Dang Le Khanh Ninh
For j = 1 To Column_Draft
If j = 1 Then
If 0 < Sheets("Draft").Cells(2, j).Value < Lotsize Then Sheets("Draft").Cells(3, j).Value = 0
If Sheets("Draft").Cells(2, j).Value >= Lotsize Then Sheets("Draft").Cells(3, j).Value = Application.RoundDown(Sheets("Draft").Cells(2, j).Value / Lotsize, 0) * Lotsize
If j > 1 And j < End_column And Sheets("Draft").Cells(2, j).Value > 0 Then
Total_old1 = Application.Sum(Sheets("Draft").Range("3:3"))
Total_new1 = Application.Sum(Sheets("Draft").Range(Cells(2, 1), Cells(2, j)))
Sheets("Draft").Cells(3, j).Value = Int((Total_new1 - Total_old1) / Lotsize) * Lotsize
If j > 1 And j = End_column And Sheets("Draft").Cells(2, j).Value > 0 Then
Total_old2 = Application.Sum(Sheets("Draft").Range("3:3"))
Sheets("Draft").Cells(3, j).Value = QtyDay + QtyEndDate + QtyStartDate - Total_old2
Sheets("Pro Finishing").Cells(Row_Paste, Column_Std + j - 1).Value = Sheets("Draft").Cells(3, j).Value
If j = 1 Then
