Chuyển ảnh từ File Excel lên Form (2 người xem)
thang_nguyen1
Chào các bạn. Cho mình hỏi có thể dùng VBA chuyển hỉnh ảnh từ File Excel lên form được không? Mong các bạn giúp mình với. Mình xin cảm ơn!
Chèn đoạn code này vào Module.
Private Type GUID
  Data1 As Long
  Data2 As Integer
  Data3 As Integer
  Data4(0 To 7) As Byte
End Type
#If VBA7 Then
  Private Type uPicDesc
    Size As Long
    Type As Long
    hPic As LongPtr
    hPal As LongPtr
  End Type
  Private Declare PtrSafe Function IsClipboardFormatAvailable Lib "user32" (ByVal wFormat As Integer) As Long
  Private Declare PtrSafe Function OpenClipboard Lib "user32" (ByVal hWnd As LongPtr) As Long
  Private Declare PtrSafe Function GetClipboardData Lib "user32" (ByVal wFormat As Integer) As LongPtr
  Private Declare PtrSafe Function CloseClipboard Lib "user32" () As Long
  Private Declare PtrSafe Function OleCreatePictureIndirect Lib "oleaut32" (PicDesc As uPicDesc, _
                     RefIID As GUID, ByVal fPictureOwnsHandle As Long, IPic As IPicture) As Long
  Private Declare PtrSafe Function CopyEnhMetaFile Lib "gdi32" Alias "CopyEnhMetaFileA" (ByVal hemfSrc As LongPtr, ByVal lpszFile As String) As LongPtr
  Private Declare PtrSafe Function CopyImage Lib "user32" (ByVal Handle As LongPtr, ByVal un1 As Long, ByVal n1 As Long, ByVal n2 As Long, ByVal un2 As Long) As LongPtr
#Else
    Size As Long
    Type As Long
    hPic As Long
    hPal As Long
  End Type
  Private Declare Function IsClipboardFormatAvailable Lib "user32" (ByVal wFormat As Integer) As Long
  Private Declare Function OpenClipboard Lib "user32" (ByVal hWnd As Long) As Long
  Private Declare Function GetClipboardData Lib "user32" (ByVal wFormat As Integer) As Long
  Private Declare Function CloseClipboard Lib "user32" () As Long
  Private Declare Function OleCreatePictureIndirect Lib "olepro32.dll" (PicDesc As uPicDesc, _
  Private Declare Function CopyEnhMetaFile Lib "gdi32" Alias "CopyEnhMetaFileA" (ByVal hemfSrc As Long, ByVal lpszFile As String) As Long
  Private Declare Function CopyImage Lib "user32" (ByVal Handle As Long, ByVal un1 As Long, ByVal n1 As Long, ByVal n2 As Long, ByVal un2 As Long) As Long
#End If
Function PictureFromObject(ByVal Target As Object, Optional ByVal bType As Boolean = True) As IPictureDisp
  #If VBA7 Then
    Dim hPtr As LongPtr, hCopy As LongPtr
  #Else
    Dim hPtr As Long, hCopy As Long
  #End If
  Dim PicType As Long
  Const CF_BITMAP = 2
  Const CF_PALETTE = 9
  Const CF_ENHMETAFILE = 14
  Const IMAGE_BITMAP = 0
  Const LR_COPYRETURNORG = &H4
  Const PicType_BITMAP = 1
  Const PicType_ENHMETAFILE = 4
  Target.CopyPicture , IIf(bType, xlBitmap, xlPicture)
  PicType = IIf(IsClipboardFormatAvailable(CF_BITMAP) <> 0, CF_BITMAP, CF_ENHMETAFILE)
  If IsClipboardFormatAvailable(PicType) <> 0 Then
    If OpenClipboard(0) > 0 Then
      hPtr = GetClipboardData(PicType)
      If PicType = CF_BITMAP Then
        hCopy = CopyImage(hPtr, IMAGE_BITMAP, 0, 0, LR_COPYRETURNORG)
        hCopy = CopyEnhMetaFile(hPtr, vbNullString)
      CloseClipboard
      If hPtr <> 0 Then
      Dim uPicInfo As uPicDesc, IID_IDispatch As GUID, IPic As IPictureDisp
        With IID_IDispatch
          .Data1 = &H7BF80980
          .Data2 = &HBF32
          .Data3 = &H101A
          .Data4(0) = &H8B
          .Data4(1) = &HBB
          .Data4(2) = &H0
          .Data4(3) = &HAA
          .Data4(4) = &H0
          .Data4(5) = &H30
          .Data4(6) = &HC
          .Data4(7) = &HAB
        With uPicInfo
          .Size = Len(uPicInfo)
          .Type = IIf(PicType = CF_BITMAP, PicType_BITMAP, PicType_ENHMETAFILE)
          .hPic = hCopy
        OleCreatePictureIndirect uPicInfo, IID_IDispatch, True, IPic
        Set PictureFromObject = IPic
Tiếp theo thêm đoạn code này vào UserForm.
Image1.Picture = PictureFromObject(Sheets("sheet1").Shapes("Picture 2"))
Việc còn lại là cho UserForm nó Show lên.
Private Type GUID
  Data1 As Long
  Data2 As Integer
  Data3 As Integer
End Type
#If VBA7 Then
    Size As Long
    Type As Long
    hPic As LongPtr
    hPal As LongPtr
  End Type
#Else
    Size As Long
    Type As Long
    hPic As Long
    hPal As Long
  End Type
#End If
  #If VBA7 Then
  #Else
  #End If
  Dim PicType As Long
  Const CF_BITMAP = 2
      CloseClipboard
      If hPtr <> 0 Then
        With IID_IDispatch
          .Data1 = &H7BF80980
          .Data2 = &HBF32
          .Data3 = &H101A
          .Data4(0) = &H8B
          .Data4(1) = &HBB
          .Data4(2) = &H0
          .Data4(3) = &HAA
          .Data4(4) = &H0
          .Data4(5) = &H30
          .Data4(6) = &HC
          .Data4(7) = &HAB
        With uPicInfo
          .hPic = hCopy
Cảm ơn bạn. Cho mình hỏi thêm nếu mà nhiều ảnh khác nhau thì có show được lên không ạ?
Mình hiện đã làm được cái này rồi. Mình muốn hỏi là khi mình bấm chuột vào ảnh nào thì ảnh trên form hiện theo ảnh mình bấm chuột không? Có giải pháp nào cho vấn đề này không?
Cho mình hỏi là có cách nào tên "Picture" trên Textbox nó nhảy luôn theo hình ảnh mà ko dùng combobox được không?
Ý bạn là xoá nó đi luôn như này ạ?
Ý mình là click vào "picture 1" hiện form. Rồi kích "picture 2" ở sheet thì form nó load theo hình "picture 2 " luôn. Nhưng điều này chắc hơi khó
là như này đúng không ạ?
Bạn có thể tham khảo việc thêm code sau ạ!
Sub ClickMe()
    Unload PicFrm
    PicFrm.Show False
Rất cảm ơn bạn. Mình muốn làm cái add-in thì có được không nhỉ. Vì đây đưa macro trực tiếp vào ảnh
Hoàn toàn làm được việc tạo Add-Ins, nhưng sẽ có nhiều vấn đề phức tạp phát sinh. Việc cơ bản là vẫn phải gắn Assign Macro cho Shape, việc này vẫn tự động được, nhưng khi mang file sang máy khác sẽ bị dính lỗi không có mang Add-ins theo, vã lại khi tự động thì sẽ gây khó khăn khi có nhu cầu thay đổi kích thước hình, di chuyển hình,... Còn nhiều thức phức tạp khác.
Em nghĩ là khi bạn ấy tạo add-in là muốn xem popup hình trên 1 file bình thường (.xlsx) bất kỳ. Khi bật add-in thì có thêm tính năng click vào hình để xem.
Ý tưởng là:
Trong add-in Chạy một đoạn mã tự động gán OnAction = "ClickMe" cho mọi ảnh trong ActiveSheet, trong đó thì ClickMe được lấy từ trong add-in ra. Có thể là OnAction = "'" & addInName & "'!" & macroName
Ý tưởng là:
Em vừa thử cách này thì không được nó báo như hình sau ạ!
Bạn viết sao thì tui không biết chứ tui viết chạy phát ngon cành đào. Còn vụ Add-Ins thì bạn nghĩ quá đơn giản, đụng thử vô đi sẽ thấy vấn đề phát sinh ngay, còn vấn đề gì thì bạn có thể thử suy nghĩ xâu hơn chút ví dụ đóng file mà không lưu, đóng file mà lưu, trên sheet có những shape trang trí, áp dụng cho file này còn file kia (đang mở) tính sao,... Thôi tui xin kết thúc vấn đề ở chủ đề này vì có lẽ cái mà chủ thớt cần đã được giải quyết, còn vụ Add-Ins là phát sinh không phù hợp với chủ đề này.
Dạ đúng ạ. Nếu mà làm add-in thì chỉ làm theo hướng show list image trên form và mình chọn hình theo list đó thôi ạ. Cảm ơn hai bạn đã nhiệt tình giúp đỡ mình.
Cho mình hỏi thêm làm sao để nó chạy trong được nhiều Sheet khác nhau. Như code trên thì chỉ chạy tđc trên "sheet 1"
Xin chào các bác,
Dựa trên đề tài này, em nhờ các bác giúp em phát triển thêm như bên dưới được không?
- Có một cột B bắt đầu từ B4:B1000 sẽ gồm những hyperlink đến địa chỉ hình ảnh (có thể là ảnh online hoặc offline).
- Khi mình click chuột vào ô nào thuộc B4:B1000 thì sẽ hiện ra ảnh lên form.
- Form hiển thị ảnh sẽ tự động thay đổi kích thước dựa theo ảnh gốc (tối đa là full screen).
Ý tưởng là:
Mình có giải pháp khác.
Nhúng ảnh lên userform rất dễ ( xem sản phẩm tôi đã nhúng anh của tôi vào hồ sơ xin việc...trong file Dich 6 ngôn ngữ)
Gán các nút nhấn vào Add in xong ....thì mở fie excel nào nó cũng đi theo...muốn dịch chữ nào nó dịch chữ đó...)
Bạn mở 3 file mình gửi nhé. Trong file có số ĐT zalo của mình đấy.
Ultraview lên mình trợ giúp bạn
Dạ bác, nay em mới quay lại với diễn đàn. Để em nghiên cứu có gì không hiểu mong được bác giúp đỡ ạ!
Private Type GUID
  Data1 As Long
  Data2 As Integer
  Data3 As Integer
End Type
#If VBA7 Then
    Size As Long
    Type As Long
    hPic As LongPtr
    hPal As LongPtr
  End Type
#Else
    Size As Long
    Type As Long
    hPic As Long
    hPal As Long
  End Type
#End If
  #If VBA7 Then
  #Else
  #End If
  Dim PicType As Long
  Const CF_BITMAP = 2
      CloseClipboard
      If hPtr <> 0 Then
        With IID_IDispatch
          .Data1 = &H7BF80980
          .Data2 = &HBF32
          .Data3 = &H101A
          .Data4(0) = &H8B
          .Data4(1) = &HBB
          .Data4(2) = &H0
          .Data4(3) = &HAA
          .Data4(4) = &H0
          .Data4(5) = &H30
          .Data4(6) = &HC
          .Data4(7) = &HAB
        With uPicInfo
          .hPic = hCopy
cái này có phải áp dụng win API phải không ạ? hay làm bằng cái gì thế anh vì em thấy nhiều cú pháp lạ quá, không thấy nhiều trong vba excel
