[Nhờ giúp đỡ] Dùng BitBlt chụp 1 phần màn hình và hash phần ảnh đã chụp đó (2 người xem)
  • Thread starter Thread starter evolt
evolt
Hiện tại mình có code này dùng BitBlt save thành file ảnh, sau đó hash file ảnh vừa tạo.
Private Type GUID
    Data1 As Long
    Data2 As Integer
    Data3 As Integer
    Data4(7) As Byte
End Type
Private Type PicBmp
    Size As Long
    Type As Long
    hBmp As LongPtr
    hPal As LongPtr
    'Reserved As Long
End Type
Declare PtrSafe Function GetDC Lib "user32" (ByVal hwnd As LongPtr) As LongPtr
Declare PtrSafe Function CreateCompatibleDC Lib "gdi32" (ByVal hdc As LongPtr) As LongPtr
Declare PtrSafe Function CreateCompatibleBitmap Lib "gdi32" (ByVal hdc As LongPtr, ByVal nWidth As Long, ByVal nHeight As Long) As LongPtr
Declare PtrSafe Function SelectObject Lib "gdi32" (ByVal hdc As LongPtr, ByVal hObject As LongPtr) As LongPtr
Declare PtrSafe Function DeleteDC Lib "gdi32" (ByVal hdc As LongPtr) As Long
Declare PtrSafe Function ReleaseDC Lib "user32" (ByVal hwnd As LongPtr, ByVal hdc As LongPtr) As Long
Declare PtrSafe Function BitBlt Lib "gdi32" (ByVal hDestDC As LongPtr, ByVal x As Long, ByVal y As Long, ByVal nWidth As Long, ByVal nHeight As Long, ByVal hSrcDC As LongPtr, ByVal xSrc As Long, ByVal ySrc As Long, ByVal dwRop As Long) As Long
'Private Declare Function OleCreatePictureIndirect Lib "olepro32.dll" (PicDesc As PicBmp, RefIID As GUID, ByVal fPictureOwnsHandle As Long, IPic As IPicture) As Long
Public Declare PtrSafe Function OleCreatePictureIndirect Lib "oleaut32.dll" (PicDesc As PicBmp, RefIID As GUID, ByVal fPictureOwnsHandle As Long, IPic As IPicture) As Long
Private Const vbSrcCopy As Long = &HCC0020
Private Const S_OK As Long = 0
Function ScreenCapture( _
        ByVal x As Long, _
        ByVal y As Long, _
        ByVal w As Long, _
        ByVal h As Long, _
        ByVal fname As String _
) As Boolean
    Dim uPic As PicBmp
    Dim IPic As IPictureDisp
    Dim IID_IDispatch As GUID
    Dim hdc As LongPtr, hDcMem As LongPtr, hBmp As LongPtr
    Dim hBmpOld As LongPtr, lRes As Long
    On Error GoTo Failure
    hdc = GetDC(0)
    hDcMem = CreateCompatibleDC(hdc)
    hBmp = CreateCompatibleBitmap(hdc, w, h)
    hBmpOld = SelectObject(hDcMem, hBmp)
    lRes = BitBlt(hDcMem, 0, 0, w, h, hdc, x, y, vbSrcCopy)
    hBmp = SelectObject(hDcMem, hBmpOld)
    Call ReleaseDC(0, hdc)
    Call DeleteDC(hDcMem)
    With IID_IDispatch
        .Data1 = &H7BF80980
        .Data2 = &HBF32
        .Data3 = &H101A
        .Data4(0) = &H8B
        .Data4(1) = &HBB
        .Data4(2) = &H0
        .Data4(3) = &HAA
        .Data4(4) = &H0
        .Data4(5) = &H30
        .Data4(6) = &HC
        .Data4(7) = &HAB
    With uPic
        .Size = Len(uPic)
        .Type = 1 'bitmap
        .hBmp = hBmp
        .hPal = 0
    lRes = OleCreatePictureIndirect(uPic, IID_IDispatch, True, IPic)
    If lRes = S_OK Then
        stdole.SavePicture IPic, fname
        ScreenCapture = True
    Exit Function
Failure:
Sub Test()
Dim cTime As String
    cTime = "C:\OD\OneDrive\Download\myScreenPic" & Format(Now(), "yyddmmhhmmss") & ".bmp"
    If ScreenCapture(x:=0, y:=100, w:=800, h:=800, fname:=cTime) Then
        Debug.Print MD5(cTime)
Mình muốn lược bỏ bớt bước "lưu ảnh thành file sau đó hash file ảnh" mà muốn hash luôn không cần save file thì làm như thế nào ạ? Kính nhờ mọi người hỗ trợ!
Private Type GUID
    Data1 As Long
    Data2 As Integer
    Data3 As Integer
    Data4(7) As Byte
End Type
Private Type PicBmp
    Size As Long
    Type As Long
    hBmp As LongPtr
    hPal As LongPtr
    'Reserved As Long
End Type
        ByVal x As Long, _
        ByVal y As Long, _
        ByVal w As Long, _
        ByVal h As Long, _
) As Boolean
    Dim uPic As PicBmp
    hdc = GetDC(0)
    With IID_IDispatch
        .Data1 = &H7BF80980
        .Data2 = &HBF32
        .Data3 = &H101A
        .Data4(0) = &H8B
        .Data4(1) = &HBB
        .Data4(2) = &H0
        .Data4(3) = &HAA
        .Data4(4) = &H0
        .Data4(5) = &H30
        .Data4(6) = &HC
        .Data4(7) = &HAB
    With uPic
        .Size = Len(uPic)
        .Type = 1 'bitmap
        .hBmp = hBmp
        .hPal = 0
    If lRes = S_OK Then
    Exit Function
Failure:
Sub Test()
Dim cTime As String
Theo hiểu biết của mình thì bạn dùng biến IPic gán vào các thủ tục lấy ảnh là được rồi nhỉ. Bạn có thể nói nhu cầu đằng sau đó không?
Nhu cầu của mình là lấy được chuỗi hash của ảnh được chụp từ 1 phần màn hình mà không cần save file hình đó lại, vì mình check liên tục, save file như vậy sẽ chậm và ảnh hưởng tới ổ cứng.
Mình đang bí đoạn chuyển ảnh đang lưu tạm trong bộ nhớ thành mã hash, không biết search key word như nào :D
Mã hash nghe lạ với mình, không biết nó là cái gì, không phải là ảnh thì nó dạng gì bạn ví dụ xem nào?
Vậy dùng mấy cái chuyên dụng, chứ ai lại đi dùng VBA.
Vụ hình ảnh thì Python đi, có sẵn mấy thư viện.
Tới đây là gần xong bài toán rồi a, ráp với mấy phần khác nữa nên để VBA luôn.
Hash là hàm băm, nó chuyển bitmap/text/số/file v.v thành 1 chuỗi unique kiểu "099992c03b0768877469e93190cdb81b31bf91876131adf45791e30df108e479" , mục đích là phát hiện khung ảnh sau có thay đổi so với khung ảnh trước, để bạn check camera chẳng hạn
Vậy là mã gốc họ băm ảnh từ file. Vậy mình hiểu là file là lưu các byte, vậy hiểu là băm một khối byte. Thế bạn thử tìm Google với tiếng tây hay ta đại loại là:
"Làm thế nào chuyển IPicture sang bytes" + in memory + VBA
"Làm thế nào để băm/hash byte" + VBA
Có thể từ hai kết quả tìm được trên ra đáp án của bạn? Nếu làm được share lên cho anh em học hỏi nhé.
