chickenguy
Sub TEST()
Dim lr&, i&, k&, col&, b1, b2, rng, res(1 To 10000, 1 To 2)
Dim dic As Object, key
lr = WorksheetFunction.Max(Cells(Rows.Count, "A").End(xlUp).Row, Cells(Rows.Count, "D").End(xlUp).Row)
rng = Range("A3:E" & lr).Value
For i = 1 To UBound(rng)
If Not dic.exists(rng(i, 1)) Then
dic.Add rng(i, 1), "1|0"
dic(rng(i, 1)) = Split(dic(rng(i, 1)), "|")(0) + 1 & "|" & Split(dic(rng(i, 1)), "|")(1)
If Not dic.exists(rng(i, 4)) Then
dic.Add rng(i, 4), "0|1"
dic(rng(i, 4)) = Split(dic(rng(i, 4)), "|")(0) & "|" & Split(dic(rng(i, 4)), "|")(1) + 1
For Each key In dic.keys
b1 = Split(dic(key), "|")(0): b2 = Split(dic(key), "|")(1)
If b1 >= b2 Then col = 2 Else col = 5
If rng(i, col - 1) = key Then
k = k + 1: res(k, 1) = key: res(k, 2) = rng(i, col)
Range("G3:H10000").ClearContents
Range("G3").Resize(k, 2).Value = res
Sao không lưu array mà cứ để dấu rồi lại tách.Bài này nếu dữ liệu tầm 10k loại và 100k dòng thì 2 cái vòng lặp ở cuối sẽ chậm như rùa.Vả quá, xài đỡ cái này:
PHP:Option Explicit Sub TEST() Dim lr&, i&, k&, col&, b1, b2, rng, res(1 To 10000, 1 To 2) Dim dic As Object, key Set dic = CreateObject("Scripting.Dictionary") lr = WorksheetFunction.Max(Cells(Rows.Count, "A").End(xlUp).Row, Cells(Rows.Count, "D").End(xlUp).Row) rng = Range("A3:E" & lr).Value For i = 1 To UBound(rng) If Not dic.exists(rng(i, 1)) Then dic.Add rng(i, 1), "1|0" Else dic(rng(i, 1)) = Split(dic(rng(i, 1)), "|")(0) + 1 & "|" & Split(dic(rng(i, 1)), "|")(1) End If If Not dic.exists(rng(i, 4)) Then dic.Add rng(i, 4), "0|1" Else dic(rng(i, 4)) = Split(dic(rng(i, 4)), "|")(0) & "|" & Split(dic(rng(i, 4)), "|")(1) + 1 End If Next For Each key In dic.keys b1 = Split(dic(key), "|")(0): b2 = Split(dic(key), "|")(1) For i = 1 To UBound(rng) If b1 >= b2 Then col = 2 Else col = 5 If rng(i, col - 1) = key Then k = k + 1: res(k, 1) = key: res(k, 2) = rng(i, col) End If Next Next Range("G3:H10000").ClearContents Range("G3").Resize(k, 2).Value = res End Sub
Mình dùng 3 vòng lặp, trong đó:Sao không lưu array mà cứ để dấu rồi lại tách.
Mình cảm ơn bạn nhiềuVả quá, xài đỡ cái này:
Đúng là dữ liệu cần xử lý của mình có khoảng 40k loại và 150k dòng. Bạn có cách nào xử lý không ạSao không lưu array mà cứ để dấu rồi lại tách.Bài này nếu dữ liệu tầm 10k loại và 100k dòng thì 2 cái vòng lặp ở cuối sẽ chậm như rùa.
Ơ, thì chạy thử xem mất mấy phút? Khi nào lâu quá thì tính tiếp nhé.Đúng là dữ liệu cần xử lý của mình có khoảng 40k loại và 150k dòng. Bạn có cách nào xử lý không ạ
