "NKCGoc" là sheet NKC ban đầu chưa xử lý.
Em xin cảm ơn ạ.
Trường hợp nhiều nợ nhiều có bạn có tách thủ công bằng tay được không vậy? Hay là bạn bảo nó lúc nào cũng phải có 1 cặp nợ có tương ứng cùng số tiền để tách? Trong phần mềm ERP không có hạch toán theo nhóm đối ứng hay sao bạn? Đối chiếu soát xét sổ sách thì dữ liệu gốc của bạn có lẽ có thể làm được hết rồi, vấn đề là ở tư duy logic mà thôi. (trong nhiều phần mềm có thể kết xuất được dạng cột TK nợ, cột TK có, cột tiền, nhưng muốn được như thế thì lúc hạch toán phải khai báo thêm nhiều điều kiện nữa: nhóm hạch toán, hóa đơn thuế,... hay là có giao diện khác có thể kết xuất ra mà bạn chưa biết^^)
File Tổng phát sinh Nợ (1.356.528.762.681)<> Tổng phát sinh Có (1.356.529.262.681) => Xem lại
Em xin cảm ơn ạ.
Này thuần chuyên môn về kế toán tài chính, ngoài khả năng của mình nên không xử lý được. Chắc nhờ các anh em khác.
Tôi gộp 2 chủ đề lại.
