Code lấy dữ liệu từ 3 file con. (4 người xem)
LuuAnh980
Thành viên tiêu biểu
Nữ
Chào các anh trong GPE!!!!
Em có bắt chước code của anh @Hoàng Tuấn 868 làm cho em để lấy dữ liệu, nhưng không biết sai chổ nào mà báo lỗi ngay dòng này:
md(k, 11) = "VTF" & Mid(wn.Name, InStr(wn.Name, "WF") - 1, 1)
lỗi Subscript out of range ạ.
Code đây ạ:
Sub LayDuLieuSheetTonDau_TuCacFile()
Dim wd As Workbook, wn As Workbook
Dim sd As Worksheet, sn As Worksheet, sn1 As Worksheet, sn2 As Worksheet
Dim lrd As Long, lrn As Long, lrn1 As Long, lrn2 As Long
Dim i As Long, j As Long, k As Long, p As Long, q As Long
Dim md() As String, md1, md2, mn, mn1, mn2
Set wd = ThisWorkbook
Set sd = wd.Sheets("TonDau")
Set sn1 = wd.Sheets("DanhMuc")
lrn1 = sn1.Cells(Rows.Count, 2).End(xlUp).Row
mn1 = sn1.Range("B6:j" & lrn1)
ReDim md(1 To 2000, 1 To 11)
ReDim md1(1 To 2000, 1 To 6)
With Application.FileDialog(msoFileDialogOpen)
.AllowMultiSelect = True
.Show
If .SelectedItems.Count = 0 Then Exit Sub
    For i = 1 To .SelectedItems.Count
        Set wn = Workbooks.Open(.SelectedItems(i), False)
        Set sn = wn.Sheets("BaoCao")
        If sn.AutoFilterMode = True Then sn.AutoFilterMode = False
        lrn = sn.Cells(Rows.Count, 2).End(xlUp).Row
        mn = sn.Range("B8:E" & lrn)
        For j = 1 To UBound(mn, 1)
            If Trim(mn(j, 2)) <> "" And Left(mn(j, 2), 11) <> "Steel Plate" Or Trim(mn(j, 2)) <> "" And Left(mn(j, 2), 11) <> "Chequered" Then
                If InStr(mn(j, 2), "Steel Plate") = 0 Then
                    If InStr(mn(j, 2), "Chequered") = 0 Then
            On Error GoTo thoat
                    md(k, 4) = mn(j, 1)
                    md1(k, 1) = mn(j, 3)
thoat:
    wn.Close False
    If k > 0 Then
        For p = 1 To UBound(mn1, 1)
            For q = 1 To k
                If mn1(p, 2) = md(q, 4) Then
                    md(q, 5) = mn1(p, 8)
                    md1(q, 9) = mn1(p, 7)
            Next q
        Next p
        sd.Range("A3:M10000").Clear
        sd.Range("A3").Resize(k, 11) = md
        sd.Range("J3").Resize(k - 1, 1) = md1
        lrd = sd.Cells(Rows.Count, 8).End(xlUp).Row
        sd.Range("A3:M" & lrd).Borders.LineStyle = True
        For i = 6 To lrd - 1
        If sd.Cells(i, 1) = "" Then
            sd.Range("A" & i).Resize(1, 11) = ""
            sd.Range("A" & i).Resize(1, 11).Interior.ColorIndex = 37
Bạn từng đăng bài rất nhiều. Cái tối thiểu là đính kèm file để có thể test giúp bạn xem nó như nào thì lại không làm. Việc trên nó như kiểu đem ảnh đi khám bệnh ấy. Xin lỗi vì nếu nói làm bạn thấy tự ái.
  • Thích
Reactions: th7
Sao câu hỏi của bạn với bạn này giống nhau không?
Đúng ạ, code này là em chế lại của anh @Hoàng Tuấn 868 làm cho em, em có nhờ ảnh giúp, nhưng ảnh nói ảnh bận công tác chưa giúp được, hôm nay em nôn quá đưa lên đây nhờ anh nào coi thử giúp em ạ.
Bạn không bẫy lỗi thì chỗ này sẽ trả về 0 khi WF nằm ở ngay vị trí đầu tiên hoặc -1 nếu kg tìm thấy, thì hàm MID báo sai thôi.
Tôi thấy chỗ sai nhưng không hiểu bài nên không biết sửa. Chỗ này ReDim md(1 To 2000, 1 To 11) nhưng biến k chỗ này md(k, 11) = "VTF" & Mid(wn.Name, InStr(wn.Name, "WF") - 1, 1) nó bằng 0 nên lỗi.
Tôi nhớ không lầm thì bài này có điều kiện là dòng nào của cột Item của các sh BaoCao/ file nguồn không có "Steel Plate" hoặc "Chequered" thì mới lấy. do vậy 1 dòng không đồng thời có cả Steel plate và Chequered được. Vậy nên
Thử thay chỗ này
thành
 If InStr(mn(j, 2), "Steel Plate") = 0 Or InStr(mn(j, 2), "Chequered") = 0 Then
và xóa đi 1 end if xem sao.
Chỗ này
và chỗ này
nó có phù hợp với nhau không?
Cám ơn các anh đã quan tâm, mong các anh giúp đỡ.
Định thử nhưng thấy UnProtect sheet, thôi bỏ cuộc...
vgf là gì vậy bạn?
À, bây giờ lại lỗi ngay dòng này ạ :
    wn.Close False
