Sửa code Gộp File (10 người xem)
thang_nguyen1
Mình có một đoạn code về gộp File. Giờ mình muốn sửa sao cho khi gộp file chỉ lấy tiêu đề ở file thứ nhất thôi, từ file thứ hai sẽ bỏ qua tiều đề. Mong mọi người giúp đỡ mình, xin cảm ơn mọi người.
Sub MergeSheetInFolder()
    Dim objFs As Object
    Dim objFolder As Object
    Dim File As Object
    Dim Wb As Workbook
    Dim ws As Worksheet
    Dim OpenWb As Workbook
    Dim OpenWs As Worksheet
    Dim xDir As String
    Dim Folder As Object
    Dim xRows As Long
    Dim xColumns As Long
    Dim xColumnsFirst As Long
    Dim WorkRng As Range
    Dim xTitleId As String
    Dim LastRowWb As Long
    Dim LastRowOpenWb As Long
    Set Wb = ActiveWorkbook
    Set ws = Wb.ActiveSheet
    xTitleId = "Vung merge"
    Set WorkRng = Application.Selection
    Set WorkRng = Application.InputBox("Xin chon vung (1 sheet trong file nay) de paste data", xTitleId, WorkRng.Address, Type:=8)
    LastRowWb = ws.Cells.Find("*", searchorder:=xlByRows, searchdirection:=xlPrevious).Row
    If LastRowWb = 0 Then
        LastRowWb = 1
        LastRowWb = LastRowWb + 1
    With Application
        .ScreenUpdating = False
        .Calculation = xlCalculationManual
        .DisplayStatusBar = False
        .DisplayAlerts = False
        .EnableEvents = False
    Set Folder = Application.FileDialog(msoFileDialogFolderPicker)
    If Folder.Show <> -1 Then
        With Application
            .ScreenUpdating = True
            .Calculation = xlCalculationAutomatic
            .DisplayStatusBar = True
            .DisplayAlerts = True
            .EnableEvents = True
        Exit Sub
    xDir = Folder.SelectedItems(1)
    Set objFs = CreateObject("Scripting.FileSystemObject")
    Set objFolder = objFs.GetFolder(xDir)
    For Each File In objFolder.Files
        Set OpenWb = Workbooks.Open(File.path, True, True)
        Set OpenWs = OpenWb.ActiveSheet
        LastRowOpenWb = OpenWs.Cells.Find("*", searchorder:=xlByRows, searchdirection:=xlPrevious).Row
        OpenWs.Rows("1:" & LastRowOpenWb).Copy
        Wb.Activate
        With ActiveSheet.Range("a" & LastRowWb)
            .PasteSpecial xlPasteAll
            .PasteSpecial xlPasteFormats
        LastRowWb = LastRowWb + LastRowOpenWb
        OpenWb.Close False
        Set OpenWb = Nothing
    With Application
        .CutCopyMode = False
    MsgBox "Done!"
Cũng nên tùy thời mà thay đổi. VBA với người mới thì học khó hơn, dễ lỗi hơn. Còn Power query mới học chỉ cần nhấn nút tác vụ.
Anh có thể quay video các bước thực hiện việc nối file này bằng Power Query được không?
Nghe anh nói em thấy mình lạc hậu quá.
Đây bạn ơi, giúp mình với.
Bạn thử lại được chưa nhe.
    Dim objFs As Object
    Dim File As Object
    Dim Wb As Workbook
    Dim ws As Worksheet
    Dim xDir As String
    Dim xRows As Long
    Dim i As Long
    On Error GoTo Errorhandler
        LastRowWb = 1
    With Application
        With Application
        Exit Sub
    i = 0
        If InStr(1, objFs.GetExtensionName(File), "csv", vbTextCompare) > 0 Then
'            Set OpenWb = Workbooks.Open(Filename:= _
'            File.Path, _
'            UpdateLinks:=0, IgnoreReadOnlyRecommended:=True, _
'            CorruptLoad:=XlCorruptLoad.xlExtractData)
            Set OpenWb = Workbooks.Open(Filename:=File.Path)
            If Err <> 0 Then
                LastRowOpenWb = 0
                OpenWb.Close False
                i = i + 1
                If i = 1 Then
                    OpenWs.Rows("2:" & LastRowOpenWb).Copy
                Wb.Activate
                With ActiveSheet.Range("A" & LastRowWb)
                If i > 1 Then
                    LastRowWb = LastRowWb + LastRowOpenWb - 1
                OpenWb.Close False
            On Error GoTo 0
    With Application
    MsgBox "Done!"
    Exit Sub
Errorhandler:
    With Application
    MsgBox "Co loi xay ra, vui long kiem tra lai!"
    Exit Sub
Sửa code, giữ nguyên thuật toán và tên biến:
- Dẹp hết resume next
- Xóa bớt lệnh, khai báo không cần thiết
- Xóa bớt khối lệnh thừa
- Sửa 1 số câu lệnh
- Chặn trước 1 số lỗi
Gọn gàng hơn rất nhiều, mặc dù không tối ưu.
    Dim objFs As Object, objFolder As Object, File As Object, Folder As Object
    Dim Wb As Workbook, ws As Worksheet, OpenWb As Workbook, OpenWs As Worksheet
    Dim xDir As String, WorkRng As Range
    Dim LastRowWb As Long, LastRowOpenWb As Long, i As Long
    Set WorkRng = Application.InputBox("Xin chon vung de paste data", "Data", "A1", Type:=8)
        Exit Sub
     With Application
    i = 0
        If objFs.GetExtensionName(File) = "csv" Then
            LastRowOpenWb = OpenWs.Cells(10000, 1).End(xlUp).Row
            If LastRowOpenWb = 1 Then
                OpenWb.Close False
                i = i + 1
                If i = 1 Then
                    LastRowWb = WorkRng.Row
                    OpenWs.Rows("1:" & LastRowOpenWb).Copy ws.Cells(LastRowWb, 1)
                    LastRowWb = ws.Cells(10000, 1).End(xlUp).Row + 1
                    OpenWs.Rows("2:" & LastRowOpenWb).Copy ws.Cells(LastRowWb, 1)
                OpenWb.Close False
    MsgBox "Done!"
Errorhandler:
    With Application
- Sửa 1 số câu lệnh
        Exit Sub
     With Application
    i = 0
                OpenWb.Close False
                i = i + 1
                If i = 1 Then
                OpenWb.Close False
    MsgBox "Done!"
Errorhandler:
    With Application
Dữ liệu cột 1 full thì được nhưng nếu bị thiếu từ dòng cuối trở lên là thua luôn.
Ok để mai mình kiểm tra nhe.
OK cảm ơn bạn.
    Dim objFs As Object
    Dim File As Object
    Dim Wb As Workbook
    Dim ws As Worksheet
    Dim xDir As String
    Dim xRows As Long
    Dim i As Long
        LastRowWb = 1
    With Application
        With Application
        Exit Sub
    i = 0
'            File.Path, _
            If Err <> 0 Then
                LastRowOpenWb = 0
                OpenWb.Close False
                i = i + 1
                If i = 1 Then
                Wb.Activate
                If i > 1 Then
                OpenWb.Close False
            On Error GoTo 0
    With Application
    MsgBox "Done!"
    Exit Sub
Errorhandler:
    With Application
    Exit Sub
Code chuẩn rồi bạn. Cảm ơn bạn nhiều
- Sửa 1 số câu lệnh
        Exit Sub
     With Application
    i = 0
                OpenWb.Close False
                i = i + 1
                If i = 1 Then
                OpenWb.Close False
    MsgBox "Done!"
Errorhandler:
    With Application
Cho em hỏi thêm khi em không chạy gộp file em bấm cancel thì nó ra lỗi này. Thầy sửa giúp em chút cho em được không ạcancel2.PNG
